Member Contributer lawnmowerman Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 just wondering if there is any suggested oil filter and why , Im in need of a oil change i am trying to stay away from k&n oil filter Link to comment Share on other sites More sharing options...
Member Contributer DannoXYZ Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 I've read numerous oil-filter studies over the years and have cut a few filters to verify. I agree with them mostly. Avoid paper filter elements and cardboard end-caps. A seal on anti-drainback and bypass valve is nice to have. I've used following: Honda OEM filter (20 different part#) PurePro PH7028 Mobil MO4612 Mahle OC575 Link to comment Share on other sites More sharing options...
Member Contributer RC1237V Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 Purolator One for Honda cars are what I use on the 90, and 93 VFR750, the VFR1200, and the RC51 - they make a long and a short. Some bikes will only fit the short... https://www.calsci.com/motorcycleinfo/FilterStudy.html Pure One PL14610 $6 50*.39*2.36 92 Silicon Silicon A A This is how an oil filter should be made. The anti-drainback valve is double the thickness of any other here, and obviously seals very well. The media is the best available, and there's a lot of it. The bypass valve is made from a laser-cut piece of stainless steel, and just can't bind or jam. Link to comment Share on other sites More sharing options...
TimC Posted January 30, 2021 Share Posted January 30, 2021 My last several oil changes on my old 6th gen, I used either the Mobil 1 or Purolator One almost exclusively. These are only a few bucks more than the cheaper filters, and the better quality is absolutely worth it. Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 Yep, I use the Purolator 1, long one. Not much bigger than OEM, but every little bit helps. Link to comment Share on other sites More sharing options...
Member Contributer airwalk Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 Mobil1, preference #110(longer) but #108(oem length) is fine, changed @ approx. 10k km or every other 5K km oil service. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 I'm also using Pure1's, have been fine. I also have three Dimple "Black Hole" magnets on the filter to trap magnetic swarf that my magnetic drain plug tells me circulates through these bike's systems. They're crazy strong for their size and swap from filter to filter. They never move a mm between changes. Maybe more important than the choice of filter other than staying away from K&N. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 I continue to employ a K&N 303 filter on Mr.RC45 and I have used OEM and High Flow with equal satisfaction... Honda OEM... Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 40 minutes ago, Cogswell said: Maybe more important than the choice of filter other than staying away from K&N. Mercy Cogs... there is no good reason to warn against K&N... Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 39 minutes ago, BusyLittleShop said: Mercy Cogs... there is no good reason to warn against K&N... BLS.. PLEASE, lets not confuse people. We DON'T want people to be using the K&N with the spot welded hex nut. AND.......If K&N continue to produce this dangerous rubbish why bother to support them at all when there are so many other good alternatives! Couldn't care if K&N were Gold Plated, I'd never buy one, hex nut or not. Link to comment Share on other sites More sharing options...
Member Contributer DannoXYZ Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 There's reason K&N filters are banned by most racing orgs and many TDPs (and more soon ). I was at trackday at Thunderhill where K&N blew going into T14. Crash collected 5 other bikes. Totaled very nice Aprilia RSV4. One guy broke both wrists. It used to be thought it was user-error that was causing filter to fail. K&N was blaming end-user. But they were just accelerating the failure sooner by using nut to tighten filter. Real issue is welding on such thin disposable weak metal causes precipitation of carbide particles in HAZ. This causes embrittlement and lowers ductility of metal. It's is more fragile and crack-prone. What happens with each ride is you have heat cycles along with low/high pressure cycling. This initiates cracks in HAZ which eventually meet and filter blows. Obviously each filter moves along SN curve (strain/stress cycles) at different rates. Bikes with higher daily and track usage obviously will have quicker failures. Link to comment Share on other sites More sharing options...
Member Contributer RC1237V Posted January 30, 2021 Member Contributer Share Posted January 30, 2021 Probably a very low failure rate, but when you sell half a million filters a year... I used to buy them, but when I started going to the track, and found out about the failures I switched. It only takes an extra second or two to grab my fitted oil filter socket along with my drain bolt socket, so not much savings just for the nut - but some inherent risk.... Link to comment Share on other sites More sharing options...
Sp00ks Posted January 30, 2021 Share Posted January 30, 2021 Where are you guys buying your filters. I didn't see much on Amazon or Revzilla. Typically just K&N. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 1 hour ago, Sp00ks said: Where are you guys buying your filters. I didn't see much on Amazon or Revzilla. Typically just K&N. AutoZone, Walmart, Advance Auto Parts....... Pure One or Bosch based on the Calsi data. Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 Auto parts store, usually O'Reilly's. Link to comment Share on other sites More sharing options...
Member Contributer DannoXYZ Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 2 hours ago, Sp00ks said: Where are you guys buying your filters. I didn't see much on Amazon or Revzilla. Typically just K&N. Trick is to know model/part# of filter you're looking for. Such as Amazon - Mobil-1 M1-108 or Amazon - Mobil-1 M1-110 or Amazon - Purolator PL14612 or Amazon - Bosch 3300 filter. Amazon - Baldwin B7285 is good because it's RED to match bike! They make filters for Amsoil. Don't search for "1998 VFR oil filter" because Amazon only list item they've tested to fit as compatible. Most of time, they haven't tested anything and it will find nothing. If you search for "H4 bulb" it will find 1000+ hits. But if you narrow it down to "fits 1998 VFR800" it will show nothing is compatible because Amazon hasn't physically put that particular bulb into VFR800 and confirms it works. Rather than say "not compatible", they really should list 3rd category of "untested". Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 3 hours ago, BusyLittleShop said: Mercy Cogs... there is no good reason to warn against K&N... I unfortunately personally know two people who had one fail, both cracking around the nut and soaking their rear tire going down the road (one was on a 5th gen). Both were extremely lucky. There was also the travel thread on here by Olive some years ago (no longer active here) where it failed at the nut and did the same thing. I can recall a couple of others but don't recall the members that posted. For the record I do not know how they were installed or if they were damaged prior to install. If using one I would suggest not using the nut to tighten it - hand tighten only. I don't ever recall any anecdotal reports about filters without nuts experiencing that kind of failure. I'm not saying they all fail, however the risks do seem elevated relative to non-nut filters. Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 17 minutes ago, Cogswell said: If using one I would suggest not using the nut to tighten it - hand tighten only. Hi Cogs. Wouldn't even suggest using a K&N with the nut, they have failed with people who haven't used the nut to tighten. As DannoXYZ rightfully mentions, the welding process to such thin metal causes the weakness, its just never worth the risk, avoid these filters like the plague or Covid! Link to comment Share on other sites More sharing options...
Member Contributer lawnmowerman Posted January 31, 2021 Author Member Contributer Share Posted January 31, 2021 thanks for all the info, K&N is out, some of your replies with filter numbers were great think im going to go with Mobil 1 or Purolator 58 minutes ago, DannoXYZ said: Trick is to know model/part# of filter you're looking for. Such as Amazon - Mobil-1 M1-108 or Amazon - Mobil-1 M1-110 or Amazon - Purolator PL14612 or Amazon - Bosch 3300 filter. Amazon - Baldwin B7285 is good because it's RED to match bike! They make filters for Amsoil. Don't search for "1998 VFR oil filter" because Amazon only list item they've tested to fit as compatible. Most of time, they haven't tested anything and it will find nothing. If you search for "H4 bulb" it will find 1000+ hits. But if you narrow it down to "fits 1998 VFR800" it will show nothing is compatible because Amazon hasn't physically put that particular bulb into VFR800 and confirms it works. Rather than say "not compatible", they really should list 3rd category of "untested". Link to comment Share on other sites More sharing options...
Sp00ks Posted January 31, 2021 Share Posted January 31, 2021 1 hour ago, DannoXYZ said: Trick is to know model/part# of filter you're looking for. Such as Amazon - Mobil-1 M1-108 or Amazon - Mobil-1 M1-110 or Amazon - Purolator PL14612 or Amazon - Bosch 3300 filter. Amazon - Baldwin B7285 is good because it's RED to match bike! They make filters for Amsoil. Don't search for "1998 VFR oil filter" because Amazon only list item they've tested to fit as compatible. Most of time, they haven't tested anything and it will find nothing. If you search for "H4 bulb" it will find 1000+ hits. But if you narrow it down to "fits 1998 VFR800" it will show nothing is compatible because Amazon hasn't physically put that particular bulb into VFR800 and confirms it works. Rather than say "not compatible", they really should list 3rd category of "untested". Great thank you. I don't buy many vehicle parts from Amazon. Link to comment Share on other sites More sharing options...
Member Contributer boOZZIE Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 52 minutes ago, Grum said: Hi Cogs. Wouldn't even suggest using a K&N with the nut, they have failed with people who haven't used the nut to tighten. As DannoXYZ rightfully mentions, the welding process to such thin metal causes the weakness, its just never worth the risk, avoid these filters like the plague or Covid! And don't forget that they had a world wide recall on these filters a couple years ago a didn't bother to tell their Overseas reps about it Link to comment Share on other sites More sharing options...
Sp00ks Posted January 31, 2021 Share Posted January 31, 2021 While we are on the oil filter topic, what is everyone using for oil? A full synthetic? Suggestions? Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted January 31, 2021 Member Contributer Share Posted January 31, 2021 10 minutes ago, Sp00ks said: While we are on the oil filter topic, what is everyone using for oil? A full synthetic? Suggestions? Oh no, please, not another oil debate!!!! Just do a sesrch you'll find tonnes of info. Link to comment Share on other sites More sharing options...
Sp00ks Posted January 31, 2021 Share Posted January 31, 2021 1 minute ago, Grum said: Oh no, please, not another oil debate!!!! Just do a sesrch you'll find tones of info. LOL, Ok. Sorry. We have a guy at the office that we troll about Oil and Tires. He's a good sport about it but I understand what your saying. Maybe I can delete my post. Link to comment Share on other sites More sharing options...
Forum CEO HispanicSlammer Posted January 31, 2021 Forum CEO Share Posted January 31, 2021 I bought a scott stainless steel mesh filter for my 98 vfr 18 years ago and still used it for my 2010 vfr1200. It is good for 35 microns, I have had to replace the gasket only twice. and it has a magnetic prefilter. I think I paid 80$ for it and its still in great shape. The outter part has some road gunk on it and some marks from a wrench its not as pretty as it once was but still an awesome filter. Its a bit messy cleaning it during oil changes but so? https://www.scottsonline.com/Product_Purchase2.php?Bike_ID=5513&BI_ID=144104 Link to comment Share on other sites More sharing options...
