Time To Rebuild The VF1000R...IT LIVES!!!!!!!!!!!!!!!!
Kel
Very nice Kel!!
Does it still fit on the bike ok?
These parts are pretty "loose" in the tolerance department so I think I'm good. The fiber is thin as are the resin layers but it could be an issue wth tighter fitting parts.
  • Replies 379
Man, that is killer! I've always wanted to try that but I don't think I have enough patience to do it right. Where did you buy your CF supplies?
The CF came from ebay(doesn't everything?) and the resin came from a local marina. It is high quality resin and not cheap but dries clear.
I've used that West system before and it's good stuff. Pretty much the #1 choice for folks doing any kind of epoxy work it seems.
Now you've got me wanting to do something like that! I'd like to see if/how you could lay down enough layers to make a part 20-25mm thick.... assuming that's even possible.
There is some stuff out there that is like a honeycomb sheet that soaks up the resin then you skin it with the CF. It's the thickness of cardboard. You could probably sandwich 2 together. Great for making dash/gauge panels. Give me a chance and i'll see if I can find some for you.
It was finally time to go from this...
and this...
to this...
I had to spin the CBR cap around due to my custom vent tube but I'll probably go with an aftermarket spin on quick fill so it won't matter. Looks good in real life. Just need to lay on some body filler and smooth it out. It took about 500 spot welds to close it up!
Why spotwelds?(researching my own here)
From the research I did on welding thin metal, a series of spot welds was most frequently advised. I suppose you could braze it but I have a welder so that was my route plus I know it's a good bond. I used 6-8 spot welds to hold it then began 1-2 inch strings of spot welds. I basically just closed my eyes and laid a spot, just as it began to stop glowing, eyes closed and another, slightly overlapping the previous. Then I would go to the other side and do an inch or so there. I would skip around the seam, criss crossing back and forth so as not to put too much heat in the metal which could warp it. This method also helps to prevent blowing through the thin metal which you would do if you tried to just lay down a long bead( well, I would any way). The VF tank has an odd shape in front of the gas fill so cutting the CBR fill out and making it sit down correctly was a bit of a challenge. The CBR tank vent(A) and drain(B) go through the bottom of the tank. I really didn't want to get in to messing with the bottom so I used part of the copper drain tube(B) to act as a vent. I turned it up and crimped the end. I then drilled a small drain hole in the low part of the tube elbow and that seems to be fine. I had to rotate the cap/base 180 degrees to let the drain tubes elbow face forward and up to the highest place in the tank. Fuel can't splash up in to the fill drain hole but any fuel that does spill at the cap can drain into the tank. I'll just have to not over fill the tank. I've heard of people drilling the cap somewhere to provide venting. May go that route if problems show up from this setup.
So by spot welds you really mean tack welds, and stitch welds. You weren't using a spot welder, correct? A mig or plain wire feed more likely? If you have a tig you can color me jealous!
It looks good, definitely makes the bike look newer. It's too bad you had to mount the cap backwards to make it work, IMO, since I prefer the look of the stock cap over the racing style ones. (which can be had for about $38 from ebay hong kong sellers, btw!)
Keep it up man!
Keep it up man!
I guess I mean tack weld. I use those terms interchangeably, wrongly, I see. I tried to loop the copper tube but it really wanted to crimp and I felt( right or wrong) that it should be as high in the tank as possible. This meant flipping it so the elbow pointed forwards. I could have cut it and soldered it but it would have been a butt joint and I didn't want anything questionable in there once it got buttoned up. I was on the fence about whether I would care if the writing was upside down or not. I suppose I could drill out 3 of the faux bolts and mount it correctly and just epoxy in some allen heads in the old holes? I like the stock look as well and also like some of the multi bolt aftermarket ones. Not crazy about the 3 bolt ones. Keyless is appealing. Ideally, to get the race bike look, I would love something like this...
The "fake" bolts are actual bolts, they thread out with a 5mm allen just like the "real" 3. :laugh:
Could you have welded a nipple to the top of the tank and run a loop of fuel line to the stem hole in the triple, like a dirt bike/old racebike? Or are you trying to keep it more modern?
I like it clean, so no nipple. Cool on the "fake" bolts! I'll have to go out and see if its possible to just remove and mount. I don't mind saving $40 at this point.
  • 3 weeks later...
I finished up the body filler and put on a coat of primer on the VF tank. Definitely looks better than stock. It has a nice profile. I'll be glad to have a flat perch for a tank bag with this set up. Still have some finish work on some pin holes but she's close to ready for paint.
Kel, is that a dent on the knee pocket ridge, at 9:15 in relation to the petcock?
A nice trick for finding high & low spots is to get a spray can of black primer, and mist a very light coat over an area. (VERY light, just enough to get the overspray effect) Then lightly block with your sandpaper; the black will come off the high spots and stay in the low spots. If you're not already using SEM filler primer, use that as it's thicker and better for filling pinholes and smoothing. Then use regular primer, then sealer, color, etc.
Good work! Think you'll get a ride in soon?
Yep, part of the reason for getting the primer on was to find the spots that don't show in the raw metal state. A few small areas to address but considering the carnage that took place on this thing, I'd say all's good. "Soon" is relative at this point.
Sorry if I came off as preachy :cool: , just trying to pass on what I've picked up over the years, although I'm far from an expert.
No preaching detected here. All good points. :ph34r:
Got the exhaust done. The rear header, pipe and can are the left side and it's attached to the front which is the right side. There's a break in the front mid pipe to allow for easy installation. It's held together with an exhaust spring. It will definitely flow some exhaust, maybe too much, who knows. I sprayed on the Ceramic coating and baked it for 1 hour at 500 degrees, another good use of the custom oven. I didn't think it would actually polish out but it is shiny, not chrome shiny but more like nickel shiny. It comes out chalky but does polish out. We'll see if it holds up. They say it's good to 2000 degrees? If it does hold up, it's a bargain at $40. I thought it would hide my crappy welds but not so. I'm no welder but I want to do everything myself on this project. Good enough for a race bike. The cans are polished aluminum with custom caps. Now I just have to make some baffles cause this thing will be loud without them!
