Member Contributer BonusVFR Posted May 7, 2015 Member Contributer Share Posted May 7, 2015 In addition to my Electrical Connection idiot light voltmeter, I have been running a radar detector recently. One of the modes of the Redline is to show volts. Works great even direct sunlight.Seriously, you need all that stuff when out riding? That is my full tour kit. Most of it is handy when I am on big tour say in Canada. Although on short day rides out of the house I do take just the RD....seriously! Link to comment Share on other sites More sharing options...
Member Contributer HoganLongfellow Posted May 7, 2015 Member Contributer Share Posted May 7, 2015 I went with this one, simple install and works perfect! i mounted the controller under my fairing next to the fuse box its right under my windscreen, super easy to see Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted May 7, 2015 Member Contributer Share Posted May 7, 2015 Cool. Thanks! Was it tricky to cut the hole for it? That's the sort of thing I would screw up & then it would not look good at all. It was not too bad, but it didn't turn out perfect either. Just patience and an Xacto knife. If you screw up, a new replacement piece is much cheaper than an entire gauge surround. Does it create any problem if you need to take that small cover off to do something like change the shield? Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted May 23, 2015 Member Contributer Share Posted May 23, 2015 I'm hoping to get some advice with wiring a volt meter. This is the one I got. http://www.lascarelectronics.com/temperaturedatalogger.php?datalogger=116 My problem is the very small gauge the wires are that are on it. Not sure the actual gauge but they're the same as the phone wires in my old house. I'd say they're the smallest that wires come. I want to figure out a way of connecting them to the 16g wires that my bike is already wired with which are for the volt meter that I'm replacing. I'm thinking twisting them together & then soldering them but I have very little experience with soldering. It also came with a Transient Voltage Suppressor(TVS) which Lascar says should be used to protect the meter from voltage spikes when it is used in automotive applications. Would you use it? Not sure how I would connect that either. Link to comment Share on other sites More sharing options...
checksix Posted May 23, 2015 Share Posted May 23, 2015 I've got one of those. In fact I've had it for several years. The wires are very thin. Very dumb design. I wound up removing the back of the meter and soldering in new wire. I used several feet of model airplane servo wire so I could run it all the way back to the battery, complete with a servo connector on the end. It was a very delicate soldering operation, so I probably would not recommend it if you're not experienced with small electronics. Sorry, I guess that's not much help. Oh, be aware that it's not waterproof, so mount it in a place that won't be exposed to direct rain. Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted May 24, 2015 Member Contributer Share Posted May 24, 2015 Thanks checksix. My bike never sees rain so I'm not concerned about that. Link to comment Share on other sites More sharing options...
Member Contributer CHUCK2 Posted May 24, 2015 Member Contributer Share Posted May 24, 2015 I'm considering trying a Posi-Twist if I can find them locally. http://www.posi-products.com/twist2.html Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 24, 2015 Member Contributer Share Posted May 24, 2015 I used positwist for my SDC led volt meter Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted May 24, 2015 Member Contributer Share Posted May 24, 2015 I'm considering trying a Posi-Twist if I can find one locally. http://www.posi-products.com/twist2.html They're tough (if not impossible) to find at retailers. A local NAPA store has a limited selection of a knock-off brand in the most common types. I ordered from their website and am really happy with their products. I have a selection of them in various places on my 6th gen - they work great. Usually the smaller packages on their website have free shipping. Link to comment Share on other sites More sharing options...
Member Contributer wagzhp Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Those look interesting. I've never seen them before. Are they up to the abuse of motorcycle use? Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Posi-locks are certainly not better than a permanent solution (crimp, solder & glue-filled shrink wrap), but they will work in a pinch. Ciao, Link to comment Share on other sites More sharing options...
keny Posted May 25, 2015 Share Posted May 25, 2015 for all whit a analog one, I just like them. Sorry digital boys......yours are cool to, but analog just a tad more cool Link to comment Share on other sites More sharing options...
Member Contributer LangoPTC Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Here's mine on a 6th gen but since the install is based on a GPS Ram Mount attached to the tank it could be used for most any gen. Link to comment Share on other sites More sharing options...
VFROr Posted June 7, 2015 Share Posted June 7, 2015 Just ordered one of these, for $16 worth a look. http://www.batterytender.com/Accessories/Digital-Voltage-Indicator-with-LCD-Display.html Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 3, 2015 Member Contributer Share Posted July 3, 2015 Just ordered one of these, for $16 worth a look. http://www.batterytender.com/Accessories/Digital-Voltage-Indicator-with-LCD-Display.html REGISTER | LOG IN VIEW CART - 0 PRODUCTS Accessories Automotive Batteries Electric Vehicle Farm & Garden Industrial Marine Motorcycle RV Solar Telecom TECHNICAL INFO ABOUT US BT RACING MEDIA STORE LOCATOR CONTACT US This item is no longer available. Do you have a question? CALL US AT: 877.456.7901 or 386.736.7900 You got the last one . Roll On ... Link to comment Share on other sites More sharing options...
Member Contributer Africord Posted July 3, 2015 Member Contributer Share Posted July 3, 2015 I'm considering trying a Posi-Twist if I can find them locally. http://www.posi-products.com/twist2.html I bought mine here: http://www.webbikeworld.com/sale/posi-locks-for-sale.htm I'm still deciding where to put my Datel in my 6th gen. I like the idea of picking a smaller black section of plastic to mount the meter. Link to comment Share on other sites More sharing options...
VFROr Posted July 4, 2015 Share Posted July 4, 2015 Just ordered one of these, for $16 worth a look. http://www.batterytender.com/Accessories/Digital-Voltage-Indicator-with-LCD-Display.html You got the last one . Roll On ... It's kinda cool but I haven't gotten around to hooking it up on the 1200. They are available elsewhere if you wanted one. http://www.amazon.com/Battery-Tender-081-0157-Disconnect-Voltage/dp/B00DJ5KE9A Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 4, 2015 Member Contributer Share Posted July 4, 2015 Order one Thanks . Roll On .. Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted September 28, 2015 Member Contributer Share Posted September 28, 2015 Here's mine. Just installed it this weekend. More to this than meets the eye so I'll post on a separate thread as it includes installation of a PDM60 power module. Link to comment Share on other sites More sharing options...
30Bones Posted September 28, 2015 Share Posted September 28, 2015 I just installed this cheap unit. We shall see how long it lasts. I also have one of these and they were within 0.1V when riding/testing yesterday. So both are either spot on accurate or off by the same amount Link to comment Share on other sites More sharing options...
GigemVFR Posted September 28, 2015 Share Posted September 28, 2015 Anyone used this brand, Coromose? Looks like these pretty small and thin but no clue as to quality. http://www.amazon.com/Coromose-12V-24V-Motorcycle-Voltmeter-Waterproof/dp/B00S7FUT10 Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted September 28, 2015 Member Contributer Share Posted September 28, 2015 Here's mine. Just installed it this weekend. More to this than meets the eye so I'll post on a separate thread as it includes installation of a PDM60 power module. That's a handsome looking meter. A friend of mine just installed the gauge from the link below on his Gold Wing and it looks cool too. http://www.ebay.com/itm/2-52mm-Digital-20-LED-Elec-Volt-Voltmeter-Voltage-Gauge-Meter-For-Car-Motor-SL-/221355919663?hash=item3389d7492f&vxp=mtr Link to comment Share on other sites More sharing options...
Member Contributer tbzep Posted September 28, 2015 Member Contributer Share Posted September 28, 2015 I didn't want any holes, so I went with this Koso and a little velcro. Wire has since been tucked away. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted September 29, 2015 Member Contributer Share Posted September 29, 2015 I didn't want any holes, so I went with this Koso and a little velcro. Wire has since been tucked away. That looks great. It's also prominent and easy to read. Link to comment Share on other sites More sharing options...
number9 Posted September 29, 2015 Share Posted September 29, 2015 I also have one of these and they were within 0.1V when riding/testing yesterday. So both are either spot on accurate or off by the same amount I have one of those and really like it. Link to comment Share on other sites More sharing options...
