VENGER Posted July 31, 2014 Share Posted July 31, 2014 I've been hearing a lot about e85 and other alcohol based fuels and was wondering if Anyone knew if the 6th gen can run on other fuel sources? Would the fuel system handle e85 or would there have to be a few or a lot of things changes? I'm curious because i've haven't heard of anyone bringing this up on motorcycles but it seems to be coming up more with car discussions. I wouldn't mind using e85 and it would be kinda cool to see what kind of power gains it would get and how fuel economy would be affected. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted July 31, 2014 Member Contributer Share Posted July 31, 2014 Silly me filled up my 4th gen (carbs) with e85 once.... The engine ran like shit, stumble, poor pickup. Maybe a fi engine will fare better. http://www.vfrdiscussion.com/forum/index.php/topic/75532-apology-to-my-bike/?p=906601 There will be no power gain and your fuel economy will be less Link to comment Share on other sites More sharing options...
Lint Posted July 31, 2014 Share Posted July 31, 2014 Our engines cannot tolerate anything more than E10, even says so in the owner's manual. It would require a lot of changes to run E85, like a lot higher compression, for one and most likely different injectors, pump and fuel lines and possibly even different rings. Link to comment Share on other sites More sharing options...
VENGER Posted July 31, 2014 Author Share Posted July 31, 2014 I was having discussion with a fews buddies of mine and some where saying yes and some were saying no. One said that you would have to change all the hoses, seals, rubbers, run different oil and change the air fuel mixture. Also said with a proper tune you could get more power out of it than regular gas. Another simply said no it would ruin the engine. Link to comment Share on other sites More sharing options...
TNRabbit Posted July 31, 2014 Share Posted July 31, 2014 Adding alcohol to fuel was the worst idea the government ever came up with. ....OK, maybe not the WORST, but you get my drift... Link to comment Share on other sites More sharing options...
V4 Rosso Posted July 31, 2014 Share Posted July 31, 2014 to what Lint wrote. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 31, 2014 Member Contributer Share Posted July 31, 2014 Silly me filled up my 4th gen (carbs) with e85 once.... The engine ran like shit, stumble, poor pickup. Maybe a fi engine will fare better. There will be no power gain and your fuel economy will be less Moonshine ? Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted July 31, 2014 Member Contributer Share Posted July 31, 2014 Silly me filled up my 4th gen (carbs) with e85 once.... The engine ran like shit, stumble, poor pickup. Maybe a fi engine will fare better. There will be no power gain and your fuel economy will be less Moonshine ? Today I cycled out to a place where there was suposedly a "korn brennerei"......... I found a derelict building and learned they stopped making shine a few years ago... bummer..... so back to the Knob Creek, Caol Ila and Port Charlotte tonight.... Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted July 31, 2014 Member Contributer Share Posted July 31, 2014 I was having discussion with a fews buddies of mine and some where saying yes and some were saying no. One said that you would have to change all the hoses, seals, rubbers, run different oil and change the air fuel mixture. Also said with a proper tune you could get more power out of it than regular gas. Another simply said no it would ruin the engine. As most others have said, NO!. E85 will only work properly with an engine that has been specifically designed for it. You will not get any sort of gain, only headaches. It has also been shown to not be nearly as efficient as pure gas or even E10. Do not put it in anything you own not strictly rated for E85 only unless you want to destroy said vehicle. Link to comment Share on other sites More sharing options...
Member Contributer dalesvfr Posted July 31, 2014 Member Contributer Share Posted July 31, 2014 I'd try in an old KLR if no other fuel could be had. That's about it though. Link to comment Share on other sites More sharing options...
spud786 Posted August 3, 2014 Share Posted August 3, 2014 I was having discussion with a fews buddies of mine and some where saying yes and some were saying no. One said that you would have to change all the hoses, seals, rubbers, run different oil and change the air fuel mixture. Also said with a proper tune you could get more power out of it than regular gas. Another simply said no it would ruin the engine. E85 unless the motor is designed for it, will seriously screw up the fuel system, I saw the results back when e85 first came out on a new Chevrolet, that wasn't designed for it.. Personally I run a combo of unleaded and leaded race fuel, don't know why anyone would run different. 110,000 miles and the bike has been rock reliable other than a stator at 56,000 thousand miles and no valve check. Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 3, 2014 Member Contributer Share Posted August 3, 2014 I was having discussion with a fews buddies of mine and some where saying yes and some were saying no. One said that you would have to change all the hoses, seals, rubbers, run different oil and change the air fuel mixture. Also said with a proper tune you could get more power out of it than regular gas. Another simply said no it would ruin the engine. ... Personally I run a combo of unleaded and leaded race fuel, don't know why anyone would run different. ... No one else runs it because lead causes brain damage and other neurological disorders... you may not care but most parents do Link to comment Share on other sites More sharing options...
spud786 Posted August 3, 2014 Share Posted August 3, 2014 Had kids and they are grown and out the door, Its very nice BTW! Lead cant be any worse than Rap music and drugs, far more detrimental to your kids. Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 3, 2014 Member Contributer Share Posted August 3, 2014 Had kids and they are grown and out the door, Its very nice BTW! Lead cant be any worse than Rap music and drugs, far more detrimental to your kids. Believe it or not... no music causes brain damage; and most drugs deplete from your system once you stop taking them. Granted, certain recreational drugs can alter brain development during the formative years... Lead exposure is cumulative and lead doesn't usually deplete quickly from your system over time without chelation treatment... just keeps building up. There is a direct correlation between increased lead concentrations in the body and decreased IQ... even when normalized for socioeconomic contributing factors. I'm glad your kids are grown and out the door. I don't know how your neighbors would feel if they found out you were emitting lead into the air their kids breath. Especially, since there is no known safe threshold for lead exposure that has been discovered—that is, there is no known sufficiently small amount of lead that will not cause harm to the body. Lead was removed from gas for a reason... Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted August 3, 2014 Member Contributer Share Posted August 3, 2014 Personally I run a combo of unleaded and leaded race fuel, don't know why anyone would run different. The primary use of tetraethyl lead was knock or detonation control... if your engine is a modern combustion chamber such as Honda's 4 valve pentroof then lead is not necessary to prevent knock... not mention lead is a unwanted maintenance item because it builds up yellow deposits on the spark plugs... I don't why a owner would go to all that trouble when the lowest octane fuel at the pump works without the dreaded denotation problem... The story how lead got into our fuels started with high compression aircraft engines back in 1921... a young engineer fresh out of college named Charles Kettering started Dayton Engineering Labs Company or Delco... he invented the first battery ignition systems for aircraft engines... when protagonists in the field of aviation widely blamed his battery ignition systems on knock or detonation Kettering commanded his young assistant Thomas A. Midgley on a investigation of detonation. motivated as much by a desire to protect Delco's reputation as by scientific altruism. Midgley worked for months over his single cylinder engine and famous "bouncing pin" which was devised to measure differences in detonation pressures. and he soon determined that detonation depended on both fuel grade and engine compression ratio. Thinking at first that fuel color influenced knock. Midgley added iodine to his fuel theorizing a dark-colored fuel would absorb more heat energy and vaporize more quickly. When the knock diminished he smelled success, but it did not come in the form . he suspected. Further experiments forced him to discard the fuel color idea but led in turn to a long. frustrating line of trial anti-knock additives. GM. parent company of Delco. encouraged Midgley and his assistant T. A. Boyd. who in a vigorous program, individually tested more than 30,000 compounds and their discouragement mounted with the list. On December 9, 1921. a chilly Friday. Midgley and Boyd were anticipating the weekend's respite from their series of relentless, routine tests when suddenly the engine was not behaving the same at all. Jolted into disbelief, Midgley had quite literally stumbled onto the remarkable antiknock properties of an obscure substance called tetraethyl lead. This proved to be without doubt the greatest single discovery in the development of aviation fuels; not only did this additive make higher power possible. it enabled the aeroplane to fly farther on a given amount of fuel- it gave the aeroplane range- and in turn enabled the successful engines that dominated aviation until the advent of gas turbines. In 1967 the remarkable Mr. Midgley was still active as president of the American Chemical Society. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted August 3, 2014 Member Contributer Share Posted August 3, 2014 The story on how lead was legislated out of our fuels started whenClair Cameron Patterson could not isolate his rock samples from leadcontamination in the lab in an effort to determine the age of theearth... he was shocked to learn lead was everywhere and developed thefirst sealed clean lab to prevent lead from messing up the data... Quote WikiThe University of Chicago developed a new method for counting leadisotopes in igneous rocks, and assigned it to Clair Cameron Pattersonas a dissertation project in 1948. During this period he operatedunder the assumption that meteorites are left-over materials from thecreation of the Solar System, and thus by measuring the age of one ofthese rocks the age of the Earth would be revealed. Gathering thematerials required time, and in 1953, Clair Cameron Patterson had hisfinal specimens from the Canyon Diablo meteorite. He took them to theArgonne National Laboratory, where he was granted time on a late modelmass spectrometer.In a meeting in Wisconsin soon afterward, Patterson revealed theresults of his study. The definitive age of the Earth is 4.550 billionyears (give or take 70 million years). This number still stands,although the margin of error is now down to about 20 million years.His ability to isolate microgram quantities of lead from ordinaryrocks and determine their isotope composition led him to examining thelead in ocean sediment samples from the Atlantic and Pacific. Derivingfrom the different ages at which the landmasses had drained into theocean, he was able to show that the amount of anthropogenic leadpresently dispersed into the environment was about eighty times theamount being deposited in the ocean sediments: the geochemical cyclefor lead appeared to be badly out of balance.The limitations of the analytic procedures led to him using otherapproaches. He found that deep ocean water contained 3-10 times lesslead than surface water, in contrast to similar metals such as barium.This led him to doubt the commonly held view that lead concentrationshad only grown by a factor of two over naturally occurring levels.Patterson returned to the problem of his initial experiment and thecontamination he had found in the blanks used for sampling. Hedetermined through ice-core samples from Greenland that atmosphericlead levels had begun to increase steadily and dangerously soon aftertetraethyl lead began to see widespread use in fuel, when it wasdiscovered to reduce engine knock in internal combustion engines.Patterson subsequently identified this, along with the various otheruses of lead in manufacturing, as the cause of the contamination ofhis samples, and because of the significant public-health implicationsof his findings, he devoted the rest of his life to removing as muchintroduced lead from the environment as possible.Beginning in 1965, with the publication of Contaminated and NaturalLead Environments of Man, Patterson tried to draw public attention tothe problem of increased lead levels in the environment and the foodchain due to lead from industrial sources. Perhaps partly because hewas criticizing the experimental methods of other scientists, heencountered strong opposition from recognized experts such as RobertA. Kehoe.In his effort to ensure that lead was removed from gasoline(petroleum), Patterson fought against the lobbying power of the EthylCorporation (which employed Kehoe), against the legacy of ThomasMidgley — which included tetraethyllead and chlorofluorocarbons — andagainst the lead additive industry as a whole. Following Patterson'scriticism of the lead industry, he was refused contracts with manyresearch organizations, including the supposedly neutral United StatesPublic Health Service. In 1971 he was excluded from a NationalResearch Council (NRC) panel on atmospheric lead contamination, eventhough he was the foremost expert on the subject at that time.[4]Patterson's efforts ultimately led to the Environmental ProtectionAgency announcing in 1973 a reduction of 60-65% in phased steps, andultimately the removal of lead from all standard, consumer, automotivegasoline in the United States by 1986. Lead levels within the blood ofAmericans are reported to have dropped by up to 80% by the late1990s.[5]He then turned his attention to lead in food where similarexperimental deficiencies had masked the increase. In one study heshowed an increase in lead levels from 0.3 to 1400 nanograms per gramin certain canned fish compared with fresh, whilst the officiallaboratory had reported an increase of 400 to 700.[6] He compared thelead, barium and calcium levels in 1600 year-old Peruvian skeletonsand showed a 700- to 1200-fold increase in lead levels in modern humanbones with no comparable changes in the barium and calcium levels.[7]In 1978 he was appointed to a NRC panel which accepted many of theincreases and the need for reductions but argued the need for moreresearch.[8] His opinions were expressed in a 78-page minority reportwhich argued that control measures should start immediately, includinggasoline, food containers, paint, glazes and water distributionsystems. Thirty years later, most of these have been accepted andimplemented in the United States and many other parts of the world. Link to comment Share on other sites More sharing options...
GadiantonRob Posted August 4, 2014 Share Posted August 4, 2014 TL;DR E85 is great for boosted applications. Guys on the mustang cobra forums would get e85 swapped and run it, because e85 has an octane rating of like 115. Terrible for n/a, but if turbo bikes come back... Link to comment Share on other sites More sharing options...
spud786 Posted August 4, 2014 Share Posted August 4, 2014 BLS, The ratio I run has nothing to do with Knock, lead oxide flakes are an excellent decarboniser with the right ratio, not to mention valve cushioning and reducing recession, But true, too much can lead to deposits just like in a rifle bore. Nascar many years ago banned Leaded fuel, and they started blowing motors shortly after, then they quietly allowed it back in. Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 4, 2014 Member Contributer Share Posted August 4, 2014 ...Nascar many years ago banned Leaded fuel, and they started blowing motors shortly after, then they quietly allowed it back in. Sunoco and Penske have been working together since the 60's. Sunoco supplies Nascar's race fuel and Sunoco has been the official fuel of Nascar since 2004. It is 98 octane and is called Green E15 because it is actually green in color. Based on Sunoco's description on it's website it is UNLEADED... "Sunoco® Green E15™ is a highly oxygenated unleaded race fuel that contains 15 volume percent ethanol." Nascar does not use leaded fuel. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted August 4, 2014 Member Contributer Share Posted August 4, 2014 BLS, The ratio I run has nothing to do with Knock, lead oxide flakes are an excellent decarboniser with the right ratio, not to mention valve cushioning and reducing recession, But true, too much can lead to deposits just like in a rifle bore. You're addressing problems the VFR doesn't suffer but if you wish to decarbon just inject a tinny stream of water into the intake and the compression will turn it to steam which cleans the aluminum to a shinny luster... ever since nolead fuels all modern engines employ harden valve seats which do not need lead for cushion... Link to comment Share on other sites More sharing options...
spud786 Posted August 4, 2014 Share Posted August 4, 2014 BLS, The ratio I run has nothing to do with Knock, lead oxide flakes are an excellent decarboniser with the right ratio, not to mention valve cushioning and reducing recession, But true, too much can lead to deposits just like in a rifle bore. You're discussing problems the VFR doesn't suffer but if you wish to decarbon just inject a tinny stream of water into the intake and the compression will turn it to steam which cleans the aluminum to a shinny luster... ever since nolead fuels all modern engines employ harden valve seats which do not need lead for cushion... If there was no recession , valves would never need checking or adjustment, and even you ought to know that's unheard of in the motorcycle world. The valves themselves tulip and recess over time, its a side effect with tiny valves in motorcycles, cars with bigger valves have much less recession isssues. You have a motorcycle shop right, and you don't know this? Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted August 4, 2014 Member Contributer Share Posted August 4, 2014 If there was no recession , valves would never need checking or adjustment, and even you ought to know that's unheard of in the motorcycle world. The valves themselves tulip and recess over time, its a side effect with tiny valves in motorcycles, cars with bigger valves have much less recession isssues. You have a motorcycle shop right, and you don't know this? Checking for tulip vales is just one of my inspection steps... but the last time I had to replace a tulip was on the intake side of my air cooled GPZ550 but the cure wasn't adding more lead... it was adding the twice as hard exhaust valve in the intake side... None of my RC30 / RC45 / VFR customers has had a problem with soft valves... Link to comment Share on other sites More sharing options...
spud786 Posted August 4, 2014 Share Posted August 4, 2014 I agree the vfr is very good on valves, but hardened seats overall really falls short on valve recession issue amongst many different models in the motorcycle world. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted August 4, 2014 Member Contributer Share Posted August 4, 2014 Direct from Sunoco: Leaded fuels should not be used where oxygen sensors and/or catalytic converters are used. http://www.racegas.com/article/38 Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted August 5, 2014 Member Contributer Share Posted August 5, 2014 I agree the vfr is very good on valves, but hardened seats overall really falls short on valve recession issue amongst many different models in the motorcycle world. Overall no one is complaining about valve recession... Link to comment Share on other sites More sharing options...
