Member Contributer huntinggunns Posted August 8, 2013 Member Contributer Share Posted August 8, 2013 I have tried a couple of different Ram mount systems for the 1200 and just wasn't satisfied with either one. 1 system would not stay tight and rotated constantly, the other system held tight but did not retain the OE steering stem cap and did not want to stay centered. So, I played around with an idea I had for a while and this is what I came up with. The key to this set up is the machined step washers. This unit will stay tight, won't rotate, stays centered, and retains the OE steering stem cap. The large machined step washer is a slip fit in the steering stem so it keeps the unit centered with the stem. The smaller machined step washer keeps the OE steering stem cap centered and from being crushed and split when the unit is tightened. The 2" well nut tightens down enough that the unit will not pull loose or rotate. I have 1 other unit that will be tested by another member next week, so I will let him give his opinion on it then. It will also fit a 5th Gen and 6th Gen as test fit on a local members bikes. What do you guys think of it? Link to comment Share on other sites More sharing options...
Member Contributer belovian Posted August 8, 2013 Member Contributer Share Posted August 8, 2013 very nice! Link to comment Share on other sites More sharing options...
gloryracing Posted August 9, 2013 Share Posted August 9, 2013 Cool...hope it works out for your tester. I enjoy tinkering/fabricating with my rides...especially when it works as well or better than whats available and costs substantially less. Link to comment Share on other sites More sharing options...
Member Contributer huntinggunns Posted August 9, 2013 Author Member Contributer Share Posted August 9, 2013 very nice! Â Thanks belovian. Sent from my crazy hand held thingy using Tapatalk 2 Link to comment Share on other sites More sharing options...
Member Contributer huntinggunns Posted August 9, 2013 Author Member Contributer Share Posted August 9, 2013 Cool...hope it works out for your tester.  I enjoy tinkering/fabricating with my rides...especially when it works as well or better than whats available and costs substantially less. Thanks glory, I think Jon will be happy with it. He and Gary gave me a few suggestions during the development stage and we even test fit it to Jon's 1200 and Gary's 5th and 6th gen before the final change was made. An engineer and a machinist are good people to know. I think it is the only set up I have seen that actually looks like it was made for the bike, not just something stuck on it. A lot of small changes to get to this point but it is done. If it works like it seems it will I might even make a small run for a few members. Hope to see you soon at the hog tie. Sent from my crazy hand held thingy using Tapatalk 2 Link to comment Share on other sites More sharing options...
bigtallguy Posted August 9, 2013 Share Posted August 9, 2013 I'd be interested in one if you decide to sell a few. Link to comment Share on other sites More sharing options...
Member Contributer spinalator Posted August 9, 2013 Member Contributer Share Posted August 9, 2013 Very nice, I like it and will pay half of retail for one! ;) Link to comment Share on other sites More sharing options...
Member Contributer Yokel Posted August 9, 2013 Member Contributer Share Posted August 9, 2013 Looking forward to being a guinea pig. Thanks Fred! Link to comment Share on other sites More sharing options...
Member Contributer crazybrother Posted August 9, 2013 Member Contributer Share Posted August 9, 2013 I did mine in the same spot but I used one of these Mountain Bike stem star nuts to hold it in. I has worked very well for a year now, only has came loose once but that was because I had not tightened it enough in the beginning. I believe that mine was a "1 version. http://www.ebay.com/itm/FSA-1-5-HEADSET-STEM-TOP-CAP-STAR-NUT-BOLT-4-MTB-BIKE-FORK-/400483121464 I'll try to post some pic's when I have time. Link to comment Share on other sites More sharing options...
Volfy Posted August 9, 2013 Share Posted August 9, 2013 Nice work and very clean install. I have a ram stem mount with the ball at 6 o'clock. It holds a 7" Samsung Galaxy tablet on a short arm just fine. Just got an 8" tablet that will takes its place. It doesn't move when I'm riding but mount/dismount of the big tablet can knock it off-center slightly. I can certainly see how yours would be better. For other gadgets (cellphone, cupholders, etc.), I have a clutch housing bracket. I can add the same thing on the brake side if I want, but so far see no need for it. Link to comment Share on other sites More sharing options...
Member Contributer didit Posted August 9, 2013 Member Contributer Share Posted August 9, 2013 I really like the idea of 'raising the ball' mount, but for different reasons. On my 6th Gen, I have the base mounted to the gas tank bolts up front, where the stubby little ball and 7" Ram mount extender tend to rub the top of the tank. I've got 2 wear marks there now. I'll have to loot at the assembly of mine, but would definitely be interested if your version will mount in the gas tank top location. Otherwise, nicely done. Link to comment Share on other sites More sharing options...
Member Contributer huntinggunns Posted September 19, 2013 Author Member Contributer Share Posted September 19, 2013 I have put about 1500 miles on this set up now and it has not budged. Not sure if Jon has mounted the hula girl yet so not sure how he is liking his . I will let him chime in when he gets a chance. Sent from my crazy hand held thingy using Tapatalk 2 Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted September 19, 2013 Member Contributer Share Posted September 19, 2013 Loving my adaptiv mounts. Keeps vibration to a minimum. Link to comment Share on other sites More sharing options...
crakerjac Posted September 19, 2013 Share Posted September 19, 2013 @huntinggunns: Any update? I like this much better than my RAM-MOUNT. Link to comment Share on other sites More sharing options...
Member Contributer huntinggunns Posted September 20, 2013 Author Member Contributer Share Posted September 20, 2013 @huntinggunns:  Any update?  I like this much better than my RAM-MOUNT. I had to make an emergency run to Colorado and should be home late Sunday evening. I have enough parts left to make 3 mounts. I will figure out how much I have tied up in them when I get home and spin up 3 more sets of spacers. I will let you know when I get that done. These are all hand made so it takes a little time to do them. I am thinking of leaving the spacers and ball mount unpainted to give the choice of what, if any, type and color of paint you want to use on it. Let me know what you think. Fred Sent from my crazy hand held thingy using Tapatalk 2 Link to comment Share on other sites More sharing options...
Clint Posted September 23, 2013 Share Posted September 23, 2013 I'm interested in purchasing one of your custom ram mounts. Is it a complete set up or do i have to modify my own forkstem cap? Link to comment Share on other sites More sharing options...
Lee 2002 Posted September 24, 2013 Share Posted September 24, 2013 I tried many iterations of GPS mount points on my sixth gen. One trial was an extended stem mount. I fabricated a bicycle-type stem mount. This thing cinches up so tight that I could probably lift the motorcycle off the ground with it... It does not move. But ultimately, I stole Didit's idea and mounted my GPS directly to my screen.... right where I always wanted it. Link to comment Share on other sites More sharing options...
Member Contributer huntinggunns Posted September 24, 2013 Author Member Contributer Share Posted September 24, 2013 I'm interested in purchasing one of your custom ram mounts. Â Is it a complete set up or do i have to modify my own forkstem cap? Clint, It is complete, ready to install. Just clean the steering stem hole really good with brake cleaner and a rag, insert the mount, and tighten it down. I am waiting for a few more Ram balls to be delivered. As soon as they are here I will machine those down and I will have a few sets ready to go. Sent from my crazy hand held thingy using Tapatalk 2 Link to comment Share on other sites More sharing options...
Clint Posted September 24, 2013 Share Posted September 24, 2013 I'm interested in purchasing one of your custom ram mounts. Is it a complete set up or do i have to modify my own forkstem cap? Clint, It is complete, ready to install. Just clean the steering stem hole really good with brake cleaner and a rag, insert the mount, and tighten it down. I am waiting for a few more Ram balls to be delivered. As soon as they are here I will machine those down and I will have a few sets ready to go. Sent from my crazy hand held thingy using Tapatalk 2 Put me down for one please - with shipping to 2170 Australia, let me know if you want a deposit. Link to comment Share on other sites More sharing options...
Member Contributer spinalator Posted September 25, 2013 Member Contributer Share Posted September 25, 2013 I should get one too, not that you want this to be a business or anything, haha Link to comment Share on other sites More sharing options...
Member Contributer vfrurknee Posted September 25, 2013 Member Contributer Share Posted September 25, 2013 Fred, Are any of these going to be 5th gen compatible? Link to comment Share on other sites More sharing options...
Jessman Posted September 25, 2013 Share Posted September 25, 2013 I would like one! Please PM me and I will send payment! Link to comment Share on other sites More sharing options...
crakerjac Posted September 25, 2013 Share Posted September 25, 2013 Holy crap... I neglect a thread for a couple days and there is a line... Put me on the list of 'I WANT ONE'. As with everything else, it comes down to price, but it looks like a solid solution. Link to comment Share on other sites More sharing options...
Member Contributer Yokel Posted September 25, 2013 Member Contributer Share Posted September 25, 2013 I've toyed with Fred's mount a bit. This thing is serious! Since I don't have any RAM compatible appliances, I'm working on making a Hula Girl that will fit on it. Should be an entertaining co-pilot in the twisties. Link to comment Share on other sites More sharing options...
Member Contributer spinalator Posted September 26, 2013 Member Contributer Share Posted September 26, 2013 I think he needs a secretary for his bulk order. That is about 5 of us that want one now. Link to comment Share on other sites More sharing options...
