2 things:
We dont get those groovy lamps in the corners:
and I saw this the last time I was at Assen:
9 hours ago, Tightwad said:
Did you lose a gear from your custom keychain?
Both.... :-(
Will make a new one once I get that printer in the office to function as it should.... :-)
7 hours ago, timmythecop said:
2 things:
They just got groovier...
By law, only yellow or white allowed, mr plod could issue a 65 euro ticket... Could... Were I to put blue in, he will for sure...Have a regular white ones under the seat. Rumor has it that green lights get noticed so I will try for a while
3 hours ago, SEBSPEED said:
Details on the slider pins please? Just finished rebuilding 4 of those calipers, could use some!
Pro-Bolt :-)
RaceBolt, too, I think.  I have some that are more of an OEM-type flush-fit without the safety wire drillings.
Ciao,
Spring is in the air!
I suspected it at the end of last year's riding season
and yes, them brake pads were due....
Did a shakedown run, all :beer:
On ‎19‎.‎3‎.‎2017 at 7:42 PM, Dutchy said:
Cheers!
Finalised "cleaning up" the front with some bits from Pro-Bolt
So this bolt I will likely replase on my RC24 as well, and its actually the same part as on your SP2!
Are you ok with this Doug?
I can re-do if needed... :-)
Looks good on the top pic, not sure about the tension, but the twists per inch look consistent, and it has been done on the correct direction. For the caliper bolts though, I can;t really tell how many twists per inch, almost looks like it isn't. Should be right around 6-8 full twists per inch. It could be correct, and the angle could be deceiving. Overall, I give you a solid B+. If I was able to tell the tension, that could raise you a full letter grade. It would most definitely pass track scrutineering though, so yeah, you did good!!!
Take two...
Sukran!!!   I think so too.
This one is for Sweeper, for he enquired...  :-)
One of redsluts handbags got a new lease of life.... For instance my camping weekend this month to WSBK Assen.
Plenty stash room for the "bare essentials"...
Lift the front wheel without the throttle ;-)
Your SP is becoming a Practical sports bike! Just like a VFR! :fing02:
But pour some of the bottles in a glass for today!
Dude, with that trunk, the way you have it set up.... It looks like you don't want to have that trunk to be part of your bike..
We need to talk dude.. Seems like the Baltic experience has done some brain damage...
I blame the Danish whisky......   :goofy:
No worries, the pizza box will be used on very rare, specific occasions....
I had it lying around in excess so better use it no?
I could move the base plate forward/over the seat hump, but that would look silly (too)...
It's just like a womans clothes, - very difficult to find something that fits and looks good.    -     without laces ,
but I like your colour matching tank bra.
My wife made a wise choice.......   leaving the SP for what it is...
Good the old girl get a turn!
Steady.....
She is 53 :-)
About yhe age to turn the
2 hours ago, Dutchy said:
Steady.....
She is 53 :-)
About the age to turn the SP2 into a ST1300 or a GL and keep the VF for the twisty shortcuts in life...:wink:
