Member Contributer YoshiHNS Posted January 27, 2014 Member Contributer Share Posted January 27, 2014 Ontario member with a captain america helmet? Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted January 27, 2014 Member Contributer Share Posted January 27, 2014 Dutch (or Belgian--they look the same to me!). Not sure about the "NR50". Are you sure it's not a Mikuni project, rather than a Honda one? Ciao, Link to comment Share on other sites More sharing options...
KanadianKen Posted January 27, 2014 Share Posted January 27, 2014 Hello everybody here's some pictures of what it can look like after a lot of work! Project was started in 94' with a 93 vfr. Cheers Is that the bike that Adrian ( i forget his last name - was it Vanderkroll ?) built? If so - I saw it after it unfortunately fell over in transport and some damage was done. If thats not Adrian's bike - then there are two in Ontario! Welcome to VFRD by the way! That does not look like an Ontario license plate? Correct- but the poster of the Pic is an Ontario member - and the plate could be a "prop". Our plates certainly are not that insane. Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted January 27, 2014 Member Contributer Share Posted January 27, 2014 Hello everybody here's some pictures of what it can look like after a lot of work! Project was started in 94' with a 93 vfr. Cheers Is that the bike that Adrian ( i forget his last name - was it Vanderkroll ?) built? If so - I saw it after it unfortunately fell over in transport and some damage was done. If thats not Adrian's bike - then there are two in Ontario! Welcome to VFRD by the way! That does not look like an Ontario license plate? That is not a license plate but an air brake that some municipalities require when you unleash a V4 upon public roadways...probably from the old world. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 27, 2014 Member Contributer Share Posted January 27, 2014 Fast bikes require big plates .... Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted January 27, 2014 Member Contributer Share Posted January 27, 2014 "Does this plate make my butt look fast?" Link to comment Share on other sites More sharing options...
Guest Posted January 27, 2014 Share Posted January 27, 2014 It is a dutch plate from the old country. Been in Ontario for 12 years but bike was made in holland. Link to comment Share on other sites More sharing options...
The Phantom Posted January 28, 2014 Share Posted January 28, 2014 Ahh, so you are indeed Adrian? That bike is legendary around here :) Welcome and wonderful to see her resurrected. Link to comment Share on other sites More sharing options...
AndreasH Posted February 12, 2014 Author Share Posted February 12, 2014 Rather sparsely between updates…but there is some progress! The side grills is very NR-specific and is a must-have on my replica. Problem is genuine parts is beyond expensive at €650 each…plus the fact they would not fit my fairings… So what to do? One option is to find a couple of industrial electronics heat sinks… …that happens to have the correct c-c between the fins. Cut the profile in your hobby cutting machine… …then cut the too long fins in your bandsaw… (and watch your fingers!!) Then mill the fins to 4,5mm height in your hobby cnc-machine. The base plate was way too thick, so mill it to 2,5mm. Here comes the trick: mill juuust through the base plate so… …the fins makes a grill! Deburr and toss is into your tumbling machine and leave it for a few hours… …and Violá! you have got a nice NR-look-a-like grill! Now I just need to adjust the radius in the corners and drill some holes, and finaly send if for anodizing. If you don´t have these machines in your garage it helps to have a good contact with a mechanical workshop... Big thanks to you Anders!! (Edit: Just to clearify...I do not have these Machines in my garage) And to Dutchy that generously helped me with pictures and measurements of the NR-grill. I also picked up my mufflers that have been anodized. Now I just waiting for the end-pipes to be bright anodized after being turned to a nice finish. Link to comment Share on other sites More sharing options...
timmythecop Posted February 12, 2014 Share Posted February 12, 2014 Please remove the word "hobby" from your keyboard. Carry on. Link to comment Share on other sites More sharing options...
AndreasH Posted February 12, 2014 Author Share Posted February 12, 2014 Please remove the word "hobby" from your keyboard. Carry on. Hmmm...I can´t find the hobby-key on my keyboard...maybe that word has a different meaning than what I thought ...? A failed attempt of beeing funny...Sorry! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted February 12, 2014 Member Contributer Share Posted February 12, 2014 Shaping up nicely Andreas! Link to comment Share on other sites More sharing options...
Member Contributer mk2davis Posted February 12, 2014 Member Contributer Share Posted February 12, 2014 I think Timmy was simply referring to the quality of your work being well above the typical hobbyist. Your work is top notch! Link to comment Share on other sites More sharing options...
marriedman Posted February 12, 2014 Share Posted February 12, 2014 I think Timmy was simply referring to the quality of your work being well above the typical hobbyist. Your work is top notch! My thoughts exactly! Link to comment Share on other sites More sharing options...
timmythecop Posted February 12, 2014 Share Posted February 12, 2014 I think Timmy was simply referring to the quality of your work being well above the typical hobbyist. Your work is top notch! My thoughts exactly! yes, it was a huge compliment. never "hobby" with you, always "pro". keep it up. Link to comment Share on other sites More sharing options...
AndreasH Posted February 13, 2014 Author Share Posted February 13, 2014 I think Timmy was simply referring to the quality of your work being well above the typical hobbyist. Your work is top notch! My thoughts exactly! yes, it was a huge compliment. never "hobby" with you, always "pro". keep it up. Aha, OK! Thanks guys! Link to comment Share on other sites More sharing options...
V4 Rosso Posted February 13, 2014 Share Posted February 13, 2014 Problem is genuine parts is beyond expensive at €650 each…And now you know why Nice work, this bike is going to look great. Link to comment Share on other sites More sharing options...
Helweg Posted March 4, 2014 Share Posted March 4, 2014 Hi guys I have asked Andreas if it was ok to join this thread, since we share the same passion in building a NR750 replica. I think we brought the fairings almost the same time, and we have had a mail korrespondance sharing measurements and ideas I was a little late to start up but finaly got started I started building the tail and are almoste done with the exhaust. Next step is to allign the fairing with the frame still needs a little adjustment It looks so easy ........ doesn't it Link to comment Share on other sites More sharing options...
AB-Oz Posted March 4, 2014 Share Posted March 4, 2014 looks great! We need a close-up photo of that rear wheel ! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted March 5, 2014 Member Contributer Share Posted March 5, 2014 Hot Dam that looks Good !!!! Link to comment Share on other sites More sharing options...
AndreasH Posted March 5, 2014 Author Share Posted March 5, 2014 Well done with the exhaust/subframe! I see you are a better welder than I am... My bulid is currently stalled by a house extension project... My goal to have it ready by spring has been revised to spring...2015. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted March 5, 2014 Member Contributer Share Posted March 5, 2014 So there goes my excuse for a trip to Sweden..... "Yes honey, I need to go north and see this finished NR build...." "the best laid schemes o' mice an' men Gang aft a-gley" Ok, move my trip to Sweden to 2015 then.... Link to comment Share on other sites More sharing options...
Helweg Posted March 10, 2014 Share Posted March 10, 2014 Today's work. - Had a little trouble getting lower fairing to fit, but by extending approximately 8 cm it fits fine now tomorrow i'll start molding fiberglass Link to comment Share on other sites More sharing options...
The Phantom Posted March 11, 2014 Share Posted March 11, 2014 OMG Excuse me while I go find a towel Link to comment Share on other sites More sharing options...
Helweg Posted April 11, 2014 Share Posted April 11, 2014 Time for a little update Dutchy and Andreas "Thanks for your help with pics, measurements and mirrors" First thing to mold in fiber was headlight , had to remove that surpriced look and give the face some nasty eyes Headlights is mounted on the frame, to make it more stabil. My idea is that it's easy to remove only the shell to get access to everything Setting up the mirrors And this is where I am now The rough part is almost done, from now on is the fine tuning, details and paint Link to comment Share on other sites More sharing options...
