Dazdiablo Posted October 12, 2023 Posted October 12, 2023 16 hours ago, boOZZIE said: Have you seen page 1 at the top yes I have. The jig is defo easily replicated, it's the completed set that I'd need to be able to measure and replicate the angles, I'd probable make one out of cold rolled just to get a feel for the compound bends and angles in each piece of tube then make one out of stainless or whatever material is required/desired. Quote
Member Contributer RC51Nick Posted October 19, 2023 Member Contributer Posted October 19, 2023 So sad to hear about sfdownhill. I never met him but we had several conversations concerning Rapid Bike and the VFR headers. All my dealings with him were top notch. He will be missed 1 Quote
V4Runner Posted October 21, 2023 Posted October 21, 2023 Good Day, I'm a new arrival to the vfr forum (i made an account just to post in this thread) and just absolutely gutted hearing about this tragic news 😞 (I've been observing in passing the past couple of months as I want to get a set of these headers for a winter build as the quality looks top notch & the collector design compared to some of the limited options out there! {is there any video or sound clips of this set-up?} ). I've been trying to catch up on the 65 pages to see if there are any left for the taking /a new wish list is being filled or did I show up too late with the given unfortunate circumstances? (in search of : a set of these for a 99 5th gen vfr, no preference on high or low set-up) Kind regards. Quote
Member Contributer interceptor69 Posted October 22, 2023 Member Contributer Posted October 22, 2023 20230708_083305.mp4 Sound quality is not great and the sound will depend on pipe used-this is a Vance & Hines Ti pipe. Mine is a '98. Quote
Member Contributer vfrcapn Posted November 13, 2023 Member Contributer Posted November 13, 2023 I have a new 8th gen set for sale in the classifieds. 10% goes back to VFRD. edit: no longer available as of March '24. Quote
Member Contributer JZH Posted November 13, 2023 Member Contributer Posted November 13, 2023 7 hours ago, vfrcapn said: I have a new 8th gen set for sale in the classifieds. 10% goes back to VFRD. On the VERY off-chance someone in the UK or EU wants a 5th-gen version, I have an unfitted one I just received from the most recent production run, and I would be happy to swap it for an 8th-gen version (to facilitate a center radiator). Cheers, JZH 1 Quote
Morados Posted March 22, 2024 Posted March 22, 2024 I am looking for a Gen 8 performance TBR Replica header if someone is willing to part with it Quote
Member Contributer RC51Nick Posted April 21, 2024 Member Contributer Posted April 21, 2024 Question for those who have installed the new header on their 6th gen. How do you handle the heatshield attached to the R/S rearset. Did you remove the shield with those hard to get nuts on the back of it and move the rearset out of the way? Did you brake the break system and remove the whole rearset/shield assembly. I know it has to be removed to get to the rear header and clamp boltts. I'm finally getting around to installing my header after a hip replacement this winter. Any help would be appreciated. I' really dont want to brake open the brake system with stories I've heard about trying to bleed a linked brake system. Thanks, Nick Quote
Member Contributer ducnut Posted April 29, 2024 Member Contributer Posted April 29, 2024 On 4/21/2024 at 6:37 PM, RC51Nick said: Question for those who have installed the new header on their 6th gen. How do you handle the heatshield attached to the R/S rearset. Did you remove the shield with those hard to get nuts on the back of it and move the rearset out of the way? Did you brake the break system and remove the whole rearset/shield assembly. I know it has to be removed to get to the rear header and clamp boltts. I'm finally getting around to installing my header after a hip replacement this winter. Any help would be appreciated. I' really dont want to brake open the brake system with stories I've heard about trying to bleed a linked brake system. Thanks, Nick Since no one has responded, I’ll give my 2¢. When I tore down my 5th Gen, that heatshield and everything Honda has jammed into that space was a right PITA. The 6th Gen is a bit different, but, you still have to get all that out of the way. I'd strongly suggest you buy OEM Honda replacement studs and nuts and replace the original bits. This way, you’ll have no issues. Don’t be afraid of the braking system. Doing so will be at your peril. People avoid servicing the hydraulics on these bikes, because of the unknown. It’s the worst thing you can do, because the system will eventually fail, altogether. At that point, you’ll be chasing gremlins and searching for used replacement parts. You’re better off to be preventive. Just buy a vacuum bleeder and follow the service manual’s bleeding procedures and you’ll have no problems. Quote
Member Contributer Duc2V4 Posted April 29, 2024 Member Contributer Posted April 29, 2024 On 4/21/2024 at 4:37 PM, RC51Nick said: Question for those who have installed the new header on their 6th gen. How do you handle the heatshield attached to the R/S rearset. Did you remove the shield with those hard to get nuts on the back of it and move the rearset out of the way? Did you brake the break system and remove the whole rearset/shield assembly. I know it has to be removed to get to the rear header and clamp boltts. I'm finally getting around to installing my header after a hip replacement this winter. Any help would be appreciated. I' really dont want to brake open the brake system with stories I've heard about trying to bleed a linked brake system. Thanks, Nick For some reason I did not see your post, so my apologies. It has been a while since I did the original install and even when I swapped out the 6 Gen motor with a 5 gen motor. But looking at the bike just now I recall that I actually pulled of the rear set so I could get better access to the heat shield bolts. The one difference between the 5 and 6 Gen rear braking setup, the 5 Gen has a hard line the rear master cylinder, where the 6 Gen only has a standard brake line, so it's a just a little easier to move out of the way. 1 Quote
Member Contributer boOZZIE Posted April 30, 2024 Member Contributer Posted April 30, 2024 On 4/22/2024 at 9:37 AM, RC51Nick said: Question for those who have installed the new header on their 6th gen. How do you handle the heatshield attached to the R/S rearset. Did you remove the shield with those hard to get nuts on the back of it and move the rearset out of the way? Did you brake the break system and remove the whole rearset/shield assembly. I know it has to be removed to get to the rear header and clamp boltts. I'm finally getting around to installing my header after a hip replacement this winter. Any help would be appreciated. I' really dont want to brake open the brake system with stories I've heard about trying to bleed a linked brake system. Thanks, Nick No need to brake anything 😀 From memory, remove the rearset and then remove the heat shield and hang the rearset/brake with a zip tie or something. Have fun with those exhaust nuts they're SOB. You'll need a swivel joint and some extensions 2 Quote
Member Contributer RC51Nick Posted April 30, 2024 Member Contributer Posted April 30, 2024 11 hours ago, boOZZIE said: No need to brake anything 😀 From memory, remove the rearset and then remove the heat shield and hang the rearset/brake with a zip tie or something. Have fun with those exhaust nuts they're SOB. You'll need a swivel joint and some extensions Thanks for the replies guys.... I ended doing what boOZZIE recommended. The exhaust nut actually came off really easy. The left rear was the toughest to get to but with swivels and long extension it was a piece of cake. Now to get my staintune mid pipe expanded to fit over the header outlet and I can put everything back together. Nick 3 Quote
Member Contributer ducnut Posted May 2, 2024 Member Contributer Posted May 2, 2024 On 4/30/2024 at 2:15 PM, RC51Nick said: Now to get my staintune mid pipe expanded to fit over the header outlet and I can put everything back together. Be extremely careful with the expanding. I took my header and Staintune to an OG exhaust dude, who gently expanded, rotated, gently expanded, rotated, etc. He probably spent 20 minutes on it, for fear of splitting it. 1 Quote
Member Contributer RC51Nick Posted May 2, 2024 Member Contributer Posted May 2, 2024 52 minutes ago, ducnut said: Be extremely careful with the expanding. I took my header and Staintune to an OG exhaust dude, who gently expanded, rotated, gently expanded, rotated, etc. He probably spent 20 minutes on it, for fear of splitting it. I def plan on taking it to someone who can take their time on it. Don't want to split the pipe you cant get anymore. 1 Quote
Member Contributer flya750 Posted May 2, 2024 Member Contributer Posted May 2, 2024 On 5/1/2024 at 10:44 PM, RC51Nick said: I def plan on taking it to someone who can take their time on it. Don't want to split the pipe you cant get anymore. I had a muffler shop do mine and he split it, I found a good welder and he fixed it up perfect! 1 Quote
Member Contributer interceptor69 Posted May 3, 2024 Member Contributer Posted May 3, 2024 I have the opposite problem-I need the pipe from the Two Brothers can I got 2nd hand expanded to fit the outlet of the new headers, as they are the exact same diameter. I'm worried that will split and I know I can't get another one of those... Quote
Member Contributer Duc2V4 Posted May 3, 2024 Member Contributer Posted May 3, 2024 46 minutes ago, interceptor69 said: I have the opposite problem-I need the pipe from the Two Brothers can I got 2nd hand expanded to fit the outlet of the new headers, as they are the exact same diameter. I'm worried that will split and I know I can't get another one of those... I took my 2Bros slip on link pipe along with our headers to a local muffler shop. He had it done in less than 10 minutes, handed him $10 cash and was on my way. It was completely uneventful. Quote
Member Contributer interceptor69 Posted May 3, 2024 Member Contributer Posted May 3, 2024 8 hours ago, Duc2V4 said: I took my 2Bros slip on link pipe along with our headers to a local muffler shop. He had it done in less than 10 minutes, handed him $10 cash and was on my way. It was completely uneventful. hope I'm as successful. Have no clue who to take it to. Also the headers are on the bike so can't take them with. Quote
Member Contributer RC51Nick Posted May 5, 2024 Member Contributer Posted May 5, 2024 On 5/2/2024 at 11:52 PM, Duc2V4 said: I took my 2Bros slip on link pipe along with our headers to a local muffler shop. He had it done in less than 10 minutes, handed him $10 cash and was on my way. It was completely uneventful. I got lucky with a customshop about a half hour from my house. Expanded the Staintune mid pipe and no cradks. fits the header perfectly. Need to get a bigger clamp tho from Staintune but hopefully that wont be a problem. I do have a couple of questions. What's the distance between the inside edges of the spring clamps on the rear header pipe to the rear head pipes. Not sure if I have mine seated fully. also before tightening everything up the header is up against the swingarm. Anyone else have issues with this or when I tighten the pips to the head the header should move away from the swingarm. Sorry about all the questions but I'm assuming I'm one of thel ast ones to install their pipe from the last run. Nick Quote
Member Contributer ducnut Posted May 5, 2024 Member Contributer Posted May 5, 2024 On 5/4/2024 at 10:17 PM, RC51Nick said: I got lucky with a customshop about a half hour from my house. Expanded the Staintune mid pipe and no cradks. fits the header perfectly. Need to get a bigger clamp tho from Staintune but hopefully that wont be a problem. I do have a couple of questions. What's the distance between the inside edges of the spring clamps on the rear header pipe to the rear head pipes. Not sure if I have mine seated fully. also before tightening everything up the header is up against the swingarm. Anyone else have issues with this or when I tighten the pips to the head the header should move away from the swingarm. Sorry about all the questions but I'm assuming I'm one of thel ast ones to install their pipe from the last run. Nick Don’t bother with Staintune. I used a FiveStar Mfg barrel clamp. WD40 liberally applied to the slip joint. You should know to never try and insert anything dry. The header shouldn’t be up against the swingarm. Quote
Member Contributer RC51Nick Posted May 6, 2024 Member Contributer Posted May 6, 2024 On 5/5/2024 at 1:22 AM, ducnut said: Don’t bother with Staintune. I used a FiveStar Mfg barrel clamp. WD40 liberally applied to the slip joint. You should know to never try and insert anything dry. The header shouldn’t be up against the swingarm. You WD-40 did the trick. Everything slipped into place the correct amount. When everything ist tightened up I have between 1/8 and 1/4" clearance to the swingarm. I hope that is about what everyone else is getting. Nick 1 Quote
Bananaorama Posted May 7, 2024 Posted May 7, 2024 Horrible to hear the creator of this project passed away! He did a great service to this community! Sadly after many life events I am late to the group buy for this header purchase as I was to the rapidbike group buy...Possibly one may pop upon the classifieds one of these days but for now it looks like lextek is the next best go to with... 4 Quote
Member Contributer RC51Nick Posted May 12, 2024 Member Contributer Posted May 12, 2024 This freaking exhaust. Did anyone who got the last batch of headers here have any major install problems. I'm not an idiot with a wrench and this isnt my first aftermarket exhaust install but jeezus. I'm back to square one... I was tightening up the front 2 pipes and before they hit 12NM per the manual the studs and flanges started bending and the tubes didnt look square in the ports. The process I followed initially was I installed the rear 2 pipes loosely, and then routed the header and after pplying wd40 got the rear pipes to slip down fully into the header. Went to install the front pipes and had the same issue with width as some others had but also they looked to be somewhat short to the ports. Had a had time getting them around the studs to seat into the ports. Started tightening up the front ports and thats where the bending started. Very frustrated. So right now I pulled everything back off and replaced all 4 of the front exhaust studs. Any words of wisdom before I start this again. I know laying the oem rear pipes up against the header pipes and the shorter of the 2 pipes looks alot shorter than the oem pipe. Dont know if they were supposed to be or not. Almost to the point of wanting to go back stock but I already expanded my Staintune midpipe. Quote
Member Contributer ducnut Posted May 12, 2024 Member Contributer Posted May 12, 2024 1 hour ago, RC51Nick said: This freaking exhaust. Did anyone who got the last batch of headers here have any major install problems. I'm not an idiot with a wrench and this isnt my first aftermarket exhaust install but jeezus. I'm back to square one... I was tightening up the front 2 pipes and before they hit 12NM per the manual the studs and flanges started bending and the tubes didnt look square in the ports. The process I followed initially was I installed the rear 2 pipes loosely, and then routed the header and after pplying wd40 got the rear pipes to slip down fully into the header. Went to install the front pipes and had the same issue with width as some others had but also they looked to be somewhat short to the ports. Had a had time getting them around the studs to seat into the ports. Started tightening up the front ports and thats where the bending started. Very frustrated. So right now I pulled everything back off and replaced all 4 of the front exhaust studs. Any words of wisdom before I start this again. I know laying the oem rear pipes up against the header pipes and the shorter of the 2 pipes looks alot shorter than the oem pipe. Dont know if they were supposed to be or not. Almost to the point of wanting to go back stock but I already expanded my Staintune midpipe. Unslip the slip joints a bit and get everything loose and floating. You’ll need to work your way around to each exhaust port, tightening a bit at a time. I don’t mean tightening the pipe all the way in; just equally moving each head pipe in, by using the nuts. While doing that, keep working the slip joint, incrementally moving it together. The gist is to equally move everything into place, until the headpipes are seated. I didn’t use a torque wrench and I’d suggest you don’t either. The studs are quite small and it doesn’t take much to damage them, strip them, or even pull a stud out of the head. Using just your hand, you can better feel when something is not right. The main thing is to just take your time and equally ease everything into place. Quote
Member Contributer IanSummers Posted May 18, 2024 Member Contributer Posted May 18, 2024 Hello everyone (I'm new here). I just bought a set of these headers off of capnspiff for my new-to-me 8th gen. I am looking to buy the attack map for the 8th gen. I sent an email to vfrheaders@gmail.com about it. I read about the unfortunate passing of the gentleman who was running that e-mail account. If anyone has taken it over for him, I am happy to pay for the map. We will see if I hear back. If I don't end up hearing back, does anyone here have the map? If so I'd be happy to make a $50 donation to the forum or send the funds somewhere else appropriate. Thanks, Ian Quote
