Military Gear For Cold Weather Riding
timmythecop
As you may know, I do not have a car. I commute every night/morning to the midnight shift at work, and it can be cold here in DC. We have two weather patterns: Africa Hot and Ice Station Zebra. I have spent ages trying to perfect the cold weather gear solution. I discovered a few years ago the military long underwear called Poly-Pro. It is a bit thicker than regular undies, but it sure works. Very very warm and cozy. The only downside is that you must wear it against your skin for it to work correctly. You can get them in tops and bottoms from a surplus store and run about 20 bucks each. Very very worth it, plus they now come in black instead of only olive drab. But now, I have discovered an even BETTER set-up. I bought some innovation from my local thrift store (right next to Andrews Aire Force Base): a brand new Army issued undershirt. The tag says "SHIRT, SLEEPING, HEAT RETENTIVE, MOISTURE RESISTANT" I paid 3 bucks for it and lemmee tell you it is magic. It is THINNER than regular long underwear and has an almost ultrasuede inside. Very comfy and so, so, so warm. I love it. it has a tall collar with a micro zipper and really long sleves. Perfect for our application. I cannot believe how warm this thin shirt is !
So you can go buy the Aerostich Windcheater 5000 for 97 bucks, or you can stop at thrift stores and surplus places that are not on the way home. Do it. Thank me here later.
Here is the new shirt I bought:
This is the poly pro stuff:
black%20ecws%20arctic%20wieght%20polypro
What is Natick Formula IV, that it "is to be laundered in"? per the tag.
Looks worth trying in any case at $3. :beer:
I've been wearing those things for at least 5 years and have about 10 of them.......... Of course I got mine at REI for about $40 a shirt.... :unsure:
Good find Timmy.........
great memories...I was issued those back in the early 80's, yes they are wonderful I will have to look for some again!
I still have my Army issued poly-pro bottoms. I wear them when hunting. Unfortunately the top crapped out after several years of misuse.
Ebay is littered with the sleeping shirts... I'll have to check the local Goodwill. Thanks for the tip Timmy
I bought some Champion Sportswear tops from Target ~$19. They are fitted long sleeve mock turtle necks and do a great job under my leathers, but at $3 a pop, these are definitely a better ROI. Thanks for the post Timmy.
something else:
yesterday morning, I put on this new shirt, a long sleeved t shirt over it and then my textile suit. I was delayed from leaving the station house, so I got pretty warm in there. I was warm and toasty on the way home, BUT when I took the stuff off, the t shirt was damp with sweat and the sleep shirt (next to my skin) was absolutely dry. I didnt used to belive in these space aged cloths before, but I do now.
There is also a sleeping cap, same material, looks like a pilots skull cap, small Velcro strap under the chin, thin enough not to interfere with helmet size...used both on and off for 30 years.....
I started using this product about 8 years ago and it extended my riding to year-round.
Elephant Ears!! I used to use a similar product on my Husky for winter hare scrambles. Hands stayed warm with summer MX gloves, Grips stayed clean and grippy. They were/are awesome.
To the OP, Thanks for the heads up on the "sleeping gear".
ANy tips on hands? I'm doing a cottom/poly thermal layer under my street gloves with grip heaters turned up to "melt". Still get cold fingers, meaning my pinkies had almost no feeling for 20 minutes after getting to work.
Same for feet?
Same for feet?
You may have a peripheral circulation problem...see your doctor, but have you ever tried heated gloves like the Gerbings T-5?
Same for feet?
Are you saying I need viagra for my peripherie's blood flow? :)
Haven't tried heated gloves. Was hoping for a proven glove and boot liner. I've got the Widder vest which uses the velcro arms chaps which connect to heated gloves. pia to use the arm chaps, even though they're effective. Need a simpler solution.
what would be the commercial equivalent? Trying to get my head around what the material really is. Fleece? Synthetic wool?
I bought one of those poly pro undershirts a few years ago for a few $ and it's the warmest thing I've ever worn. The OP shirt is available at my local surplus store for $6, going to check it out this weekend. Thinking of sewing some insulating gloves up from that poly material.
It is hard to describe. The outside is nylon-ish and the inside is fleece-ish, but the whole thing is increadibly thin.
Same for feet?
try riding without the liner. (use good leather winter gloves) You need some air in there for the warmth to have a place to go. My hypothisis is that the heated grips warm the leather and that in turn warms the air inside the leather. I do know with boots that if 2 pairs of socks makes it really tight, one pair is always warmer.
+1 to what Timmy said...make sure there is room in your glove for air space...you don't want a tight fitting glove like in the other seasons. You may need to get a glove that only fits with the liners in and is too big otherwise. I would stay away from any cotton on the liner since it holds moisture and will cause your hands to be colder. A surplus ski or snowboard shop will have straight polyester glove liners that are thin for cheap.
Hey Timmy,
How's the sizing on these? I'll have to do eBay, so I need to know how they stack up to civilian t-shirt sizes.
Glenn
