Vnr? Wtf! Nr750 Replica
  • Replies 324
There was an NR750 sold quite cheaply in Japan this week (Equivalent of around $24,000 USD). http://page6.auctions.yahoo.co.jp/jp/auction/f142920225
A Japanese spec example, so "Only" 75 bhp.
Shhhhhh!!
(At least until I've managed to buy one for myself...)
Ciao,
Well even the serial NR750 is a exotic and rare, nice looking bike, I wounder why not anyone done a replica of the race NR´s?
Like this one
A peak inside the real thing
  • 1 month later...
NR = Never Ready?
I hope not…
House extension project is now done, and the long and warm summer is over, so it is time to get this build moving again!
However there has been some progress since I dropped this build in January.
Single nut, or more precise “single nut”…
A bolt with large washer to cover the four nut-holes in the wheel, a special washer and a castle nut. (Thanks Duchy!)
Just need to put in a R-pin.
I have also put “air intake tubes” on the tank. Just for looks of course…
Needs more fine tuning with filler for the right NR-look.
Right now I have taken a step back with the fairing brackets. I found that the fairing was positioned a bit obliquely.
But everything is a compromise…if not the brake reservoir is colliding with the fairing, the clutch lever will.
So I need to find out the point of the least bad.
I hope I can update this thread on a regular basis from now on.
The absolute goal is to have the bike ready till spring 2015!
Brae!!!!
Do you have a local shop that can produce the decals/stickers? Like the one for the rear hub.
Echelon3:s replica is probably the closest you can get to the real deal…
Very very nice work!
Unfortunately I don´t possess the skills it takes to achieve that kind of quality.
Since last update I have been working with the front fairing bracket.
Finally I have the instrument-cluster in place, along with wiring loom, relays, fog lights and oil cooler!
It was really tight since the headlight stole a lot of space.
  • 3 weeks later...
A little update.
I´m working on the exhaust…again. Now trying to get the pipes in proper position.
Needs fine tuning later.
The exhaust will be wrapped with heat resistant bandage to reduce heat radiation inside the rear end.
I will also put heat shields in some places where the tubes gets close to the fairings.
For the moment I´m adjusting the battery-box to make room for the electronics also.
wow man, I take my hatt off for that one. very nice project!
it's looking very good. can't wait to see it finished.
I'm working on my vfr 95 as well, to make it a streetfighter, I'll post pictures when ready.
greetings from Belgium
  • 3 weeks later...
With a rate of 2-3 hrs a week things are moving really slow…but it´s moving forward.
Finally I got all parts for the mufflers.
All special made after my design.
And it fitted perfectly!
To be able to fine tune the pipes through the grill I had to make adjustable brackets for the mufflers.
Det ser godt ud Andreas # great job" It's the details that counts - I'm working on my grills right now, the rest is ready for painting but it's too cold for that right now
I want to wish you all a Merry Christmas
