Member Contributer Hingley Posted July 25, 2019 Member Contributer Share Posted July 25, 2019 Well after nearly 2 1/2 years I finally put the final touches on my VFR750. I have waiting since 1990 to own one of these pups and today is the day she is ready for the road Being in Canada there were not that many sold and fewer survived in good shape. I purchased mine 2.5 years ago and being from a province that does not have a safety inspection program I went through the whole bike to check and upgrade any issues Forks rebuilt Front brakes redone with new pads, fluid etc New tapered steering head bearings Rear brakes redone with new pads, fluid etc Clutch flushed with new fluid New plugs Engine coolant replaced New thermostat with new rubber hoses Upgraded the regulator with a Roadstercycle FH020AA Regulator, bypassed the old regulator plugs and wired into stator as close as possible, ( now 14.4 volts at battery ) and the new regulator has no heat where as the old regulator you could hardly touch Rebuilt the fried starter relay wiring The carbs were completely stripped with new gaskets, o rings, fuel lines etc etc, Shimmed the carbs for a little richer mix The bike had an aftermarket seat cowl and I was lucky enough to find a as new one sitting on a shelf As you may have noticed the side stand cover is missing but I am in the process of repairing the screw mounts and she will be 100% 1990_VFR750.MOV Link to comment Share on other sites More sharing options...
Member Contributer Brown81 Posted July 25, 2019 Member Contributer Share Posted July 25, 2019 Looks terrific! Link to comment Share on other sites More sharing options...
Member Contributer Lorne Posted July 26, 2019 Member Contributer Share Posted July 26, 2019 That is a very tidy looking '90. Not sure if they are currently available but the '94-'97 VFR750F rear turn signals fit the '90-'93. The replace the two red lenses either side of the brake light and let you eliminate the stubby oe units. They are p/n 33606-MZ7-671 & 33656-MZ7-671. Here's what my '92 looked like so equipped. Link to comment Share on other sites More sharing options...
Member Contributer MaxSwell Posted July 26, 2019 Member Contributer Share Posted July 26, 2019 Holy Socks. What a beautiful example. You do fabulous work! Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted July 26, 2019 Member Contributer Share Posted July 26, 2019 Gorgeous. I just got my '93 on the road after 4+ years. It's a lot rougher but you can feel what a great bike these are. The Yosh pipe sounds incredible too, congrats. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted July 26, 2019 Member Contributer Share Posted July 26, 2019 Wow! That 3rd gen is fantastic! Looks new like off the dealer show room floor... Link to comment Share on other sites More sharing options...
Member Contributer coppertop Posted July 26, 2019 Member Contributer Share Posted July 26, 2019 Looks great! Link to comment Share on other sites More sharing options...
Member Contributer Gebruiker Posted July 26, 2019 Member Contributer Share Posted July 26, 2019 Congratulations...and done in time for some great summer rides in your part of the world. I’m hope you’ll have a few travel adventures to report. Thanks especially for your design solution of the electrical system upgrade. You do really good work. Link to comment Share on other sites More sharing options...
Member Contributer Hingley Posted August 3, 2019 Author Member Contributer Share Posted August 3, 2019 Man, there are times I wish I lived in the U.S. I think I could use some ones expertise like squirrelman#1 in carb building or buy another set, between the Canadian exchange rate of 35% and the high shipping costs to another county it is hard to purchase state side. I just got my 1990 VFR750 on the road after 2.5 years and just had the carbs cleaned and synced. I know it has been a long time since I rode a bike but the carbs have to be off. The other day I started it up cold with out any choke , it fired right up and it idled for as long as I wanted, but at times if I tried to bring her off idle it felt and sounded like she was stumbling, after the revs passed 2 grand she would rev to the heavens. Once she was really warmed up If I held her at say 5 grand than let go of the throttle ( or rotated it closed ) she would drop her revs until roughly 3 grand and then she would hang there for a few seconds before she settled down to a idle. In the past week I have driven it roughly 60 miles and the fuel consumption seems high. At this point I guess I will have to pull the carbs and see if there is something out of place or not hooked up right from the carb rebuild and if everything is ok there start going through the carbs. I should noted that the bike has a full Yosh exhaust with a K&N air filter, the jets in the carbs are marked as stock sizes, there is a thin washer under the main jet needle ( I guess to help with the installed pipe). I wonder if the main jets are truly stock, I have heard of guys drilling out the stock jets, if this is something I should check what is the best way? Link to comment Share on other sites More sharing options...
squirrelman Posted August 3, 2019 Share Posted August 3, 2019 you're going to need some plug color inspections to dial in carb jetting adjustments, so start with a fresh set of plugs. read an instruction sheet furnished with a dynojet kit to refine your tuning. Link to comment Share on other sites More sharing options...
