Veefer800Canuck Posted May 20, 2008 Posted May 20, 2008 BLS, those triples are things of beauty & grace. I second that opinion. Another fun material to machine is titanium -- drills and endmills love titanium. If magnesium is not coated, yes, it eats away over time from the elements. I have certainly noticed this on the unpainted areas of my front wheel. IIRC, Larry has his triples coated in something space-age, let me see if I can dig that up....... ...................................... Nah, couldn't find it, hafta ask Larry. Quote
Member Contributer canib Posted May 20, 2008 Member Contributer Posted May 20, 2008 What's the easiest way to get super bike bars? Would I need home made upper tripples for that? Is there a kit or something already out there? Quote
cassandtim Posted May 20, 2008 Author Posted May 20, 2008 Spiegler USA offers the LSL superbike kit for VFR's with stock front ends. http://www.spieglerusa.com/cfm/sbk.cfm Quote
cassandtim Posted May 20, 2008 Author Posted May 20, 2008 Oh, and BTW, my 7075 material is in and my machinist says we're cued up to begin this weekend. If all goes well I will post up photos of the finished product early next week! Woot! Quote
Member Contributer BusyLittleShop Posted May 23, 2008 Member Contributer Posted May 23, 2008 BLS, those triples are things of beauty & grace. Did you make those on a conventional Bridgeport type mill? Thanks... like everything I machine at the Busy Little Shop they were done by hand eye coordination on a Taiwan copy of a conventional Bridgeport mill... Quote
Member Contributer BusyLittleShop Posted May 23, 2008 Member Contributer Posted May 23, 2008 Admittedly in my engineering travels I have not had the opportunity to play with magnesium. But doesnt that material degrade over time? (years) Kinda why the major mfrs avoid it for structual parts?I'm thinking 2024 is a strong candidate..... MD Magnesium resistance to weather exposure is good in rural or inland atmospheres... color will change to dark gray if unprotected... parts may be treated in Dow 7 giving magnesium the characteristic chocolate brown color so many motorcycle parts are painted to resemble... Dow #7 is dichromate treatment... My triple clamps were treated to MIL process which is a chrome pickle treatment for magnesium. Color may vary from matte gray to yellow-red... Quote
cassandtim Posted July 22, 2008 Author Posted July 22, 2008 No longer made out of "Unobtanium". The real deal just back from the CNC machinist. I popped the stem in moments ago using the old oven/freezer trick (mucho thanks to Busy Little Shop :blink: ) Thoughts? Triple Clamp Assy 072108.jpg Here's a view of the two different size risers I had made (7mm & 17mm): Risers 072108.jpg The view of the bottom of the bottom clamp (massive): Bottom Triple 072108.jpg And finally, a view of the bottom of the top clamp: Top Triple 072108.jpg They're off to the anodizer tomorrow. With any luck I'll have the bike back together for the Kootenay Hootenanny PNWVFRD Meet '08 in August. Woot!!! Quote
Member Contributer redmarque Posted July 22, 2008 Member Contributer Posted July 22, 2008 Wow! those are awesome! :fing02: :blink: :dry: Quote
Darth Bling Posted July 22, 2008 Posted July 22, 2008 Thoughts? Triple Clamp Assy 072108.jpg Yeah, you could of at least picked up the place before you took pictures of your filthy floor... :blink: Quote
cassandtim Posted July 22, 2008 Author Posted July 22, 2008 Dude, you're killin' me! "No beer for you!" I forgot to mention that the machinist made one small mistake when tapping the holes in the top clamp for the bar clamp mounts. He tapped the hole with an M10x1.25 instead of the standard M10x1.5. I panicked when I couldn't find any stainless socket head capped bolts in that thread at Mcmaster-Carr. When I googled the thread size the first place that came up was Yoyodyne and their vast supply of titanium bolts. Ugghh. I then had the dilema of purchasing the two bolts that I depserately needed for the bar mounts and use stainless for the rest or go "whole hog". Well, $220 bucks later I'm in it for the win! I sure hope to hell this whole thing turns out ok. Quote
Member Contributer trav72 Posted July 22, 2008 Member Contributer Posted July 22, 2008 Wow! That's some very nice machining! I'll take a set! :blink: Quote
JAM Posted July 22, 2008 Posted July 22, 2008 As for the bolts, could you have bought the stainless socket heads extra long and not fully threaded and then single point threaded them or used a die on a lathe? Basically cut off the non usable threads and cut new threads? Nice job on the clamps, now onto the 5th generation. Quote
cassandtim Posted July 22, 2008 Author Posted July 22, 2008 That's a great idea that I never thought of. This kind of gave me the excuse to buy the titanium hardware. I had said to Magellan and Darth Bling earlier in this project that I would buy the exotic stuff if I didn't have to pay more than $100 for it so the necessity/opportunity more-or-less pushed me over the edge. I am, however, concerned about potential galling between the 7075 and the titanium. I have some Vibratite thread patching compound that clearly states that it minimizes galling/stripping. I hope that I don't have too much to worry about. I believe that these would work on 5th Gens. That is, if it works on my 6th Gen after bolt up. Quote
Member Contributer Silver#788 Posted July 22, 2008 Member Contributer Posted July 22, 2008 Looking good Tim Quote
Member Contributer magellan Posted July 22, 2008 Member Contributer Posted July 22, 2008 I am, however, concerned about potential galling between the 7075 and the titanium. I have some Vibratite thread patching compound that clearly states that it minimizes galling/stripping. I hope that I don't have too much to worry about.I believe that these would work on 5th Gens. That is, if it works on my 6th Gen after bolt up. Yes, these are direct bolt-ons for a 5th gen, as long as you're installing RC51 (or same diameter) forks. As far as galling, it'll never happen as long as you use anti-seize or Vibratite. These parts will never experience widely ranging heating and cooling cycles which cause dissimilar alloys to gall when in contact with one another. Beautiful parts, proud papa! :biggrin: Can't wait to see it all installed! Quote
Member Contributer dude Posted July 22, 2008 Member Contributer Posted July 22, 2008 Wow that looks superb. Nice work Tim :biggrin: Quote
mello dude Posted July 22, 2008 Posted July 22, 2008 (edited) WOW! WOW! Totally cool! Stem questions - so did you make a stem from steel alloy or is it Honda part? What is the oven/freezer trick? (I can make a guess, but it doesnt hurt to ask.) Again beautifull! MD Edited July 22, 2008 by mello dude Quote
JAM Posted July 22, 2008 Posted July 22, 2008 I love titanium, but would for my project have used steel in the clamping area, stainless or a chromed stee. That being that under failure the ti bolt would fracture, and the steel would stretch. I wouldn't worry about the galling, based on my experience that disimiliar metals are more unlikely to do so. If you are going to apply any material to the threading section, torquing the titanium bolts might not be accurate. Most torque standards that I know of are dry states. Are you going to clear anodize and if you are going to color it, are you going for a UV stabilized color? Quote
Member Contributer BusyLittleShop Posted July 22, 2008 Member Contributer Posted July 22, 2008 No longer made out of "Unobtanium".The real deal just back from the CNC machinist. I popped the stem in moments ago using the old oven/freezer trick (mucho thanks to Busy Little Shop :biggrin: ) Thoughts? You're welcome Tim... the clamps look the biz... 40mm offset is very important because it preserves the VFR quick handling rate whereas the stock RC51 offset doesn't... the only the thought that comes to mind is to gull the top clamp like the bottom in order preserver the VFR's front end height and in addition there might be enough room to hang a clip on... If you weight them post the number so I may advise prospective customers... Quote
Member Contributer Kel Posted July 22, 2008 Member Contributer Posted July 22, 2008 I had to use a gull set up for my R to keep the stock stance and allow me to use RC51 bars above the triple. I love that lower! Could use it on my bike! upper Quote
Member Contributer BusyLittleShop Posted July 22, 2008 Member Contributer Posted July 22, 2008 So is this your work then, Larry? This Tim's work with the help of a local CNC shop... Quote
cassandtim Posted July 23, 2008 Author Posted July 23, 2008 Stem questions - so did you make a stem from steel alloy or is it Honda part? What is the oven/freezer trick?(I can make a guess, but it doesnt hurt to ask.) I used the stock RC51 (SP1) steering stem. I do intend on modelling the stem as I would like to have one machined that uses the internal thread style top bolt similar to the Aprillia and Ducati stems. Because the stem and lower clamp use a force fit (0.002") I put the clamp in the oven at 300º for 35 mins and the stem in the freezer overnight. I put a little marvels mystery oil on the stem as well per Larry's advice and they went together with a tap from a dead-blow hammer and hardwood dowel. You're welcome Tim... the clamps look the biz... 40mm offset is very important because it preserves the VFR quick handling rate whereas the stock RC51 offset doesn't... the only the thought that comes to mind is to gull the top clamp like the bottom in order preserver the VFR's front end height and in addition there might be enough room to hang a clip on... If you weight them post the number so I may advise prospective customers... Because I'm going the "Superbike Bar" style setup there's no need for clip-ons. I did do the measurements on fork length differences and it came out (measured from center of axle to top of fork): Stock = 772mm RC51 (SP1) = 759mm Stock fork is supposed to be set 41mm from top of top clamp to top of fork (per Honda service manual) So I should have 28mm of fork tube above the top clamp when done. I have pondered modelling a set of gullwings in case somebody would rather go with clip-ons. It's all about finding the time. I will weigh these after I get them back from the anodizer but I suspect that with the bar clamps and associated hardware they will weigh a little more than the stock RC51 triples. I am hoping that I might be able to offer up the .DXF files after I verify that everything works well on my bike so that others can do this same conversion. I have discovered through this whole process that "where there's a will, there's a way" and it's not as tough as initially thought. Quote
