CandyRedRC46 Posted March 26, 2015 Share Posted March 26, 2015 Don't you wish it were this easy? Let's get in contact with termi! Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted March 26, 2015 Member Contributer Share Posted March 26, 2015 ...And left exit? Yes Please! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted March 26, 2015 Member Contributer Share Posted March 26, 2015 Are we also gonna do under the tail exhaust for us "baggers" ? But I guess I could still purchase a header . Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted March 26, 2015 Share Posted March 26, 2015 I'd kill for a full race left exit system Link to comment Share on other sites More sharing options...
Voided76 Posted March 26, 2015 Share Posted March 26, 2015 http://www.ebay.com/itm/Honda-RVF750R-RC45-SHARK-Exhaust-System-/111551106778?pt=LH_DefaultDomain_15&hash=item19f8f6ceda&vxp=mtruhh... this is def doable? http://www.ebay.com/itm/Honda-RVF750R-RC45-SHARK-Auspuffanlage-Auspuff-Exhaust-System-/121502193447?pt=DE_Motorradteile&hash=item1c4a185727&vxp=mtr it's RC45, so same heads, ect, I bet it'd work, if you made a few brackets off the existing oilpan brackets, ect. Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted March 26, 2015 Share Posted March 26, 2015 I think someone said it may not clear the swing arm or something like that... But some one needs to try asap! Lol Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted March 27, 2015 Author Member Contributer Share Posted March 27, 2015 http://www.ebay.com/itm/Honda-RVF750R-RC45-SHARK-Exhaust-System-/111551106778?pt=LH_DefaultDomain_15&hash=item19f8f6ceda&vxp=mtr uhh... this is def doable? http://www.ebay.com/itm/Honda-RVF750R-RC45-SHARK-Auspuffanlage-Auspuff-Exhaust-System-/121502193447?pt=DE_Motorradteile&hash=item1c4a185727&vxp=mtr it's RC45, so same heads, ect, I bet it'd work, if you made a few brackets off the existing oilpan brackets, ect. That's not an original RC45 exhaust, who is it made by? RC45 has two pipes side by side as they make the bend around the swingarm so they aren't as wide. Even so, they scrap the ground on hard lefts... you'll scrap a hole in that single mid-pipe in no time with aggressive riding unless all you do is go fast in a straight line... Link to comment Share on other sites More sharing options...
Voided76 Posted March 28, 2015 Share Posted March 28, 2015 That's a Shark brand exhaust... NO idea where they hail from. It depends on if that pipe runs through the crease of the pro arm or not I'd suppose. who wants a REAL piece of kit? http://www.ebay.com/itm/Honda-RVF750R-RC45-1994-1995-1996-Rear-Shock-Absorber-Suspension-/121606055815?pt=LH_DefaultDomain_3&hash=item1c50492787 Link to comment Share on other sites More sharing options...
Voided76 Posted March 29, 2015 Share Posted March 29, 2015 Case in point... Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted March 29, 2015 Member Contributer Share Posted March 29, 2015 I still want a left exit... and an RC45 solo tail! Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted March 29, 2015 Member Contributer Share Posted March 29, 2015 I still want a left exit... and an RC45 solo tail! I'm planning to make one for the 5G. 18 more years of working and then I retire, take a few welding classes, by that Miller tig unit and get to fabbing, can you wait? Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted March 29, 2015 Member Contributer Share Posted March 29, 2015 Yep Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted March 29, 2015 Author Member Contributer Share Posted March 29, 2015 I still want a left exit... and an RC45 solo tail! Nothing shows off that SSS and wheel better! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted April 8, 2015 Member Contributer Share Posted April 8, 2015 MOTAD Enlarge image VFR800Fi 1998-2001 Down pipes and collector Stainless steel This system has mounting bosses for the Lambda sensors. If fitting to an earlier model which does not use Lambda sensors, these bosses will need to be blanked off with a suitable bolt and sealing washer (not supplied)The main stand can be retained Type Motad Exhaust Systems Part No PEX MOT D8HRCS Price $465.00 Approx AU$ 610.78 | CA$ 592.41¥ 55741.88 Quantity Stock Temporarily out of stock * Tweet * Please note stock will be available soon and you may still add this to your cart.If you would like to know when this item will be in stock you can request an email alert or call 01728 833020. Well at least one options. Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted April 9, 2015 Share Posted April 9, 2015 I did that option already. Overpriced, a bitch to fit and made no more power that stock. It did drop some weight and sound good though lol. Those headers are made with zero regard to performance. The collector is lined with a steel mesh sound deadening material, primaries/secondaries are tiny and come together at way too obtuse of an angle and there is a huge bottle neck in the collector, right before the slip on. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted April 9, 2015 Member Contributer Share Posted April 9, 2015 I did that option already. Overpriced, a bitch to fit and made no more power that stock. It did drop some weight and sound good though lol. Those headers are made with zero regard to performance. The collector is lined with a steel mesh sound deadening material, primaries/secondaries are tiny and come together at way too obtuse of an angle and there is a huge bottle neck in the collector, right before the slip on. Thanks CandyRed for the input . Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted April 9, 2015 Share Posted April 9, 2015 No prob. I dynod 101 whp with those. Basically the same as every stock header plus slipon and tune VFR out there. No point. Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted April 18, 2015 Author Member Contributer Share Posted April 18, 2015 Ok... here's the latest update. Emailed Tyga since it has been a month... just as a refresher, this is after our discussion in December and their request to clear existing projects until March. The following below is the email thread, I drew a line in the sand and took a leap of faith because I know just how upstanding the good folks on VFRD are and those that committed to purchase VFR800 performance headers will stand by their word... if this works, we will finally have new performance headers... if not... well, the search continues... "Hi Paul, I hope you, Matt, and the rest of the Tyga team are doing well. I'm following up on behalf of the VFRD members regarding our discussions of potential Tyga VFR 800 performance parts. Do you have information or updates you care to share? Please let me know. Thanks... --------------- Friday, April 17, 2015 9:49 PM Subject: RE: VFR800 Performance Parts Hi Sorry to say we are still busy working on other projects. Paul ------------ Hi Paul, Thank you for your prompt response. I understand and respect your business needs and decisions around commitment of resources and the competing priorities for those finite resources. Would Tyga be willing to manufacture 24 units of VFR800 performance headers (no muffler/silencer) based on our previously supplied dimensions for $14,400 USD ($600 USD/unit) plus freight? Please let me know. Thank you for your consideration of this proposal. Best regards," -------------- We will see what they say. I'm keeping my fingers crossed... if the answer yes, I'm sure we will have a little time to finalize and get our coins together and finally get our hands on some real new performance headers for our bikes... if it's no, well... we'll keep looking. If your name is listed in the first post it is because you previously committed and will be first in line for the headers... please honor this commitment or let me know if you've had a change of heart. Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted April 18, 2015 Member Contributer Share Posted April 18, 2015 Rush, If you have that guarenteed commitment, then you could send that to other manufacturers. Anyone that does RC45 already has the basic jig already for header port location. Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted April 18, 2015 Share Posted April 18, 2015 Termi's! Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted April 18, 2015 Member Contributer Share Posted April 18, 2015 Well I emailed them way back at the biginning, never got a reply :( Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted April 18, 2015 Share Posted April 18, 2015 :( Link to comment Share on other sites More sharing options...
MVinOZ Posted April 19, 2015 Share Posted April 19, 2015 I'm out guys, I've just pulled the trigger on a Delkevic system. Best of luck with it! Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted April 20, 2015 Author Member Contributer Share Posted April 20, 2015 I'm out guys, I've just pulled the trigger on a Delkevic system. Best of luck with it! No worries, mate... IIRC you had some reservations about this project and I hadn't added your name to the list in post #1. I only added names to the list of those members who did not offer stipulations to their participation. Thanks for the best wishes and good luck with the Delkevics! Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted April 20, 2015 Author Member Contributer Share Posted April 20, 2015 Reply to proposal from Tyga: "Hi Thanks for the reply. The numbers below are certainly interesting to us. We have a plan to increase our pipe bending capacity in a couple of months and providing we have the time and can source bike to check fitment, we should be able to produce this product. I wouldn’t like to commit to a particular time frame but it is an attractive project. While we have the bike here for measuring, we can look at the rear sets too. Best regards Paul" My response: "Hi Paul, That is encouraging to hear. You mentioned increased capacity in a few months; without committing to a particular time frame what is your vision of when this could possibly play out? Summer, Fall, Winter... Spring 2016? Best regards" Link to comment Share on other sites More sharing options...
