Wow. Someone really wanted those forks on that bike. And I'm a little bit confused on what's going on with the top stem nut, er..bolt?
Boy, those have got a lot of meat on them... I guess they are going for the industrial look :huh:
It's not that they have a lot of meat... well, it is,... but that's because they've skipped a lot of the dress-up features which drive up the labor and therefore the cost.
I do the same with my custom sets.
I made these for a guy who wanted to adapt Hayabusa forks to a GS1000-
This is one of the more fancy parts I've made. Still basic, but has a nice shape. Counterboring the stem pinch bolt was slightly challenging.
4D6B5C16-F230-44C8-9AFF-C4BB7C1A7761-288
6E6BB10E-6144-48E5-A360-56F4154E3177-288
B66EF175-ECA7-4287-A0FA-EF5BFC4BFAE4-288
...This is one of the more fancy parts I've made. Still basic, but has a nice shape. Counterboring the stem pinch bolt was slightly challenging.
I guess that is more accurate... the other shape was blocky, less work put into the aesthetics.
Your work looks outstanding with nice shape, form, and function. :beer:
Does anyone have a CAD drawing or similar format for 54/50 triples with VFR geometry to loan or sell that will allow me to provide to a machine shop for a quote?
Does this mean I get my $250 deposit back ?
??? Was there a custom triple group buy that I'm unaware of?
Anybody have VFR800, RC51, 929/954 steering stem available for measuring? What is the length of the steering stem?
Someone posted earlier a link to a fork conversion table for All Balls Racing and I'm trying to see if there are other options... the unknown is the steering stem length.
Just go buy a used Honda triple for as little $$ as possible, and take the stem out. In an accident, 9 times out of 10 the stem is fine and the triple gets tweaked. So finding a cheap tweaked triple with a good stem should be easy.
Then you can press that into your new custom lower triple.
The all balls site has the fork conversion. You look up your bike and it gives the steering head bearing ID, OD, and heights, and those of other bikes that are or are close to the same. It's up to you to figure out which bearings you need to use and decide if it is really going to work.
It gives you bearing stack heights, not stem lengths.
Right, just bearing dimensions. So it will give you an idea if a different stem even has a chance to fit. Still need to get the stem lengths and compare.
CBR929/954: from base of the lower triple to the top 8"7/8. Bearing surfaces on the steering stem are spaced 7" apart (outer dimension).
Thanks Man!
Anybody know if the RC51 is the same?
Will the VFR (or RC51 or 929/954) stem be long enough if the custom triples are... let's say, an 1" thick aluminum alloy?
It doesn't matter how thick the triple is really. You'll just size the hole and then press the stem to the depth required to achieve the height above the top surface of the triple.
In this day of customizing everything it is hard to believe nobody what produce a generic blank (Honda or Kawasaki or whatever) triple that can be bored to the bottom that you wanted to use ....
When using the CBR929/954 for a fork swap are there any threads exposed above the top nut? If yes, how far does it extend past the nut? If it doesn't extend beyond the nut is there complete engagement of all the nut threads with the steering stem?
Would a complete '01 CBR954 front end (forks, triples, wheel, rotors) be a pretty much straight bolt on for a 4th Gen?
I wish it was that easy! In the end I've found that I can make custom triples to the precise dimensions I want for about the same price. It pays to have suppliers that you've developed a good relationship with!
:wheel:
I've spent hours researching offsets and trail numbers and reading Race Tech's Motorcycle Suspension Bible. The data shows most of the best handling bikes have around a 30mm offset with high 90s to low 100s trail values (CBRs, GSXRs, R1s... early R1s and RC51s are exceptions) and rakes of 23* to 24*; this was also confirmed by a reliable suspension expert.
The stock 5th gen VFR chassis geometry doesn't cut it for this application... and it wasn't designed too. No fault, no grandiose claims that I can engineer better than Honda. Just me attacking a challenge to take something I love and adapt it to a new, more specific application.
Based on this, and some more expert input, I'm going to shoot for an initial set-up of 30mm offset, around 102mm trail, and ~24* rake on my 5th gen track bike. My '09 ZX14 50/54 USD forks are scheduled for delivery tomorrow... so I can start the measuring and wrenching and stop the jabbering!!! Build thread to follow...
My unscientific and nearly accidental settings are CBR/RC51 offset, combined with the front as low as the clutch master cylinder allows (due to hitting the fork) and the rear end shimmed 5mm on the shock mount bolt. It's stock length, and that's where I ran out of threads. Turns out it works. At least for me.
