ember1205 Posted May 1, 2014 Share Posted May 1, 2014 Hi, all. New to me 2000 VFR, just South of 40k on the clock. Previous owner was decent with his general maintenance, and always used regular dino oil for the motor. I'm wondering what the risks are if I try to swap to full synthetic at this point. Here's what I'm interested in knowing from those with direct experience: - Dino, blend, or full syn... Ultimately, which one allows for multi-season riding with good lubrication for the motor and keeps the MPGs decent? - Is switching to full syn from full dino at 40k advisable? Do I run any real risk of leaks or other similar type issues? - Is there any real benefit to switching to either a synthetic blend or full syn at all? I expect to ride it basically from April until November, when nice weather allows. Shorter trips, not much commuting or highway use. It's completely a recreational vehicle. I would expect to put anywhere from 2k to 4k on it in a season. Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted May 1, 2014 Member Contributer Share Posted May 1, 2014 There should be no risks. Any good full synth is fine. I use Mobil1 4T, my friend likes Motul 300V. Whatever is your preference; I don't see an issue. Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted May 1, 2014 Member Contributer Share Posted May 1, 2014 No issues. Left over rumors from way back when. I run 15W-40 full sythetic Castol Syn-tech. No problems so far. If you change your oil every year with only 3-4000 miles, then synthetic is kind of overkill. Not that it won't work very well, but with those short intervals a good dino will work just fine and save you some dough at the same time. Check out Rotella T3, an excellent oil. Link to comment Share on other sites More sharing options...
JDMBird Posted May 1, 2014 Share Posted May 1, 2014 On my old '94, my dad had ran Honda GN4 (I think that's the standard oil type) from the day he got it in '96. When he passed it along to me, it had around 25k on the clock, and I switched to Mobil1 4T. I ran it up to 37k before I let my little brother take it out and lay it down into a guard rail. That motor is still flawless to this day ( bike itself is currently being rebuilt by a friend). I've also switched from dino oil to full synthetic in my cages with no issues caused by the switch with mileage ranging anywhere from 60k, to 150k, all the way up to 250k at the switching point. For each of those vehicles, the motor outlasted the rest of the vehicle by far. Link to comment Share on other sites More sharing options...
ember1205 Posted May 1, 2014 Author Share Posted May 1, 2014 No issues. Left over rumors from way back when. I run 15W-40 full sythetic Castol Syn-tech. No problems so far. If you change your oil every year with only 3-4000 miles, then synthetic is kind of overkill. Not that it won't work very well, but with those short intervals a good dino will work just fine and save you some dough at the same time. Check out Rotella T3, an excellent oil. I get what you're saying, and I've thought of the fact that syn would seemingly be much more than I really -need-. I'm just thinking of the long-term health of the motor, keeping it running smooth, maximum fuel efficiency, etc. If it costs me an extra $15/year for the oil change, that seems pretty cheap to me. Link to comment Share on other sites More sharing options...
Guest Posted May 14, 2014 Share Posted May 14, 2014 According to Jim Wolf Racing, who builds all out racing turbo Nissans, the biggest advantage of synthetics is that, because of better film cling, they protect much better than dino at cold start up,which is when most of the engine wear occurs. Link to comment Share on other sites More sharing options...
ember1205 Posted May 14, 2014 Author Share Posted May 14, 2014 According to Jim Wolf Racing, who builds all out racing turbo Nissans, the biggest advantage of synthetics is that, because of better film cling, they protect much better than dino at cold start up,which is when most of the engine wear occurs. And yet, because of the requirement to use full synthetic oil in my snowmobile motor, it has to be fogged for the summer because the oil doesn't adhere to the motor internals as well as pure dino oil. Link to comment Share on other sites More sharing options...
Member Contributer BCmcrider Posted May 14, 2014 Member Contributer Share Posted May 14, 2014 I have a 2000 and switched to synthetic Rotella T6 at about 50,000kms. No issues. Also use a Fram 7317 filter for the past 50,000kms so likely I'll explode in a ball of fire soon. Link to comment Share on other sites More sharing options...
Member Contributer MadScientist Posted May 14, 2014 Member Contributer Share Posted May 14, 2014 I always hate to get into these things because there is always some qualitative aspect to certain motor oil qualities and they often get off topic. However, mineral group II and III (hydrotreat/cracked) and group v synthetic ester based oils generally have more polar (molecular dipole moment) molecules that interact more strongly with metal surfaces in the engine. The amount of charged ion components in the additive package also influences surface adhesion of a given lubricant, so film cling must be looked at on an individual formulation basis. And on topic: depending on the detergent mixture/content of the mineral oil vs that of the replacement synthetic, you may see increased clearing of engine deposits following the change to full synthetic. This isn't really related to the base stock of the oil though. Link to comment Share on other sites More sharing options...
Member Contributer digitallyhip Posted May 14, 2014 Member Contributer Share Posted May 14, 2014 I have a 2000 and switched to synthetic Rotella T6 at about 50,000kms. No issues. Also use a Fram 7317 filter for the past 50,000kms so likely I'll explode in a ball of fire soon. Not the same filter, though. Right, Ian? And: +1000 for Rotella T6 Link to comment Share on other sites More sharing options...
Member Contributer BCmcrider Posted May 14, 2014 Member Contributer Share Posted May 14, 2014 I have a 2000 and switched to synthetic Rotella T6 at about 50,000kms. No issues. Also use a Fram 7317 filter for the past 50,000kms so likely I'll explode in a ball of fire soon. Not the same filter, though. Right, Ian? And: +1000 for Rotella T6 I guess I did say "a" filter, but no, I've gone through several of them. Not sure if there is any difference in any of them. If you look up filter cross reference, each one covers a huge number of various machines, cars, bikes etc. Link to comment Share on other sites More sharing options...
Member Contributer y2kvfr Posted May 14, 2014 Member Contributer Share Posted May 14, 2014 I use M1 High Mileage synthetic. Doesn't have the friction modifiers, but isn't moto specific (_*gasp*_) Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted May 14, 2014 Member Contributer Share Posted May 14, 2014 The price of Rotella jumped from 18/gal to 25/gal here. Was going to switch to it, but maybe I'll just use the last of the GN4 for now. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted May 14, 2014 Member Contributer Share Posted May 14, 2014 The only difference between straight petroleum and a 100% syntheticsuch as Mobil 1 are the size of the molecules... synthetic is still crude fromthe ground but it is engineered with an expensive Ethylene gasprocess to produce the uniform size molecules... this is very desirablein our oil because it will decreases friction and increases flow and flow is paramount... Understanding FlowFlow is what really lubricates our engines not pressure... pressureand flow are inverse proportional... you can have pressure at theexpense of flow... an increased in flow is an increased in cooling bythe oil... an increase in flow works harder to separate the engineparts that are under very high stress... an increase in flow meansless internal drag and more HP at the rear wheel...Typically,synthetic oils same size molecules sport a higher viscosity index...This is another reason why they are better suited for the wide rangeof temperatures and riding conditions associated with motor-cycle use.They require little or no Viscosity modifiers... synthetic oilstypically will hold their viscosity grade longer and thus will rate ahigher index number than non synthetic... Uniform size molecules of synthetic oil Variable size molecules of refined crude What about viscosity???If there is one thing a owner has control over its the viscosity oftheir oil... so going by the official Honda manual I may choose either30wt 40wt or 50wt... this means that according to the Engineers whodesigned the engine any one the three viscosities are safe to reachyour longevity expectations... there is mounting evidence that this istrue because no one is complaining about selling their bike becausethe engine is worn out rather riders just grow tired and wantsomething new...So if you ask me what is the best oil I will say the one that givesthe most RWHP without wearing out your engine and lowers youroperating temp during summer... and that means any car or motorcyclespecific 100% synthetic 30 weight... I don't worry about running thelower viscosity 30 because it has proven to meet any owners mileageexpectations... Oil engineers know that flow not pressure lubricatesour prized engines and its time we learn that fact too... its nobrainier that 30 weights flow more than 40 or 50 and 100% syntheticsflow more than straight Dino...ClutchesTechnically speaking there is no oil that can not defeat a wet clutchin good working order... what is confusing the issue is the fact thatall motorcycle wet clutches will reach a point in their life and startto slip... no one complains about clutch slip when the bike is new...but on about the 27K to 57K range is when containments may build up topoint where the clutch begins to loose its grip... this is usuallydiscovered by the owner during WFO (Wide Fooking Open)throttle like ata track day... in error one can blame the oil but its really thecontaminants on the clutch plates...So the belief that we should stay away from Energy Conserving oil ison shaky ground... fact is I've been using 10/30 Energy ConservingMobil 1 since 98 in Mr.RC45 with no clutch slipping due to oil beingcertified 10% freer flowing than non EC oil... and it's a 27Khomologated racer with a tall first gear good for 90mph that's knownto incinerate clutch plates... Actual Viscosity explained Every oil company list viscosity of their oil at 2 temps 40ºC / 104ºF(room temp) and 100ºC / 212ºF (operating temp) Actual viscosity Mobil 1 grade 0-30 synthetic oil...At 40ºC / 104ºF viscosity = 56.7 cSAt 100ºC / 212ºF viscosity = 10.3 cS Actual viscosity Mobil 1 grade 0-40 syntheticAt 40ºC / 104ºF viscosity = 80 cSAt 100ºC / 212ºF viscosity = 14 cS Actual viscosity of Mobil 1 grade 15 50 synthetic...At 40ºC / 104ºF viscosity = 125 cSAt 100ºC / 212ºF viscosity = 17.4 cSThe thickness of moving oil is measured in centiStokes or cS. Themotorcycle engineers design the pump and blow off so the ideal oilviscosity is around 10 cS at normal operating temp of 100c or 212F...The really thick multigrade oils such as 50Wt have a viscosity of 17.4cS at operating temperature. Contrary what some people believe 50 isnot twice as thick as 30, it is only 7.3 cS thicker... or 7.3 cS less freerflowing... Synthetic Oils measured viscosity at start up during a hot 104º day(on a chilly 60º day the oil viscosity is even higher)...50wt 12540wt 8030wt 56 Oils measured viscosity at 212ºF operating temp...50wt 17.440wt 1430wt 10.2You can see what the problem with oil is... its too thick at roomtemp and just right at operating temps... the lesson that should be learned isidle the engine up to operating temp of 100ºC / 212ºF before selecting firstgear if you wish to properly lubricate your engine... Mr.RC45 with 55K on the odometer thrives on Mobil 1 0W-30 Link to comment Share on other sites More sharing options...
Member Contributer Dedofnite Posted May 15, 2014 Member Contributer Share Posted May 15, 2014 Hey Ember, Is VFRD the coolest school, or what!! All Honda manuals still say: "Engine oil quality is the chief factor affecting engine service life and performance." With updated wording over the past 60 years or so. Plain old dino oil is still used and recommended by Honda, as are the synthetics. I try to go with the manual recommendation for the year and model, as per the manufacturer when it comes to viscosity, temperature range, and dust conditions. Can't go wrong there. The difference in expensive vs. inexpensive is not real huge in a street bike situation, and race bikes just get fresh oil all the time. I use synthetic in just about everything, just for the longevity of the more stable consistent molecular structure. With dino oil I would just change it more often. My usual pick is Repsol, Motul or BelRay. Whatever is on sale. Cars, I use Mobil1. Remember, bikes use the same oil for the transmission, unlike cars. The brainy guys here would know better, but I think the synthetics hold up better in the shear and just plain wearing out department. I change once or twice a year, depending on mileage. With dino oil I would do 2 or 3 times. Really good information on this post, yeah? We got history class from FJ and JD. A lesson in molecular chemistry from Mad. An encyclopedia on engine hydro-dynamics from Busy. And Tanner, along with Honda, says: relax, pick your poison and use it, oil is oil. Just make sure you change it when you're supposed to! I am constantly amazed at the depth of knowledge and willingness to share on this site! Thanks to all you guys and girls for the input. Enjoy the ride. Ded Link to comment Share on other sites More sharing options...
spud786 Posted May 15, 2014 Share Posted May 15, 2014 You mean the only difference between Dino and fake synthetics. There are several non synthetic labled oils, that use the same technology. But the synthetic lables are a big money maker. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 15, 2014 Member Contributer Share Posted May 15, 2014 baby oil!! fresh squeezed! make a sandwich with the rest! Link to comment Share on other sites More sharing options...
Beck Posted May 15, 2014 Share Posted May 15, 2014 The old (back in the 80's) belief was, if you switch over from Dino oil to a high detergent synthetic like Mobil 1, at high mileage, the sludge that they say some Dino oils (Pennzoil was mentioned a lot) sometimes deposit in you engine after some miles, will get dislodged from nooks and crannies in your engine, possibly blocking off some of the smaller oil galleries and passages, leading to oil starvation for some components in the engine, and possibly engine damage. Not sure if that was ever proven to be the case, but it did get some people thinking about it back then....... Link to comment Share on other sites More sharing options...
Member Contributer Dedofnite Posted May 15, 2014 Member Contributer Share Posted May 15, 2014 NOOOOO, really, Spud??? You mean marketing isn't true? Like fake sugar will "make you skinny AND healthy" ? And, "100% organically grown" ? Ha ha! Well, gll, they did use pig fat for wheel bearings a long time ago... Beck, I'm pretty sure that DID happen to a few people who only changed their oil when they couldn't see any in the little window anymore, or didn't even know there WAS a dip stick... :unsure2: Ded Link to comment Share on other sites More sharing options...
WGREGT Posted May 15, 2014 Share Posted May 15, 2014 I have always used Honda non-synthetic GN4 on all my stuff. Swap it every 3k. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted May 15, 2014 Member Contributer Share Posted May 15, 2014 Turn into a another oil thread !!! Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted May 15, 2014 Share Posted May 15, 2014 Don't they always? In all my cages, I use dino oil all summer, because it's cheaper, and synthetic in the winter, to get a nice low viscosity oil for the nasty -40 winter weather. Never had an oil related issue in any of my cars/trucks, ever. Swapping back and forth is a non-issue. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted May 15, 2014 Member Contributer Share Posted May 15, 2014 I use M1 High Mileage synthetic. Doesn't have the friction modifiers, but isn't moto specific (_*gasp*_) Friction modifiers additives are only a small percent of the total oil product and help the base oil do things that it otherwise could not... Additives fall into several basic categories but Moly is the most often used friction modifier because it has such a high melting temperature (4730¯ F versus 2795¯ F for iron), it works great as a high-temperature, high-pressure antiwear agent. Some claim that because moly is so slick, it can cause clutch slippage... but note that 6 of the 19 motorcycle oils Sport Rider tested used moly including the HP4 market by Honda for any of their motorcycles... Link to comment Share on other sites More sharing options...
Member Contributer Dedofnite Posted May 15, 2014 Member Contributer Share Posted May 15, 2014 Good info Busy. Honda did have some trouble with the HP4 Moly when they started using the "slipper" clutches in some of the bikes, V twins and a few others, if I remember correctly. They warrantied enough of them that they sent out a service bulletin to not use Moly in those specific bikes. I remember trying it in my CBX, and it didn't cause any clutch issues, but did seep past some gaskets and made a black, ugly mess on the engine. I think they re-formulated and that is not a problem anymore. ded Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted May 15, 2014 Member Contributer Share Posted May 15, 2014 Link to comment Share on other sites More sharing options...
