Member Contributer vfrcapn Posted March 15, 2013 Member Contributer Share Posted March 15, 2013 Just wanted to see if anyone had tips on swapping a motor in a 5 or 6g? I'm thinking of rigging up ceiling straps to support the rear frame and dropping the motor & swingarm. Any good alternative short of a complete teardown? Link to comment Share on other sites More sharing options...
Member Contributer wagzhp Posted March 15, 2013 Member Contributer Share Posted March 15, 2013 Sorry, I can't offer any insight, but I'd be more than happy to offer you help with the heavy lifting. Say, was that you I waved to at park and Stanford ranch tonight? Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted March 15, 2013 Author Member Contributer Share Posted March 15, 2013 Yep, looked you and the wife were off for an evening ride. Link to comment Share on other sites More sharing options...
wera803 Posted March 15, 2013 Share Posted March 15, 2013 Just wanted to see if anyone had tips on swapping a motor in a 5 or 6g? I'm thinking of rigging up ceiling straps to support the rear frame and dropping the motor & swingarm. Any good alternative short of a complete teardown? I know WERA910 pulled the engine out of a 5th gen. I'm sure he has a picture or two in his gallery if you want to look there. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted March 15, 2013 Member Contributer Share Posted March 15, 2013 Don't drop it on your toes. It's a bit heavy. Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted March 15, 2013 Member Contributer Share Posted March 15, 2013 The 5th gen service manual shows the rear supported via a bar through the rear subframe to a couple of support frames. Get it up, get it stable then remove the swingarm, then the engine.I'd advise removing all the ancillery parts Tank, Airbox, Injectors, Radiators etc before supporting it for engine removal. The engine is about 75Kg so more than a one man job. If you have the ability to make an engine holding frame do so & use a wheeled jack to move it ! Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted March 15, 2013 Member Contributer Share Posted March 15, 2013 75kg?? That's more than the transmission out of my car! Wow. Link to comment Share on other sites More sharing options...
spawningvat Posted March 15, 2013 Share Posted March 15, 2013 I just swapped an engine into a 4th gen frame. This job was a bit easier because the 4th gen swing arm mounts to frame. The 5th gen swing arm mounts to the engine. Here's how I did it: -Loosen/remove as much as possible. (Tank, entire exhaust, chain and cover, rad, oil cooler, air box, carbs or throttle bodies, all electric plugs, coils and wires, etc) -I unbolted all the mounts and dropped the engine onto wood under the from most part of the oil pan using a screw jack and pivoting on the rear mounts. -Made a castle nut driver out of a 7/8" socket. You will need an impact driver. I used a hammer impact driver from harbor freight, with a 3/8" adapter into the socket. Probably easier to order the right castle nut driver. -Removed last bolt, and used jack to drop engine another few inches. -Used ratchet straps to hook up the frame and lift it up high enough to swing it out of the way. -Moved old engine away with help. -Moved new engine into exact same space with help. -Dropped frame back onto engine and started rebolting. Easy stuff. I did it all outside, in the cold of winter, with gloves and earmuffs, and some ample swearing. Used anti seize on everything for less swearing next time. Goodluck! Everyone likes pictures: The rest: https://plus.google.com/photos/116949566934695094716/albums/5855567419689021121?authkey=CKG0k_uG3J6Mcw Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted March 15, 2013 Member Contributer Share Posted March 15, 2013 I dont think it would be all that hard, if you are organized. I like to put sets of faseners in ziplock bags and label them. I think mostly the job is more tedious than difficult. Here's a pic of mine when I stripped it down, and just few more parts and bolts and the engine would have been out sitting on the jack. Probly just pull the frame off the engine. -I think VeeferCanuck did something of the reverse when he installed a new frame -- Unbolted the frame from the engine. Link to comment Share on other sites More sharing options...
Guest Posted March 15, 2013 Share Posted March 15, 2013 best way is pay a tech 150 like I did,even picked the bike up and delivered it. Link to comment Share on other sites More sharing options...
The Phantom Posted March 15, 2013 Share Posted March 15, 2013 As hinted at above - don't drop the engine out, far easier to support the engine and lift the frame off it. Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted March 16, 2013 Author Member Contributer Share Posted March 16, 2013 Thanks for the tips. I don't expect it to be hard, just tedious and looking for shortcuts. I'm hoping to do this over a 3-day weekend. Was planning to drop the motor but I like the idea of supporting it and picking the frame off, although I wasn't planning to pull the forks or front fairing, and that whole assembly with frame and rear subframe must be at least 75kg/165lbs. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted March 16, 2013 Share Posted March 16, 2013 -I think VeeferCanuck did something of the reverse when he installed a new frame -- Unbolted the frame from the engine. Yes, I removed the frame from the engine vertically, and left the engine sitting on some wooden blocks and the centerstand. Easier than muscling the engine up into the frame. Link to comment Share on other sites More sharing options...
soichiro Posted March 16, 2013 Share Posted March 16, 2013 Thats how we do modern Honda and acura cars. Leave the enine on the ground and raise the car. I have done it on a busa by putting anchors in the ceiling studs, Raised the bike right off. Left the engine sitting. The more you can take off the better. Link to comment Share on other sites More sharing options...
Member Contributer wagzhp Posted March 16, 2013 Member Contributer Share Posted March 16, 2013 Yep, looked you and the wife were off for an evening ride. Yep, guilty as charged. Let me know when you're going to do the swap. I'd love to help, or at least watch. Link to comment Share on other sites More sharing options...
Auspanglish Posted March 16, 2013 Share Posted March 16, 2013 Yeah I, like most who have replied, lifted the frame off the motor... the latter supported on wooden blocks. Link to comment Share on other sites More sharing options...
Arri Posted March 16, 2013 Share Posted March 16, 2013 Auspi, I like a lot that work , but i know that you have a nice video about the first start of the new bike. .. Link to comment Share on other sites More sharing options...
Auspanglish Posted March 16, 2013 Share Posted March 16, 2013 Auspi, I like a lot that work , but i know that you have a nice video about the first start of the new bike. ..Hehehe... yeah but it's in Spanish and doesn't have subtitles... ;) Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted June 1, 2014 Author Member Contributer Share Posted June 1, 2014 Ok, I took my sweet old time getting this done...used 25K California motor been sitting for almost 2 years. Swapped in 49-state cams and ECU, converting '99 CA motor to 49-state specs, +5-6 HP, with a little Seb clutch cover. Original motor went 93K, 2nd gear gone. Took half a crank to bring it to life, gotta love Honda engineering. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted June 1, 2014 Share Posted June 1, 2014 Nice. Good work. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted June 1, 2014 Member Contributer Share Posted June 1, 2014 Great job on the swaps in this thread. When doing a job like this that involves lots of fasteners, zip lock bags and a marking pen are your friend. Helps things go smoother on re-assembly. Link to comment Share on other sites More sharing options...
Member Contributer Willy Posted June 1, 2014 Member Contributer Share Posted June 1, 2014 Gene Autry once said "back in the saddle again" ...... Great job Mike! I bet it feels good to get it completed and back on the road. Ernie Link to comment Share on other sites More sharing options...
VFR4Lee Posted June 1, 2014 Share Posted June 1, 2014 best way is pay a tech 150 like I did,even picked the bike up and delivered it. I just want to know what mechanic does all that work for only $150. Mine charges $80/Hr. They would have to be extremely fast. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted June 1, 2014 Member Contributer Share Posted June 1, 2014 All rrrrrriiighhght! Very cool Capn, Been waiting for this update. Congrats on all the work! - Cant wait for a ride report with the new cams. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 16, 2014 Share Posted September 16, 2014 Still running good??? Link to comment Share on other sites More sharing options...
