smoothsailin Posted April 22, 2013 Share Posted April 22, 2013 Need any parts? There's a clean-looking '86 Mini-ceptor with extra parts advertised for sale on the local CL just south of you in Richmond. http://richmond.craigslist.org/mcy/3758088922.html If I didn't already have too many two- and four-wheeled vehicles I'd be tempted to check this one out... Link to comment Share on other sites More sharing options...
Member Contributer Burns Posted April 22, 2013 Member Contributer Share Posted April 22, 2013 will be there Sunday, Sir. crowbar and beer in-hand. Tmac MUST happen. Link to comment Share on other sites More sharing options...
SEBSPEED Posted April 23, 2013 Share Posted April 23, 2013 Team Honey Badger for the win! Link to comment Share on other sites More sharing options...
timmythecop Posted April 25, 2013 Author Share Posted April 25, 2013 All Balls tapered rollers arrived today. I'll sort that and take a look at the carbs soon. I havent given up, but I needed a break from only sleeping, working and VF500-ing, because that is all I have done for a month. It feels incredibly light when you wheel it around, so that is a slight positive............. Link to comment Share on other sites More sharing options...
SEBSPEED Posted April 25, 2013 Share Posted April 25, 2013 I have a box of tissues I could send your way nancy. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted April 25, 2013 Member Contributer Share Posted April 25, 2013 I have a finished project in the garage that will make it's way out. I'll even fix that paintjob. Those wheels just add too much color to the whole thing Link to comment Share on other sites More sharing options...
timmythecop Posted April 26, 2013 Author Share Posted April 26, 2013 2 of the carbs picked up some cack and prevented fuel flow. (Had nothing to do with my folger's coffee can tank, I assure you). Carbs got a visit to the bench and all seems well now. I will prolly wait till Burns gets here to do the head bearings, because I can potentially trick him into doing the entire job before he realizes it is finished. No time until saturday anyway because it is shift, 8 hours of M16 re qualifying, 4 hours rest, another shift, 4 hours sleep, then alarm clock bringing me back into the shed. I have decided to sell the Seca, because by all rights, its place should be occupied by a V4. Looking for a Sabre to use as a commuter now......... Link to comment Share on other sites More sharing options...
SEBSPEED Posted April 26, 2013 Share Posted April 26, 2013 I wish I could get paid to spend 8hrs at the range!! Lucky you!! Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 A sabre huh? How about a magna Link to comment Share on other sites More sharing options...
timmythecop Posted April 26, 2013 Author Share Posted April 26, 2013 I wish I could get paid to spend 8hrs at the range!! Lucky you!! about 1000 rounds of .223 (or 556 if you are Jeremy) Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 does the .223 that you "have" to shoot for work have two positions on the fire selector switch or three? 'cause I can burn through 1,000 rounds pretty quick if your weapon goes all the way to three... Link to comment Share on other sites More sharing options...
timmythecop Posted April 26, 2013 Author Share Posted April 26, 2013 no, although it is an M16A1, it has been altered and no matter how hard I push, the selector wont go to "fun" We are also required to call it an "Accessory Lug" Heaven forbid one should utter the word "bayonette" Link to comment Share on other sites More sharing options...
Member Contributer InvisibleCities Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 2 of the carbs picked up some cack and prevented fuel flow. (Had nothing to do with my folger's coffee can tank, I assure you). Carbs got a visit to the bench and all seems well now. Way to stick with it! If I could suggest - not sure if you have done this yet - give a go at checking the valve lash. Side note, you will need to re-sync the carbs, using a manometer, after this is done. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 2 of the carbs picked up some cack and prevented fuel flow. (Had nothing to do with my folger's coffee can tank, I assure you). Carbs got a visit to the bench and all seems well now. Way to stick with it! If I could suggest - not sure if you have done this yet - give a go at checking the valve lash. Side note, you will need to re-sync the carbs, using a manometer, after this is done. Definitely do this ASAP. When I did it on the magna motor, a bunch of the valves were so far out that I called a friend to make sure I wasn't doing something wrong. It's kind of easy to adjust once you get the hang of it, since it moves a little bit when you're tightening it down. Link to comment Share on other sites More sharing options...
Member Contributer InvisibleCities Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 Two feeler gauges and the Factory tools make for an easier go of it. For ref: Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 Found y Found you one local. Link to comment Share on other sites More sharing options...
Member Contributer y2kvfr Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 no, although it is an M16A1, it has been altered and no matter how hard I push, the selector wont go to "fun" We are also required to call it an "Accessory Lug" Heaven forbid one should utter the word "bayonette" Accessories available: 1, bayonet, lug mounted. Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 Bayonette splattered with red paint = Best crowd control. Carry on. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted April 26, 2013 Share Posted April 26, 2013 Ahem, veering abruptly back on topic: Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted April 26, 2013 Member Contributer Share Posted April 26, 2013 Ahem, veering abruptly back on topic: Used to think it would be cool to own one when they are new and most conspicuous in Japan...still not a fan of the inbord discs on this or the early VTR250s Link to comment Share on other sites More sharing options...
timmythecop Posted April 27, 2013 Author Share Posted April 27, 2013 a lil test Link to comment Share on other sites More sharing options...
PFox Posted April 27, 2013 Share Posted April 27, 2013 That's pretty awesome. Sounds like a much bigger bike, especially when starting it up. Link to comment Share on other sites More sharing options...
Member Contributer InvisibleCities Posted April 27, 2013 Member Contributer Share Posted April 27, 2013 Way to go! Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted April 27, 2013 Share Posted April 27, 2013 Nice, I could almost hear the theme song playing in my head. Link to comment Share on other sites More sharing options...
timmythecop Posted April 27, 2013 Author Share Posted April 27, 2013 for the CHiPs soundtrack, one should be watching this one Link to comment Share on other sites More sharing options...
