AB-Oz Posted September 23, 2014 Posted September 23, 2014 Thanks everybody, hopefully this video from 0,7 bar bost , And more Picture comming OMG that is awesome!! Quote
Member Contributer Switchblade Posted September 24, 2014 Member Contributer Posted September 24, 2014 It's a hell of note when you have to let off the throttle so the front wheel touch down . Quote
Member Contributer Cogswell Posted September 24, 2014 Member Contributer Posted September 24, 2014 Wow... great opening post!!! Welcome... I can't wait to hear more Maybe the best opening post of all time - easily a top 10! There's also all the other mods (which look to be too many to count) . . . we need to see this bike with its clothes off! Quote
Guest wargen Posted September 24, 2014 Posted September 24, 2014 No i have no plans to offering kit…. sorry I will post more picture and video later Quote
Member Contributer Skids Posted September 24, 2014 Member Contributer Posted September 24, 2014 Apart from the obvious front end, suspension, electrics and rear sub-frame, what else have you changed? Quote
Member Contributer arrow Posted September 24, 2014 Member Contributer Posted September 24, 2014 No i have no plans to offering kit…. sorry I will post more picture and video later I think that's wise. A member here (Dan) created a of a supercharger kit for the VFR800s (both 5th and 6th gen) and some people were saying that they'd buy two if he ever started production. He did, and guess what, few people bought one. Granted it was a considerable sum that he was asking for, but I think that kit was easily worth that money. I was one of his customers and it really was a great creation. However I had some problems eminating from my bike (not the kit) and I gave up after a while and sold the bike and the kit seperately. I'm always left in awe after I see talented and knowledgable people create stuff like this. Looking forward to seeing more of your work... Quote
Guest wargen Posted September 24, 2014 Posted September 24, 2014 Hi, good thinking, there is hour and hour to figur out ingnition map, and hours to make a exhaust system so i took me 2 year of everyday work ok some day only 1 hour and some day 14 hours. If i make one more bying a frame for RV45 is not everyday shoping, you could use vfr chassi bits but count about 6 month work for me. No one will pay that( i think) Quote
Suitcase Posted September 24, 2014 Posted September 24, 2014 So you have another missile for NORAD to track.....NICE!!! Do you have an intercooler loop in your design? and is there circuitry in the EC you are using to accommodate and control nitrous oxide as in one nozzle in the intake plenum or multiples And a suggestion for extending your turbo chargers life ( a lesson I learned in owning 2 hi perf turbo cars) ..install a post engine shut off lube system...even though your crank isn't turning, the turbo can still be spinning at 10k rpm at shut down...without pressurized oil to lube it. here is just one of many available kits .non specific for m'cycles. http://www.autoenginelube.com/prepostlubekit.html Good luck with your very advanced development .. Quote
duccmann Posted September 24, 2014 Posted September 24, 2014 Ahh.. Holy shit batman....I want!!!.....great project...sound bite gave me chills......its my ring tone now...thanks and your bike is b e a utiful Quote
CandyRedRC46 Posted September 24, 2014 Posted September 24, 2014 Apart from the obvious front end, suspension, electrics and rear sub-frame, what else have you changed? sixth gen vfr swing arm? Quote
Guest wargen Posted September 24, 2014 Posted September 24, 2014 Ok god question, here is some bakground, i dont want to change te geometrics in orgininal RC45 i can drive it in my sleep, but when power output become higher and higher during new parts in engine for example the double injection ( talking race kit only) the swing was 2cm longer (also HRC kit) to handle more power. And that is exacly the lengt of 2002- vfr, but the orginalRC45 is same length as 1998-2001, so i decided to go for 2002- to handle more power output, so its 2001 engine 2004 swing and 2005ABS controler, frame is RC45 posting more pics later on, the first engine was 2004 vfr but that was dubble work to make mapping when no vtec or vtec on, so i decided to make powertest with that engine and piston breakdown at aprox 330 hp but maybe my fault do to to smal fuelpump it was rated 350hp but anyway it cracked, oil pump is god idea i do have an electric waterpump for circulate cooling water after poweroff Quote
Guest wargen Posted September 24, 2014 Posted September 24, 2014 Yes i do have room and plan for intercooler but i do log intake air and i is like 50 degres most and i newer drive more than 0,6 bar now and traction control takes down bost dynamicly depending on condition from readings from Abs rings, yes there is ready in ec for nitrius http://youtu.be/G0H0SKXhglE Here is some live data during driving and max bost is about .3 bar and traction works fine first part giving full trottle 1gear http://youtu.be/EAfosVhMsbs And here is a link to see when testing out the serve foregulating wing in turbo to reduce power when pressure go upp Quote
CandyRedRC46 Posted September 24, 2014 Posted September 24, 2014 Awesome!!! Have you thought about lowering the compression ratio or using methanol injection?? Quote
Member Contributer Rush2112 Posted September 24, 2014 Member Contributer Posted September 24, 2014 Loving this bike build.... Wargen you are the Man! Quote
Guest wargen Posted September 25, 2014 Posted September 25, 2014 I was deep into methanol early in project but engine works so perfect ether luck or wery good EC( MSIII)so no need for that when i go around ,6 bar no pre detonation lots of power, it just runs wery smoth, Im situated in Sweden smal town Visby on island Gotland, the best is that its road legal and dry weight is 165kg design goal was 150 but imposssible with turbo and ABS pump. http://youtu.be/uOtGVc9yXbY And here is a another cool stuff, an electronic display (bluetoth) but i like the original instrument more but this i first test with it so i forgot to change rpm display (to low). Quote
Aimbot9000 Posted September 26, 2014 Posted September 26, 2014 i may have to make a trip to sweden just to see this bike lol Quote
Member Contributer rangemaster Posted September 26, 2014 Member Contributer Posted September 26, 2014 You Sir, are a freakin' genius. Quote
HighwayStar2009 Posted September 26, 2014 Posted September 26, 2014 And I thought adding mirror extenders to my '09 was a mod. 2 Quote
CandyRedRC46 Posted September 26, 2014 Posted September 26, 2014 Do you have any idea on the weight difference between the rc45 swingarm and the VTEC swing arm? Quote
Member Contributer Mohawk Posted September 26, 2014 Member Contributer Posted September 26, 2014 A very sweet project. If you intercool then use a water/air cooler with separate radiator electric pump. I'd love to see some pics of the turbo exhaust & boost pipe plumbing. Do you have any idea on the weight difference between the rc45 swingarm and the VTEC swing arm? Ask Larry he scored an RC45 race one for Mr RC45 I believe. So I hope he has weights for standard (close to 5th gen) and the race unit. Quote
Member Contributer Dutchy Posted September 26, 2014 Member Contributer Posted September 26, 2014 i may have to make a trip to sweden just to see this bike lol My thoughts too!!! There's a NR replica being built in Denmark There's a NR replica being built in Sweden And now a Turbo RC45 in Sweden!!! Quote
Guest wargen Posted September 26, 2014 Posted September 26, 2014 Do you have any idea on the weight difference between the rc45 swingarm and the VTEC swing arm?I think wiith the HRC wheel hub brake etc 1/3 ... Quote
Guest wargen Posted September 26, 2014 Posted September 26, 2014 And price is x100 And HRC MkII kit swing with titan HRC hub brake etc is extreme difficult to source And 3 version ( not singel arm ) is impossible i think never seen any for sale Quote
Guest wargen Posted September 26, 2014 Posted September 26, 2014 And I thought adding mirror extenders to my '09 was a mod. You folks are wery funny, thanks for all god words all of you Quote
