Sign in to follow this
fallzboater
Faq: Low-budget Fixes
3. remove the charcoal canister. This saves weight and the thing only gets in your way during oil filter changes.
And it is to be found where, exactly? :goofy:
Share this post
To the right of your oil filter. It looks like a big black painted apple juice can.
Share this post
Guest fco
Anyone else having a problem accessing the pages for the different mods?
Tried numerous times and still nothing. Can't locate it with the search either. <_<
same here. anybody can help ?
Share this post
And it is to be found where, exactly? :blink:
What is the purpose of this black apple juice can? Will it hurt anything to remove it?
Share this post
It's to capture gasoline fumes when the engine is stopped so that it doesn't vent to the environment, then reuse it the next time the engine runs.
Eenh, I'd say keep it.
Share this post
Just occurred to me that the ball thing would make a nice RAM mount if the size is similar. Hello rear-facing footage! :thumbsup:
Share this post
Anyone remove the metal heat shield behind the right drivers peg? If so any adverse affects? Might look better without it and it can't provide that much heat protection.
What about removing the lower chain guide/guard. Also doesn't look like it does much and will look cleaner without it.
Share this post
Been done. Gives a hot foot.
Chainguard done too. Not sure where the threads are.
Share this post
are you talking about the guard on the up pipe? Or attached to the peg? I bought my bike with Micron exhaust already on it and it didn't have the heat sheild on the up pipe. 17k miles later still no problems with that. And I do like the looks of the pipe that way.
If you're talking about the little wing shaped guard on your footpeg? ... well, ya need that buddy. For the twisties! :fing02:
Share this post
No he is talking about the black piece of tin behind the peg. With it off you can see the pipes and it looks good. I bet it blocks more heat than you think.
Share this post
REAR SUSPENSION:
Mod:  Increase rear ride height by shimming under top shock mount
Benefits:  Improved handling due to steeper head angle, reduced trail, increased cornering clearance
How to:  Add approximately 4mm of shims under top shock mount to raise ride height ~12mm.
Time:
Cost:  $0
Permanance:  Completely reversible.
Could anyone help me find anymore information regarding this mod of shimming the top shock mount? My searches are coming up empty...
I think you just needs some M10 washers....I found this
http://www.nabble.com/rear-shock-question-td2715158.html
and am considering trying this myself.
Share this post
Bumpity bump bump.......
Share this post
The small section talking about that can by the oil filter, does it sit on the from lower part of the motor under the front part of the header. I think the manual says something about being part of the california model or something. Is that needed?
Share this post
Noooo, don't touch that can or the "g-men" will be on your back lickety split, sending you to the slammer for breaking EPA laws!! :huh: ........BTW, it's there to capture polluting "farts" from your gas tank :laugh: .
Beck
95 VFR
Share this post
I just got my '02 VTEC for a song, and was able to pay cash, but not much left for mods right now. Great bike, but definitely could use some improvements, especially in the FI and suspension. I've been searching the forum, but thought it'd be cool to have a list of little to no cost mods to improve the bike, with comments on their benefits. Should be a good FAQ once compiled, and my bike is bone stock now, so I'm willing to be a guinea pig. Mostly looking for improved driveability and suspension performance, also aesthetic (visual and/or aural). I think weight reduction would be another good catagory. By low-budget, I mean: free, using (adjusting, modifying, or removing) stock parts (or used parts from other models) if possible or worthwhile, or the most cost-effective aftermarket options. For example, a new Ohlins USD fork would be nice, but Race Tech springs, gold valves, and rebound pistons and adjuster caps from an F4, while not free, would be more cost-effective for the majority of riders.
Please add comments, links to how-to threads, and any new mods. I'll compile and edit as we go along, and add my impressions as I perform the mods. Feel free to PM me, or just reply.
Let's go!
-David
INTAKE SYSTEM
Mod: Flapper valve disable
Benefits: Smoother acceleraton through 5k rpm??? Sound enhancement at low rpms?
How to: Lift fuel tank, pull vacuum hose off of flapper control valve diaphram on top of air box, plug hose with bolt, secure with zip tie (optional).
How it works: Disconnecting the vacuum hose will keep the flapper valve from closing the second intake opening under the control valve.
Time: 5 minutes
Cost: $0
Help: got to http://www.vfrdiscussion.com/forum/index.php?page=parts
click on "Air Cleaner" for drawing
Mod: Remove intake snorkel
Benefits: Sound enhancement at WOT, possible performance benefit due to less restriction.
How to: Lift fuel tank, pull snorkle out of right front of airbox lid.
Time: 5 minutes
Cost: $0
EXHAUST SYSTEM
Mod: De-baffle stock exhaust
Benefits: Sound enhancement, possible performance benefit due to less restriction.
How to:
Time:
Cost: $0
Permanance: Not reversible without buying another stock exhaust.
FUEL SYSTEM
Mod: Adjustable fuel pressure regulator (FPR)
Benefits: Improve drivability by reducing lean running conditions
How to:
Time:
Cost: $130 (retail)
Mod: Dynojet Power Commander (PCIII)
Benefits: Improve drivability by modifying fueling maps
How to:
Time:
Cost:
FRONT SUSPENSION
Mod: Heavier fork oil
Benefits: Increased compression and rebound damping with stock internals
How to:
Time:
Cost:
Mod: Raise forks in triple-clamps
How to:
Time: 20 minutes
Cost: $0
Mod: Replace fork springs with Race Tech appropriate for rider weight and use
Benefits: Improved handling, reduced brake dive. Stock springs are too soft.
How to:
Time:
Cost: $110 (retail)
Help: got to http://www.racetech.com/evalving/SpringRat...SpringType=Fork to choose your rate, or direct (15% discount for VFRDG) or through your favorite vendor
REAR SUSPENSION:
Time:
Cost: $0
Any chance to get the broken links fixed? I'm about to do a search, but for the ease of other newcomers it would be nice to have the links work again. These just take me to the homepage. :warranty:
Share this post
Remove the stickers on the fuel tank
- Use only unleaded fuel
- Always wear protective gear
Improves the look and lower the weight with up to .5 g.
Share this post
Got any great advice about removing the stickers from the tank without messing up the finish?
Share this post
Goo Gone.
Share this post
I did the PAIR, flapper, and snorkel mod and noticed a 1 to 2 MPG better gas mileage on average. That's over the last 2,000 miles. Happy so far.
Share this post
Let's go!
-David
INTAKE SYSTEM
Time: 5 minutes
Cost: $0
Time: 5 minutes
Cost: $0
EXHAUST SYSTEM
How to:
Time:
Cost: $0
FUEL SYSTEM
How to:
Time:
Cost: $130 (retail)
How to:
Time:
Cost:
FRONT SUSPENSION
How to:
Time:
Cost:
How to:
Time: 20 minutes
Cost: $0
How to:
Time:
Cost: $110 (retail)
REAR SUSPENSION:
Time:
Cost: $0
It may be that those posts have been purged. Going to the end of the modifications section, there's only a handful prior to 2006. The generations sections were recently purged to no more than 600 days old, so many links there are no longer working, either.
Share this post
