Member Contributer VFROZ Posted April 11, 2018 Member Contributer Share Posted April 11, 2018 3 hours ago, shaynus said: Sigh... that's one problem with living so far away from anywhere - the cheapest set I found (4 plugs + harness) was at least $100 more than that. And that is from the UK. One 'local' (other side of the country) ebay seller is asking for $220 for the same thing! I got the whole lot from the US for under AU$75 posted Shaynus. A bit of patience will pay off mate. Quote Link to comment Share on other sites More sharing options...
Member Contributer shaynus Posted April 11, 2018 Member Contributer Share Posted April 11, 2018 4 hours ago, VFROZ said: A bit of patience will pay off mate. But when I get an idea in my head I want to do something about it NOW! ... and then have the parts sit in my shed for 6-12 months until I get a chance to do anything and then another 6-12 months until I finish it! ;-) Quote Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted April 11, 2018 Member Contributer Share Posted April 11, 2018 12 hours ago, shaynus said: But when I get an idea in my head I want to do something about it NOW! ... and then have the parts sit in my shed for 6-12 months until I get a chance to do anything and then another 6-12 months until I finish it! ;-) Wow! It's like looking in a mirror... that sounds just like me Quote Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted April 26, 2018 Member Contributer Share Posted April 26, 2018 Got it fully finalized today. I bought some better soldering gear and heat gun for heat shrink tubing so I could permanently join the CBR plugs to the VFR harness. #3 wire was a tad short making it tighter than I wanted, so I added some length. I have most of a ZX636 wiring harness and found one wire to match. The other will have to be brown... I found some fancy high temp resistant tape used by auto manufacturers for under hood wiring.(Tesa 51036, btw) Figured it was worth a shot. More like a cloth than traditional stretch electrical tape. I still suck at wrapping, though... I didn't trust my jenky soldering to not eventually poke through the heat shrink, so I gave each one a wrap of tape. Starts on the button, as they say. Actually better than it had been recently. It was taking 2 pushes when cold, now it fires right up with the first push! I'll probably change the plugs at some point soon-ish. I don't remember how long they've been in there. Quote Link to comment Share on other sites More sharing options...
Member Contributer Stray Posted April 28, 2018 Member Contributer Share Posted April 28, 2018 Good job, Kev. Looks very neat. On 4/11/2018 at 8:08 PM, Rush2112 said: Wow! It's like looking in a mirror... that sounds just like me Yup, me too! Quote Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted April 29, 2018 Member Contributer Share Posted April 29, 2018 2 hours ago, Stray said: Good job, Kev. Looks very neat. Thanks! I've actually been practicing my soldering this evening and I could do it so much better then I did the other day. Quote Link to comment Share on other sites More sharing options...
Member Contributer adkfinn Posted June 22, 2018 Member Contributer Share Posted June 22, 2018 I posted this in my refurb thread already, so if you've seen it before apologies. I completed my COP swap recently and this thread was an excellent guide. I chose to use the boot/seal over the top style COP's common to GSXR's and, like others, found the length/plug engagement/and seal to work seamlessly on the VFR. One tip - I pulled the rubber seal and installed it first, then inserted the coil second. This ended up meaning the seals sat a bit lower on the coil, just below the notched area they sat in originally. The fit around the coil is a little tighter because of this, and the seal over the plug tunnel is very positive as well. We will see if they move around, I haven't had the bike back on the road yet. Here is a pic of the part #, thanks everyone for sharing the info: Quote Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted June 24, 2018 Member Contributer Share Posted June 24, 2018 Anyone know which Denso pn. the VFR1200 uses? Ciao, Quote Link to comment Share on other sites More sharing options...
yogisays09 Posted June 24, 2018 Share Posted June 24, 2018 3 hours ago, JZH said: Anyone know which Denso pn. the VFR1200 uses? Ciao, Denso part number means like this ? 129700-5370 Quote Link to comment Share on other sites More sharing options...
Member Contributer Vee-Ef-Ar Posted June 25, 2018 Member Contributer Share Posted June 25, 2018 15 hours ago, yogisays09 said: Denso part number means like this ? 129700-5370 I searched some time ago and got the same pn. 129700-5370 Quote Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted June 26, 2018 Member Contributer Share Posted June 26, 2018 On 6/25/2018 at 7:01 AM, Vee-Ef-Ar said: I searched some time ago and got the same pn. 129700-5370 That's the one--thanks, both. I saw an eBay ad for one recently (but not the pn. view) and it definitely looked like a Denso CoP. The Denso part numbers all begin with 127900, but 5370 is not one I've seen before (or measured). It looks like a CBR1000RR CoP, which is pn. 5150 (which is the same length as a 4400), but the grommet appears to be significantly wider--which would help "internal" sealing in larger valve cover openings. Here is a picture of a 5150: And here is the 5370: Now, if they only sold the grommets separately... Ciao, Quote Link to comment Share on other sites More sharing options...
Member Contributer Vee-Ef-Ar Posted June 26, 2018 Member Contributer Share Posted June 26, 2018 9 hours ago, JZH said: Now, if they only sold the grommets separately... Surely someone with a 7thGen has or will change their plugs sooner or later... and have a decent set of vernier calipers. adkfinn - The 129700-4800 sounds promising, let us know I'm in the VFROZ camp, where prices are somewhat surprising, including the not-so "plug and play" options. Quote Link to comment Share on other sites More sharing options...
