AB-Oz Posted January 17, 2008 Share Posted January 17, 2008 :rolleyes: on the RAM tank mount for the Zumo, other methods just get in my way. Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2008 Share Posted February 5, 2008 Any RAM dealer has this Handlebar RAM mount.......take off the Ubolt and you are ready to go using the front bolts on the VFR tank. Just wondering when you use the ram mount attached by the tank mount bolts do you need to replace the bolts with longer ones or do the stock ones do ????? Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted February 5, 2008 Member Contributer Share Posted February 5, 2008 Any RAM dealer has this Handlebar RAM mount.......take off the Ubolt and you are ready to go using the front bolts on the VFR tank. Just wondering when you use the ram mount attached by the tank mount bolts do you need to replace the bolts with longer ones or do the stock ones do ????? No, but it's a good idea. (There's plenty of thread there). I did, but I also put in about 1" of spacer, under it, as I wanted it up a little higher. Link to comment Share on other sites More sharing options...
Member Contributer sportrider Posted February 5, 2008 Member Contributer Share Posted February 5, 2008 Any RAM dealer has this Handlebar RAM mount.......take off the Ubolt and you are ready to go using the front bolts on the VFR tank. Just wondering when you use the ram mount attached by the tank mount bolts do you need to replace the bolts with longer ones or do the stock ones do ????? I've done both. Stock worked, but I was happier with slightly longer. :thumbsup: Link to comment Share on other sites More sharing options...
Member Contributer BonusVFR Posted February 5, 2008 Member Contributer Share Posted February 5, 2008 Any RAM dealer has this Handlebar RAM mount.......take off the Ubolt and you are ready to go using the front bolts on the VFR tank. Just wondering when you use the ram mount attached by the tank mount bolts do you need to replace the bolts with longer ones or do the stock ones do :unsure: ????? I've done both. Stock worked, but I was happier with slightly longer. :thumbsup: This is what I ended up doing. Just a little longer than OEM. I think I had some in my parts bin. Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2008 Share Posted February 5, 2008 Cheers alll for the replies :thumbsup: Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted February 5, 2008 Member Contributer Share Posted February 5, 2008 Cheers alll for the replies :thumbsup: Here is one more.... HP iPAQ 6515 Link to comment Share on other sites More sharing options...
Guest Posted February 6, 2008 Share Posted February 6, 2008 I like clean and uncluttered, I really don't like stuff up on my bars, so; I took an off road GPS mount, Touratech, I had laying around and attached in front of the tank. The same would work for a newer bigger GPS Link to comment Share on other sites More sharing options...
Member Contributer OrdinaryAverageGuy Posted February 17, 2008 Member Contributer Share Posted February 17, 2008 Just bought a Zumo 550. Here is one more option, a stem mount, which is the one I will be going with. Techmounts Link to comment Share on other sites More sharing options...
Mitch Posted February 22, 2008 Share Posted February 22, 2008 The handle bar RAMs is what i use! they work well to mount a camera to the bike as well! :salesman: Link to comment Share on other sites More sharing options...
?art West-VL. Posted February 23, 2008 Share Posted February 23, 2008 I just use the suction-cup mount that came with the GPS and plant it on the tank, near the front. Doesn't move at all in a 250 mile ride. I did have to pull off the sticker that was placed there by Honda. Was easy with a hair dryer. Link to comment Share on other sites More sharing options...
Guest Posted April 2, 2008 Share Posted April 2, 2008 Hi, As for mounting, I have seem something on a VFR Bike once, it attaches to the left and right locations on the handle bars just left/right of the grips and is bolted (where you can put 1 ram mount on each either or both sides) and the a bar spans from left to right, and then on that bar you can mount a host of things. Has anyone seen or use this can post some shots? Thanks Link to comment Share on other sites More sharing options...
V4 Rosso Posted April 2, 2008 Share Posted April 2, 2008 I posted pics of that setup in BonusVFR "Tales of a Zumo" topic. It is part of the Honda/Zumo Gathers-M GPS setup. Link to comment Share on other sites More sharing options...
Member Contributer DougFromIndy Posted April 2, 2008 Member Contributer Share Posted April 2, 2008 This is for a camera, GPS or really anything, I just got it off Ebay (Canada seller) was $30 USD plus ship, I will use it for my MP3 and gerbings t-stat , things I need to adjust on the fly Link to comment Share on other sites More sharing options...
Guest Posted April 3, 2008 Share Posted April 3, 2008 I think what I'm talking about are these: http://www.hardracing.com/Vortex/VortexClipOns.htm Anyone have something like this on their VFR and can show some pictures? Link to comment Share on other sites More sharing options...
Guest Posted April 3, 2008 Share Posted April 3, 2008 Ok, I found it, here is the picture link I uploaded to a gallery. Cross-Bar Mounter This I have seen in Japan and found on the Honda Japan website for VFRs.<br /><br />This Bar attaches to the left and right side near the Brake and Clutch fixtures and you can mount several items such as GPS etc.. Link to comment Share on other sites More sharing options...
Headhunter Posted April 3, 2008 Share Posted April 3, 2008 The RAM stem mount works great. Link to comment Share on other sites More sharing options...
V4 Rosso Posted April 3, 2008 Share Posted April 3, 2008 Ok, I found it, here is the picture link I uploaded to a gallery. Like I said, it is in the Tales of a Zumo thread. Looks to me this bar makes it difficult to reach for the ignition switch. Link to comment Share on other sites More sharing options...
Guest Posted April 3, 2008 Share Posted April 3, 2008 Ok, I found it, here is the picture link I uploaded to a gallery. Like I said, it is in the Tales of a Zumo thread. Looks to me this bar makes it difficult to reach for the ignition switch. I'm wondering, do you know of a way with the Garmin Zumo 550 to be able to control the music volume, and moving track to track without having to directly interact with the Zumo and browse away from the maps? Each time I wanna go to the next song, I have to go to the Player, switch and then get back to the Map. Link to comment Share on other sites More sharing options...
V4 Rosso Posted April 3, 2008 Share Posted April 3, 2008 I don't know, sorry. I have a streetpilot myself and it comes without an mp3 player. I am sure others like BonusVFR will soon chime in. Link to comment Share on other sites More sharing options...
Member Contributer BonusVFR Posted April 4, 2008 Member Contributer Share Posted April 4, 2008 Ok, I found it, here is the picture link I uploaded to a gallery. Like I said, it is in the Tales of a Zumo thread. Looks to me this bar makes it difficult to reach for the ignition switch. I'm wondering, do you know of a way with the Garmin Zumo 550 to be able to control the music volume, and moving track to track without having to directly interact with the Zumo and browse away from the maps? Each time I wanna go to the next song, I have to go to the Player, switch and then get back to the Map. For the volume use the 4th button down on the left ..........then use + and - hard buttons. Use the 3rd button or page thru the various screens to move to the mP3 screen. The song that is playing should come up. Go to browse. Then pick your All (every song on the Zumo), Album, Artist and Genre and then hit Play All. You will then play all the songs in the album. That is the best you can do except maybe if you have a playlist. Link to comment Share on other sites More sharing options...
Guest Posted April 4, 2008 Share Posted April 4, 2008 So, you're saying that after I hit the fourth Hard Button (bottom-most one), I can then control the volume of the music by the '+' & '-' hard buttons to the left? Are you also saying that after hitting the fourth Hard Button (bottom-most one), it is then possible to use the 3rd Hard Button (looks like a square) to forward through songs? Volume is important, but also if I just don't feel like listening to the dog barking jingle bells, I was hoping for a quick 'Next Track' button so I don't have to take multiple steps just to get to the point to be able to select next track, as well as not losing the Map view. Thanks for your contrib, any further clarification would be super. Thanks! Link to comment Share on other sites More sharing options...
Member Contributer BonusVFR Posted April 4, 2008 Member Contributer Share Posted April 4, 2008 So, you're saying that after I hit the fourth Hard Button (bottom-most one), I can then control the volume of the music by the '+' & '-' hard buttons to the left?Are you also saying that after hitting the fourth Hard Button (bottom-most one), it is then possible to use the 3rd Hard Button (looks like a square) to forward through songs? Volume is important, but also if I just don't feel like listening to the dog barking jingle bells, I was hoping for a quick 'Next Track' button so I don't have to take multiple steps just to get to the point to be able to select next track, as well as not losing the Map view. Thanks for your contrib, any further clarification would be super. Thanks! I understand your question better now. Once you page (3rd hard button) to the MP3 screen just hit the + or - hard buttons to advance the song. I thought you were stuck on one song. I find I prefer to have one album/artist at a time in order to minimize "key strokes" while on the move. Plus if you really do not like the song you can dump it from the download if you like. Link to comment Share on other sites More sharing options...
Guest Posted April 5, 2008 Share Posted April 5, 2008 Yeah, Thanks I see what you're saying. Unfortunately still too many steps just to advance/change the song while riding. Hiway ok, but in town with lot's of traffic, a bit dangerous. Too bad there isn't some type of voice command you can give like saying 'Next'. Thanks for the help. Link to comment Share on other sites More sharing options...
FrankoQ Posted April 13, 2008 Share Posted April 13, 2008 Pics of my setup. Link to comment Share on other sites More sharing options...
