VFR80025th Posted August 22, 2018 Share Posted August 22, 2018 During the winter I use a trickle charger. A few weeks ago I only rode once during the week so I usedmy trickle charger. Pulled the seat off and left it for 2hrs. Is it OK to do this or should battery be pulled. I had no issues. Anybody want to chime in. Thxs Link to comment Share on other sites More sharing options...
Member Contributer Marooncobra Posted August 22, 2018 Member Contributer Share Posted August 22, 2018 I have installed the external connector plug which is permanently attached to the battery. When I need to trickle charge, due to long periods of no riding, I just hook it up and forget about it. I have done this with both my old lead acid battery and my new Lithium battery. I did have to change trickle chargers as you cannot continually trickle charge a lithium battery. My trickle charger is made by CTEK Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted August 22, 2018 Member Contributer Share Posted August 22, 2018 I have a similar set-up to Marooncobra; I have a connector directly wired to the battery (love the Motobatt brand with an extra pair of terminals) that I use to power heated grips and voltmeters on my bikes, and that I can connect to an external trickle charger when I get the urge. I would not use a fast charger on a battery within the bike as if that went wrong you could possibly boil acid out and cause corrosion, but a trickle charger is fine. Link to comment Share on other sites More sharing options...
Member Contributer Egg on Leggs Posted August 22, 2018 Member Contributer Share Posted August 22, 2018 My VTEC has been on charge for about 12 years without a problem. Link to comment Share on other sites More sharing options...
Urbanengineer Posted August 22, 2018 Share Posted August 22, 2018 1 hour ago, Egg on Leggs said: My VTEC has been on charge for about 12 years without a problem. Dang you should ride it more. Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted August 22, 2018 Member Contributer Share Posted August 22, 2018 +1 for riding more. But I'm guilty too. I've had weeks-long periods of not riding or even starting the machine. Still starts every time with no problems. The only time I even think about it is during the winter months (~Dec - Mar). There was a winter a while back during which I rode nearly once a month, usually nearly a one-month lay-up, and the machine would fire up having sat sans charging. I do replace my battery every three months. Our winters have been becoming milder. (Summers are getting down right HOT - 90s+ Sigh). Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted August 23, 2018 Member Contributer Share Posted August 23, 2018 2 hours ago, MaxSwell said: +1 for riding more. But I'm guilty too. I've had weeks-long periods of not riding or even starting the machine. Still starts every time with no problems. The only time I even think about it is during the winter months (~Dec - Mar). There was a winter a while back during which I rode nearly once a month, usually nearly a one-month lay-up, and the machine would fire up having sat sans charging. I do replace my battery every three months. Our winters have been becoming milder. (Summers are getting down right HOT - 90s+ Sigh). Hi MaxSwell. Am I hearing you correctly "I do replace my battery every three months", mate, I've never heard anyone needing to do that. A good quality battery charger maintainer for AGM type batteries will end up saving you a fortune. Just pop it on for a while during those long cold periods of no riding. With the right care the original Yuasa AGM type battery will last for many years. Safe riding MaxSwell. Cheers. Link to comment Share on other sites More sharing options...
Urbanengineer Posted August 23, 2018 Share Posted August 23, 2018 I was just prodding. By the time we buy a VFR many of us don’t have the time to wrench that we used to. Glad you keep yours charged and ready to go. I wish mine was turn key ready and only had battery issues 🙂. Link to comment Share on other sites More sharing options...
LEGEND Posted August 23, 2018 Share Posted August 23, 2018 I keep my bikes on a battery tender when they sit for a few days. Never had an issue with keeping a bike on the tender. Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted August 23, 2018 Member Contributer Share Posted August 23, 2018 By no means am I advocating against battery maintainers. That is a completely sane strategy. It may well be that I'm just lazy or forgetful about using them. I do keep a portable jump-start battery with me always; as a backup. I've needed to use it several times when I leave my ignition on accidentally (when the engine is over 220F) when I leave it on to run the fan to cool the coolant; after a minuet or so, I restart the engine and the engine temp drops to ~210F. Link to comment Share on other sites More sharing options...
Member Contributer 34468Randy Posted August 23, 2018 Member Contributer Share Posted August 23, 2018 I do not have a battery tender so the only time I put it on a charger is when it won' start. I leave the batteries on the bike and hooked up when I charge it and there has never been a problem. The bike (2006) is on its third battery, but it has over 212,000 km on it so I have no complaints on what I get from the batteries with the way I charge it when it is in need. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted August 24, 2018 Member Contributer Share Posted August 24, 2018 For the last 5 years, I have had a lithium Iron Phosphate battery on the viffer. - I replaced with my 2nd one at the 4th year... -- Charging? What's that? - The only main care I do is pull it off the bike in the winter time and set it on my desk... reinstall in spring. (YRMV) Link to comment Share on other sites More sharing options...
Member Contributer gig Posted August 24, 2018 Member Contributer Share Posted August 24, 2018 1 hour ago, mello dude said: For the last 5 years, I have had a lithium Iron Phosphate battery on the viffer. - I replaced with my 2nd one at the 4th year... -- Charging? What's that? - The only main care I do is pull it off the bike in the winter time and set it on my desk... reinstall in spring. (YRMV) +1 Link to comment Share on other sites More sharing options...
