Member Contributer Rectaltronics Posted September 10, 2015 Member Contributer Share Posted September 10, 2015 Those of you paying attention to the RC79 Instant Suspension Tune thread will know that I changed out my stock tires a few weeks ago. I went strictly by the manual for pretty much everything, including the bizarre tighten / loosen / tighten procedure for the bits on the front forks. Everything except one thing... The manual says all the bolts holding the brake calipers on are supposed to be replaced with new bolts. Really? New bolts with every tire change and brake job? At $11+ apiece..? What's the liability, having not replaced them? Or, how many remove/install cycles can we get away with and why? What are the chances that a Honda dealer shop would ever even bother? FWIW I see the same bolts are also used on every CBR600RR since 2005. Link to comment Share on other sites More sharing options...
Member Contributer wagzhp Posted September 10, 2015 Member Contributer Share Posted September 10, 2015 I call BS. I don't use any scientific procedure to measure the bolts, but as long as they don't appear to be stretched or distorted, I just put some lock-tite on them and re-install them. Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted September 11, 2015 Author Member Contributer Share Posted September 11, 2015 Which color Loctite? Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted September 11, 2015 Member Contributer Share Posted September 11, 2015 I just check them visually, put them back in, and tighten to spec. Never had one loosen up or be anything but tight when time comes to take them back out again. I don't use Loktite because I don't feel it's necessary. But that's just the way I feel about it. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted September 11, 2015 Member Contributer Share Posted September 11, 2015 Same here - I reuse 'em. I remove the old thread lock before reuse. Link to comment Share on other sites More sharing options...
dogman Posted September 11, 2015 Share Posted September 11, 2015 Never replaced one ever, and no loctite for me either. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted September 11, 2015 Member Contributer Share Posted September 11, 2015 If you read the 600rr manual it would have said the same thing. All the service manuals say replace brake bolts if they have been removed Link to comment Share on other sites More sharing options...
Member Contributer wagzhp Posted September 11, 2015 Member Contributer Share Posted September 11, 2015 Which color Loctite?I use loctite blue - medium strengh. Link to comment Share on other sites More sharing options...
Baileyrock Posted September 11, 2015 Share Posted September 11, 2015 I've installed over 40 sets of tires on my 02 VFR and have replaced 1 bolt in that time, also i never use Locktite either as the bolts only have to go less then 4k miles w/o falling out. BR Link to comment Share on other sites More sharing options...
Shinigami Posted September 12, 2015 Share Posted September 12, 2015 As long as you're using a torque wrench, no problem. If you screw up and over torque one, though, you would be wise to replace. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted September 12, 2015 Member Contributer Share Posted September 12, 2015 There is a dissenting view about this. But I use titanium! Ciao, Link to comment Share on other sites More sharing options...
ShinyVFR Posted September 13, 2015 Share Posted September 13, 2015 I got stitched by my dealer in the UK on my 2015 VFR800 when I got a set of new tyres. They said the hollow bolts holding the calipers on should be replaced. £7each, I recall, so each front tyre is suddenly £28 more expensive. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 13, 2015 Member Contributer Share Posted September 13, 2015 The dealer will follow the documented procedure, that is not stiching... If next time he refuses to reuse the bolts, that would be a different matter. Link to comment Share on other sites More sharing options...
ShinyVFR Posted September 13, 2015 Share Posted September 13, 2015 You're right - I wasn't stitched up, it just felt like it. Link to comment Share on other sites More sharing options...
emil Posted September 14, 2015 Share Posted September 14, 2015 There is a line of 3rd party repair manuals (in German) by the Bucheli publishing house. I got their manual for the NC700, where replacement of the bolts is specified as well (probably the same for all current models). In the author's opinion, replacement is not necessary, but he does recommend using a product like Loctite (medium strength). Generally, nobody but licenced Honda repair shops replaces these. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted September 14, 2015 Member Contributer Share Posted September 14, 2015 Replacement bolts come with a thread locking compound on them so it should be "locked" if reusing them Link to comment Share on other sites More sharing options...
fatshoutybloke Posted September 15, 2015 Share Posted September 15, 2015 I've gone titanium too, and not just for the caliper bolts. Various fasteners were looking distinctly manky after just one British winter. Link to comment Share on other sites More sharing options...
garyr Posted September 15, 2015 Share Posted September 15, 2015 Where do you get the titanium bolts from? Looks good, did you do the ones around the disc as well. I have another bike that needs some. Link to comment Share on other sites More sharing options...
cbrcolin Posted September 15, 2015 Share Posted September 15, 2015 I have reused the same bolts on other Honda bikes many times with no issues, did not add thread lock but I did torque bolts to specs. Link to comment Share on other sites More sharing options...
fatshoutybloke Posted September 16, 2015 Share Posted September 16, 2015 Where do you get the titanium bolts from? Looks good, did you do the ones around the disc as well. I have another bike that needs some. Various places - Pro-Bolt (the stainless steel mudguard bolts), Titan Classics (the axle and disc bolts) and Competition Fasteners on eBay. Link to comment Share on other sites More sharing options...
