Member Contributer Dutchy Posted April 3, 2013 Member Contributer Share Posted April 3, 2013 Inspired by GP bikes, courtesy Douglasthecook From To Me likey!!! Link to comment Share on other sites More sharing options...
SEBSPEED Posted April 3, 2013 Share Posted April 3, 2013 Watch yer shoelaces... ;-) Link to comment Share on other sites More sharing options...
Member Contributer 2thdr Posted April 3, 2013 Member Contributer Share Posted April 3, 2013 On our AR ride last weekend a young guy on a K1200 S was with us (came with a VFRD member) and was wearing some combat-style laced boots. During the ride another rider flagged him down to stop since he was dragging his 18" untied laces! Yikes! Watch yer shoelaces... ;-) Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted April 3, 2013 Author Member Contributer Share Posted April 3, 2013 Good thing I never have and never will rides with shoes.... ;-) Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted April 3, 2013 Member Contributer Share Posted April 3, 2013 On our AR ride last weekend a young guy on a K1200 S was with us (came with a VFRD member) and was wearing some combat-style laced boots. During the ride another rider flagged him down to stop since he was dragging his 18" untied laces! Yikes! Wow! Link to comment Share on other sites More sharing options...
Guest Posted April 3, 2013 Share Posted April 3, 2013 Is that a modified stock cover ,or?? Link to comment Share on other sites More sharing options...
Beck Posted April 3, 2013 Share Posted April 3, 2013 Dutchy!,.......your shift lever's getting dirty! Beck 95 VFR Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted April 3, 2013 Member Contributer Share Posted April 3, 2013 Now your boots oiled ..... Link to comment Share on other sites More sharing options...
Guest Posted April 4, 2013 Share Posted April 4, 2013 Is this a stock cover cut down or a special ?? Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted April 4, 2013 Author Member Contributer Share Posted April 4, 2013 Cut down original....... I will have to see how this functions in the real world re chain oil on my boot.... Since Doug has the same on his 4th Gen, he'd told me if there were any drawbacks No functional advantage, just form. Like the clear clutch cover......... but I want it Dutchy!,.......your shift lever's getting dirty! Beck 95 VFR That is not dirt, just scrapes........ Link to comment Share on other sites More sharing options...
timmythecop Posted April 4, 2013 Share Posted April 4, 2013 whats the cack supposed to stick to? Cack is an integral part of motorcycling, you know. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted April 4, 2013 Author Member Contributer Share Posted April 4, 2013 Oh by the way...... the gasket I bought (the one that is supposed to go between the engine and the cover) was NOT the right one. I found out once the cover was off... Yeah I should have checked it with the donor cover......... Maybe I ordered the gasket for a 3rd gen cover? Anyway, I have now fitted it without this gasket. Since it is not there to hold any fluid inside, will I now crash burn and die??? What is the point anyway to have a gasket if not to hold fluid/pressure inside??? Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted April 4, 2013 Share Posted April 4, 2013 It'll be easier to clean out the chain spooge from around the countershaft area now..... Link to comment Share on other sites More sharing options...
timmythecop Posted April 5, 2013 Share Posted April 5, 2013 It'll be easier to clean out the chain spooge from around the countershaft area now..... spooge = cack. Link to comment Share on other sites More sharing options...
Beck Posted April 5, 2013 Share Posted April 5, 2013 I must have opened that sprocket cover only once on my 4th gen a very long time ago.... There must be more than a decade's worth of cack under it........slowly turning into beautiful diamonds already.... Should I check it this weekend??........I'm a bit afraid to look.... . Beck 95 VFR Link to comment Share on other sites More sharing options...
SEBSPEED Posted April 5, 2013 Share Posted April 5, 2013 If you do take a look... Scrape the thick stuff with a flathead screwdriver, and use WD40 to wipe the remainder out. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted April 5, 2013 Author Member Contributer Share Posted April 5, 2013 And wear a pair of marygolds/rubber kitchen gloves......... That is some serious cack down there....... ;-) Link to comment Share on other sites More sharing options...
timmythecop Posted April 5, 2013 Share Posted April 5, 2013 what is nederlands for cack?......dingetje? Link to comment Share on other sites More sharing options...
V4 Rosso Posted April 5, 2013 Share Posted April 5, 2013 Smurrie. Looks good Leon. I like the idea to be able to check the front sprocket for wear without having to take the cover off. Link to comment Share on other sites More sharing options...
SEBSPEED Posted April 5, 2013 Share Posted April 5, 2013 I did something similar to a 96 cover. I did not need to retain the speedo pickup so I was able to open it up a lot more. Link to comment Share on other sites More sharing options...
