Slow burn 5th gen build - old skool kool!
Stray
^ Love the blue pipes above - reminds me of this beast...
Nice! I refrained from posting the same when I thought the same!
Great minds think alike...and so do ours.
Still stuck on what fairings to fit on the race bike, so thought I’d give the poor old 5th gen “Donkey” some love instead. Hoping inspiration for the racer will strike soon!
Had some GSXR 750 coils on the shelf so decided to treat the “Donkey” to them. What a daft idea - took a whole day of messing about and dismantling the bike to to reach the spark plugs, especially the front pair. Many choice words were used!
Big thanks to Ranger and Mohawk for pioneering this mod. Followed your thread and cut off connectors from a CBR900 loom, even matching the wire colours.
Below I cut out the metal tube from an insulated crimp for a cleaner install.
Crimped with a proper tool and slipped adhesive heat shrink over each join, then another bigger tube over them both. Tried to stagger the joins by snipping the wires at different lengths so they’re not right next to each other.
Bike has done 29k miles so I thought best to replace spark plugs whilst I’m in there. Wouldn’t want to have to rip the bike apart again so threw in some NGK Iridium ones. Below you’ll see the regular NGK plug (top), the NGK Iridium XI (aftermarket, middle in blue box)) and the Laser Iridium (OEM, bottom in silver box). I believe the Laser Iridium are fitted to the 7th and 8th gen bikes as standard?
Apparently the Iridium IX are good for 40-50k miles, whereas the Laser are good for 80-100k.
Closeup of the firing electrodes on a regular vs Iridium IX plug. See how fine the iridium one is?
NGK Iridium IX going into the Donkey and Laser Iridium saved for the racer.
Scratched each coil top with the cylinder it belongs to, and also marked the end of each connector with the same number. Should reduce confusion if I ever tear the bike down in future.
The Donkey now fires up nicely, as it did before, but at least the coil clutter is gone so bike is easier to work on. Fresh plugs also a bonus.
Next up is clutch master and slave upgrade on the Donkey…
Clutch action on the Donkey was a bit heavier due to the 6th gen clutch springs installed last year. Not really a problem but thought I’d try improving comfort in traffic.
In another thread we’d established the 6th gen master cylinder has a smaller piston than the 5.1 gen (1/2 inch vs 14mm) so this should give me better leverage over the slave and a softer hand action. Also fitted an Oberon 38mm slave (vs 36.5mm) which should further improve the action.
First step was to rebuild the 6th gen clutch master with a Tourmax kit as it was crusty!
Had an old braided brake line same length and banjo angle as the VFR clutch hose so decided to fit that too. Didn’t want to dismantle the bike again so tied the new line onto the old one with some wire and pulled it through.
The rebuild kit didn’t have a seal for the lever push rod thingie which had split, so I pulled the old piston seal off and reused that instead.
Piston seal is slightly bigger and actually seals better. Here it is fitted and the lever cleaned/lubed up. Luckily the 5th gen lever fits on the 6th gen unit (mine came without a lever).
Everything fitted together and bled with fresh brake fluid. Has solid feel but lever tied back to the bar overnight just in case there are any bubbles still trapped in there.
New unit looks exactly like the old one. View of the “open” airbox and ghetto phone holder (from a bicycle!) if anyone is interested.
All right folks, back to the racer front fairing ideas and I need your help!
I’ve posted some pics below to get creative juices flowing but please don’t limit yourself to these. Only parameters are:
1. Must accommodate high bars because I’m old and brittle
2. Must be functional
3. Must look fantastic (subjective, but don’t want to be laughed at!)
Honda RS1000
Honda RS1000 lookalike
CBR900RR with RS1000 looks IMG_5600.jpeg.e3c53f5c6d4bdb1aec1ac8fced5efcf3.jpeg
Same again but different fairing
Some sort of custom fairing for an RS1000
CBR600RR with Ducati 900SS front fairing cut down a bit at the bottom
CBR900RR early FireBlade (got an RC30ish vibe going on)
Yamaha XSR900GP
Yamaha TRX800 with modified headlight
BMW with what looks like a Yamaha TRX800 front fairing
IMG_5631.thumb.jpeg.440212c4796ee2afd6a1312f97ffe9e5.jpegIMG_5632.thumb.jpeg.a411c41199ea6d10d0525fce9a2f5413.jpeg
Another BMW with cool unknown fairing
Yamaha FJ1200 - integrated indicators are a bonus but doesn’t scream “sexy”IMG_5626.jpeg.a71047984b0ac6bb7fb069213460f87e.jpeg
Kawasaki GPZ900
Kawasaki GPZ900 with added mid-fairings
Ducati 750F1
Suzuki XR69
IMG_5612.webp.ea19173e69661a5ab7bbe0b09005565c.webpIMG_5611.jpeg.1245758aab1fd052c12759656f4c114d.jpeg
Suzuki GSX1100 Slabside
Dustbin fairings. Look cool but impractical as can’t turn the front wheel to full lock and ground clearance at the front is compromised. Also death weave with crosswinds…
VTR1000 Firestorm
VTR1000 Firestorm with a cool fairing
VFR800 5th gen Bioblade (thanks Mohawk!)
VFR800 custom fairing (looks like a Batwing cut to pieces?)
VFR750 (2nd gen?) endurance racer
NR750 - body kits available that might fit but the front isn’t what I’d call handsome
NC30/35 - somebody on this site fitted NC30/35 fairings to a 4th gen so it might work. But pics are long gone so can’t really tell for sure…
VF500 Endurance racer
VF750
VF1000 (F1?)
VF1000R with same NSR250 tail I have
VF1000R with custom front fairing
VF1000F2 Bol d’Or with cut down tail
NS400R - nice but might be too narrow for my radiator…
So what are your thoughts?
I think the only ones that will accommodate your bars (and sit close to where they should be) are the FJ and GPZ.  The VTR1000F is worth a look too I think.
I thought you already determined the VF1000F/FII variants weren't right.
And damn, that #519 Race Bike is fucking cool!
On 2/14/2022 at 10:24 AM, Stray said:
Have you ever seen a thing more terrifying?
Took me all day to get the loom out. Bet it’ll take me a week of swearing to get it back in...
Left myself some notes on positioning with masking tape but they’re nothing close to comprehensive.
God, I hate wiring!
Also, the loom weighs a tonne. Got speaking to a guy who built his bike with a Motogadget Blue unit - this replaces all your wiring (except the ECU) with a tiny little gizmo that controls everything (lights, ignition, sensors etc). If it was guaranteed to work on the 5th gen I’d buy one but Motogadget can’t confirm. They did say it won’t work for HISS models though.
Do u really believe a gizmo exists that can replace a copper wiring loom?
I bet your motor runs on fairy dust instead of petrol.
Thanks for sticking with me, Captain. It’s agony trying to choose and I keep going back-and-forth on all the options. Can’t make my mind up and this must be driving you crazy!
Now I have your attention, and seeing you like the #519 VF500, how about this VF400 fairing (very similar to VF500 UK model), and with a VFR 1st gen tail (tail like the #1 2nd gen above but chopped down 3 inches - try to imagine the seat)?
With side fairings that will need “massaging” and the vent replaced…
And again with just the 1/4 fairing (I’d have to blend this into the tank somehow)…
I quickly threw an RC30 fairing from the loft on but radiator will need trimming to make it fit. Just for shits and giggles. But hard to picture it in place as the headlight bracket pushes the upper too high and the radiator pushes the lower too low. Side vent section would need massaging to match the frame angle better but I think there’s room for the high bars at full lock
Will try to post a better view of the RC30 in the next couple days when I get more time.
Thanks Gaz. Yes, Motogadget Unit Blue does just that. One single wire from the battery runs headlights, indicators, ignition, dash and accessories (horn, phone charger etc). No flasher or other relays required either - it’s all in the unit, which is smaller than a box of 20 cigarettes, has a built in alarm and headlight/tail light modulator options. Only the ECU and ignition wiring remains stock.
Unfortunately they can’t confirm it works on the 5th gen as it has fuel injection. It’s designed for carbed bikes.
Still working on the “fairy dust”. Trying to stay ahead of spiralling petrol prices…
I'm kinda diggin the VF500F2 front fairings.  Seems to "fit" decent.
I hate the fitment of white NC/RC fairing.  The angle is TERRIBLE and is what I make fun of when people try to use them on the wrong bikes.  The rear angles of the cowls need to match the angle of the frame or they look very "off". Just like the plane that the screen mounts to...   needs to be some what close the overall angle of the bike/tank.  Plus the angle of the headlights...   are we illuminating the tree tops? Those are made for below-the-triples clip ons.
THe VF400FII fairing and the 86 tail are a great match, I love it. I also agree with Captain, the twin headlight RC fairing is not right.
I agree with the Captain and Terry; the VF fairing looks perfectly matched for the handle bar arrangement and seems to fit the lines of the chassis well. Looking forward to seeing how it all works out in the end. 👍
Captain, is that #519 bike yours? It IS fucking cool!
Thanks for your thoughts, gentlemen. Looks like I’ll be following your advice. So a 1/4 fairing up front and the RC24 tail out back. Belly pan and some bodged radiator vents TBA. Here we go…
In the meanwhile, got my hands on a badly crashed Brembo 19RCS brake master cylinder to match the Nissin radial calipers on the front. Big risk as these aren’t supposed to be rebuildable…but they can…kind of.
Got a Brembo 19mm repair kit for another model and harvested the seals. The new piston, spring, spacer and plinth were all wrong.
Original piston and spring seemed reusable (I “stretched” the spring a bit before reinstall). I’m not sure pistons really wear out as the seals do all the work. Please correct me if wrong. Reassembled with silicone brake grease and tungsten disulphide in the pivot pin: moves nicely.
Brake lever was badly damaged and I was going to replace it but then saw the prices: OUCH! Time to try a repair with blowtorch, an old pair of motorcycle gloves and various other tools.
Before blowtorch:
After blowtorch:
Bleed nipple also ground down from crash. Snapped but luckily was able to remove it. New Ti one ordered.
Much swearing later and it’s passable. Needs sanding and paint to finish but will work fine for now.
Finished product (just needs sanding and paint on lever):
Just to add this took about 1.5 hours of messing about. Most of that was taken up looking for little parts I’d dropped amongst the detritus on the floor. Even the little ball detent for the 18-20 adjuster (try putting that back together without swearing!). Need to clean up the floor!
Yep.  😉 Thanks!
So I‘ve been wrestling with the chain guard and how I can make a smooth one without all the brake line holders on top (my brake line runs through the swingarm as per the mod on this forum, so the brake line channels are an eyesore).
This particular project failed but I’m including it here to:
1. show that in real life we sometimes lose a few battles but that doesn’t mean we will lose the war
2. plastic welding Polypropylene is possible but not nearly as easy as ABS
For the uninitiated, polypropylene is what our airbox, chain guard and speedo surrounds are made of. ABS is what our fairings are made of. If you wanted to modify your airbox this method will work. But it’s hard to make pretty so it didn’t work for this chain guard project.
First thought was to cut off the top of my 5th gen chain guard and replace it with the top off another bike. Got my hands on a selection of chainguards to experiment with. Below from top-to-bottom are VFR Crossrunner, 5th/6th gen and Honda CBR1100XX Blackbird. IMG_5568.thumb.jpeg.00b36c4f26aedad43ef75ede7c953756.jpeg
Architecturally the 5th, 6th and Crossrunner parts fit the same. But the flat top off the Blackbird is too narrow and short to work as the VFR piece is a bit wider than all my other bikes (probably due to the extra strength needed for the brake hoses running along the top).
Next thought was to cut the offending bits off the centre of the VFR guard and replace them with the smooth bits off the front of another VFR guard (brake hose stays are only in the middle of the VFR chainguard).
So bought a second VFR chainguard and got busy chopping/welding. 5th and 6th gen units are exactly the same.
Here’s the trial fit after quite a lot of fine grinding: cutting out the centre piece off chainguard A and slotting in the front part from chainguard B. Has a nice and smooth profile without any brake hose stays. Just what I wanted!
Soldering iron used to “tack weld” the two pieces together, strong enough to let me work on them later. You can see gaps where the front piece from guard B wasn’t quite long/big enough. No problem - we can fill these gaps with offcuts later.
Next, get yourself a nice stainless sieve and harvest the mesh for internal support.
Used the bigger soldering gun to heat the mesh and melt it into the plastic, forming a single part when it cools. With hindsight, I should have used much smaller bits of mesh as they are a heat sink and I really had to crank up the power on the solder gun. This, in turn, warped
the plastic somewhat.
Can get really smoky so do this in a well ventilated area and don’t breathe the fumes. Helps if you keep your head below the welding point.
Basically, the “welding” technique is to use strips of the parent material (cut from discarded pieces of chainguard), and melt them into the cracks with a soldering iron. A bit like welding in that you have to achieve decent penetration (not that kind of penetration!) and ensure both the filler material and the piece itself melt into each other properly. This is hard to do with Polypropylene, especially if all you have is a soldering iron pressed on the filler material. It’s also why the project failed (see further below).
Once the main bits are “welded” together, time to cut out some pieces and fill in any gaps. The pieces will be melted from the back onto the stainless mesh, and then all cracks welded with filler.
And we end up with something like this. Looking good and ready to finish off by grinding/filing/sanding down the “welds” to create a smooth surface.
Unfortunately, this is where it all falls down. The polypropylene didn’t melt uniformly into itself and there were granular bits in the welds. Sanding the welds down exposed these granular bits which came off in chunks, leaving ugly scars. Also, I had no idea how to grind/sand off the welds along the horizontal fold and keep them dead straight. Impossible to do by hand so I’ve abandoned the project on these grounds.
Having said that, if you ever needed to repair a polypropylene part or modify your airbox, this technique works a treat. Just not really good for pretty things in this case (not by hand anyway).
So I’m open to ideas for a smooth top chainguard if you have them. Otherwise I may have to bend one out of aluminium or something.
Back to the bodywork, and based on advice from here I’d settled on the VF400/500 front with the VFR750 RC24 tail. Nice slim design with a narrow tail to match. Makes the bike look smaller/lighter/faster. This is the sexy image I had in mind:
What I didn’t expect was a celebrity intervention that would derail my plans completely.
Incensed at my lack of skill and direction, none less than the legendary Mohawk himself came to the house and chastened me with a lecture on aerodynamics, rear seat drag and aesthetics. Very sternly, loudly and in person. There was much finger pointing and violent gesticulation!
As if not crushed enough, his missus then lectured me on cleanliness, organisation and the efficient use of garage space.
Feeling suitably chastened, I couldn’t possibly argue with any of it.
Mohawk has instructed me to build this: VF1000-F2 Bol d’Or front with MC21 tail piece.
And if Mohawk says it must be so, then so it shall be. Who am I to refuse!
It’s hard to visualise as the panels are different colours and not entirely in the right position. So here are some pics of the respective bits on other bikes for reference.
VF1000-F2 front with minor modifications (Check out the saddle on the first one!):
MC21 tail on a VF1000R:
Still planning to have side fairings and a belly pan. These will be bodged up after the front fairing and seat are situated. Side vents possibly from a CBR600RR and maybe a NACA duct thrown in for fun.
Let’s see how we get on…
  • Haha 2
He's hilarious 😂 Fantastic write up Spiros. Was great to see you again & visit anothers secret Skunk works garage to chew the fat. Thanks again for lunch. We look forwrd to regular updates 👍
Pep says keep that work space tidy 😂👍
So here is my electric water pump installed.
Second pic shows main coolant flow with Yellow arrows same on diagram.
Orange arrows show T-stat (Thermostat) circuit that allows heated coolant from head to be circulated by the water pump to the T-stat until warm enough to open the T-stat. Once T-stat opens main yellow flow takes over.
Diagram shows location of my 25mm to 11mm (IIRC) T-piece hose joiner in the lower rad return hose to allow T-stat to be retained with the electric pump which only has an inlet & outlet for the main flow. Not a perfect solution but it works.
Hope that all makes sense 👍
How about Skidmarx? https://skidmarx.co.uk/guards-huggers?q=Brand-Honda/Models-VFR800/products-Rear+Huggers
I have one on mine, it's a 2 piece design, they can make up the chain guard without the mounting holes if you don't want to use the fender - at least they were willing to do that 10 years ago when I got mine.
Thanks mate. When you explained it last time I just blinked at you without understanding. This really helps immensely!
By the way, this bike and I owe you a great debt, Mohawk. And there are 100’s of VFRs wearing mods you pioneered out there, alongside my own.
On 2/3/2024 at 6:36 PM, vfrcapn said:
How about Skidmarx?
Good shout vfrcapn, and thanks for explaining the 2 part bit. Will ring them next week.
Quick update on throttle body intake rubbers: looks like all 800 generations are the same.
VFR Crossrunner 800 on the left and old hardened 5th gen on the right. Even the locating tabs for clamps and engine intake are a match. Same internal and external dimensions too. I’d assume 6th gen would be the same?
The clamps are different though - new ones are better as they have hex head drive alongside the JIS Phillips.
Rubber intakes are also a decent match for the engine ports. Considering they are rubber items, there’s very little protrusion so flow looks smooth.
Finally, for anyone wondering if a front rad fits the 5th gen fairings, it does. I threw the fairings on quickly to show there’s ample room. But the vents are in the wrong place so you’d have to figure that out to keep your engine cool.
Looks nice with the MC21 tail. The RC24 front bit in blue isn’t necessary but you’d have to massage the front part of the MC21 seat fairing to blend with the tank. You COULD fit this on your stock subframe but you’ll have to cut the corners off the back and the fairing will leave the bottom rail exposed just above the footpegs and a bit under th seat hump. Cutting and rebelling would make a neater job.
Stock solo seat (cut off the pillion part) fits fine.
You’ll also have to fabricate brackets for the rear light and exhaust hanger, and an undertray (original will hang below the fairing near the tank).
Just in case anyone was planning to do theirs.
If you do some searching, there is a means to revamp those rubbers make them soft as new. I used engine oil on the inside of mine the first time I had the TB's off, every time since they have been easy to do & flexible 👍
Thanks Mohawk. Silicone oil is also good.
If anyone has really hard ones (behave!), I’ve personally had great success with a dunk in Salicylic Acid (AKA oil of wintergreen) and thinners at 50:50 mix.
Takes between couple hours and couple days depending on how far gone they are. I’ve revived truly ancient rubber parts this way. Even badly cracked stuff. Cart racers use it on their tyres to make them grippy. Can be used on old hard shoe soles too if you’re careful.
But at £20 it’s often easier to just pick up some nice condition ones off eBay.
It's odd that the rubber part would be the same, yet Honda changed the PCN shown on the edge from MBG to MCW.  Did you measure them?  My eye says the MCW is slightly narrower.   Normally, if there is no change, Honda would continue to use the old PCN.
JZH
Little update as I scored a Shindengen SH847AA regulator on eBay and fitted it to the 5th gen Donkey. It will help save the stator as these regulator rectifiers don’t get too hot, and only draw the required current (as opposed to shunt types that draw all the current all the time and convert any excess to heat).
If you’re looking to buy one, these are fitted to the big late model Suzuki VStrom (not the little 600’s). Anything after 2014.
Bought a Furukawa crimp and plug kit to match, as well as some heat shrink and terminals to do the job right. Wiring as per this image:
First step is to wire the new plugs. I used some high-amp cable from the shelf, which was slightly too thick but OK. Proper crimper also utilised.
For this mod you don’t use the charging connector anymore (black, green and red cables) and wire the regulator rectifier directly to battery instead. Just tape up the connector and forget about it. I used self amalgamating tape.
Then time to cut off the stator connector (3 x yellow cables) and wire it all up directly. You can see early signs of overheating and corrosion on the connector below.
Couldn’t get butt crimps that would connect two different gauge cables so I used a variation of the Western Union/Linesman Splice, followed by solder, a coating of dialectic grease and heat shrink.
Then more heat shrink over all three cables and a third round over the top of that. Nothing like a bit of over-engineering to give peace of mind and some strain relief to the joints.
Once the regulator’s location was decided, I chose to make an aluminium heat sink to soak away any excess heat generated. This isn’t strictly necessary as I’ve run this setup bolted directly to the subframe in the past with no ill effects (the SH847 doesn’t generate nearly as much heat as other regulator types) but it’s comforting to over-engineer.
First, trace the outline on a pice of scrap 5mm aluminium plate.
Then get busy with the hacksaw, grinder and flap disc. Cut-and-shut job is good enough for a part that will never really be seen.
Then, drill and tap some holes to mount the regulator and the plate. This took some thinking…
The m6 and little bolt below go through the INSIDE of the subframe and the bolt finishes flush with the plate so it doesn’t interfere with the regulator, which needs to lie flat against the plate.
All three holes now complete.
The empty one goes to the top, and bolts both regulator and heat sink plate using a new hole I drilled through the subframe side plate.
The muddle hole shows the small bolt that goes through the back of the subframe and holds the heatsink plate on. It’s fitted on the wrong side in the picture as you wouldn’t be able to see where it goes otherwise.
The bolt near my thumb holds the bottom of the regulator onto the heatsink. Bolt had to be cut shorter in the end to stop fouling against the subframe lower tube.
Below I’m pointing at the little bolt coming from the inside of the subframe to thread into the middle hole of the plate. Was a b!tch to fit, if I’m honest!
All mounted up, greased and sealed, with strain relief in the cables via zip ties.
All that work and barely visible with the seat off but at least the charging system is now sorted. This means the regulator won’t fry the stator, or overheat on track days (when there’s little electric draw due to headlights off and high charge rate due to high revs) or kill my
lithium Iron battery.
Now back to the race bike, I had to grind down the lip of the Ducati wheel nut socket. My socket had a chamfered edge that caused it to slip off the low-profile nut. The nut is only about 5mm wide and takes a HUGE amount of torque to fasten (almost 200nm!), so easy for the tool to slip off.
Before with chamfered edge…
After a clash with the angle grinder…
After a tickle with the flap disc…
So how do I rust-proof the polished edge? Answer: heat blueing.
Heated the edge to blue/purple. One edge got away from me and went to straw yellow, but that’s OK as it’s not hot enough to change the temper of the S2 steel (you need to go to cherry red for that!). And then dunk into some diesel oil to Parkerise the surface.
Here it is right out of the oil quench.
And again after a slick of copper grease. Lighting doesn’t show the blueing very well but it’s there, albeit dulled by the copper.
One more little win in the bag!
