Member Contributer PorradaVFR Posted June 5, 2007 Member Contributer Share Posted June 5, 2007 3. remove the charcoal canister. This saves weight and the thing only gets in your way during oil filter changes. And it is to be found where, exactly? :goofy: Quote Link to comment Share on other sites More sharing options...
Guest redrocket800 Posted June 10, 2007 Share Posted June 10, 2007 3. remove the charcoal canister. This saves weight and the thing only gets in your way during oil filter changes. And it is to be found where, exactly? :goofy: To the right of your oil filter. It looks like a big black painted apple juice can. Quote Link to comment Share on other sites More sharing options...
Guest fco Posted June 15, 2007 Share Posted June 15, 2007 Anyone else having a problem accessing the pages for the different mods?Tried numerous times and still nothing. Can't locate it with the search either. <_< same here. anybody can help ? Quote Link to comment Share on other sites More sharing options...
Headhunter Posted July 11, 2007 Share Posted July 11, 2007 3. remove the charcoal canister. This saves weight and the thing only gets in your way during oil filter changes. And it is to be found where, exactly? :blink: To the right of your oil filter. It looks like a big black painted apple juice can. What is the purpose of this black apple juice can? Will it hurt anything to remove it? Quote Link to comment Share on other sites More sharing options...
Guest bsd43 Posted July 15, 2007 Share Posted July 15, 2007 What is the purpose of this black apple juice can? Will it hurt anything to remove it? It's to capture gasoline fumes when the engine is stopped so that it doesn't vent to the environment, then reuse it the next time the engine runs. Eenh, I'd say keep it. Quote Link to comment Share on other sites More sharing options...
Member Contributer PorradaVFR Posted January 28, 2008 Member Contributer Share Posted January 28, 2008 Just occurred to me that the ball thing would make a nice RAM mount if the size is similar. Hello rear-facing footage! :thumbsup: 1 Quote Link to comment Share on other sites More sharing options...
Guest SixD7 Posted June 22, 2008 Share Posted June 22, 2008 Anyone remove the metal heat shield behind the right drivers peg? If so any adverse affects? Might look better without it and it can't provide that much heat protection. What about removing the lower chain guide/guard. Also doesn't look like it does much and will look cleaner without it. Quote Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted June 22, 2008 Member Contributer Share Posted June 22, 2008 Anyone remove the metal heat shield behind the right drivers peg? If so any adverse affects? Might look better without it and it can't provide that much heat protection.What about removing the lower chain guide/guard. Also doesn't look like it does much and will look cleaner without it. Been done. Gives a hot foot. Chainguard done too. Not sure where the threads are. Quote Link to comment Share on other sites More sharing options...
Member Contributer achfly Posted June 22, 2008 Member Contributer Share Posted June 22, 2008 Anyone remove the metal heat shield behind the right drivers peg? If so any adverse affects? Might look better without it and it can't provide that much heat protection.What about removing the lower chain guide/guard. Also doesn't look like it does much and will look cleaner without it. are you talking about the guard on the up pipe? Or attached to the peg? I bought my bike with Micron exhaust already on it and it didn't have the heat sheild on the up pipe. 17k miles later still no problems with that. And I do like the looks of the pipe that way. If you're talking about the little wing shaped guard on your footpeg? ... well, ya need that buddy. For the twisties! :fing02: 1 Quote Link to comment Share on other sites More sharing options...
soichiro Posted June 22, 2008 Share Posted June 22, 2008 Anyone remove the metal heat shield behind the right drivers peg? If so any adverse affects? Might look better without it and it can't provide that much heat protection.What about removing the lower chain guide/guard. Also doesn't look like it does much and will look cleaner without it. are you talking about the guard on the up pipe? Or attached to the peg? I bought my bike with Micron exhaust already on it and it didn't have the heat sheild on the up pipe. 17k miles later still no problems with that. And I do like the looks of the pipe that way. If you're talking about the little wing shaped guard on your footpeg? ... well, ya need that buddy. For the twisties! :fing02: No he is talking about the black piece of tin behind the peg. With it off you can see the pipes and it looks good. I bet it blocks more heat than you think. Quote Link to comment Share on other sites More sharing options...
Member Contributer ASPHALT04 Posted August 5, 2008 Member Contributer Share Posted August 5, 2008 REAR SUSPENSION:Mod:Â Increase rear ride height by shimming under top shock mount Benefits:Â Improved handling due to steeper head angle, reduced trail, increased cornering clearance How to:Â Add approximately 4mm of shims under top shock mount to raise ride height ~12mm. Time:Â Cost:Â $0 Permanance:Â Completely reversible. <{POST_SNAPBACK}> Could anyone help me find anymore information regarding this mod of shimming the top shock mount? My searches are coming up empty... I think you just needs some M10 washers....I found this http://www.nabble.com/rear-shock-question-td2715158.html and am considering trying this myself. Quote Link to comment Share on other sites More sharing options...
KanadianKen Posted April 6, 2009 Share Posted April 6, 2009 Bumpity bump bump....... Quote Link to comment Share on other sites More sharing options...
Heikes Posted April 26, 2009 Share Posted April 26, 2009 The small section talking about that can by the oil filter, does it sit on the from lower part of the motor under the front part of the header. I think the manual says something about being part of the california model or something. Is that needed? Quote Link to comment Share on other sites More sharing options...
Beck Posted April 26, 2009 Share Posted April 26, 2009 The small section talking about that can by the oil filter, does it sit on the from lower part of the motor under the front part of the header. I think the manual says something about being part of the california model or something. Is that needed? Noooo, don't touch that can or the "g-men" will be on your back lickety split, sending you to the slammer for breaking EPA laws!! :huh: ........BTW, it's there to capture polluting "farts" from your gas tank :laugh: . Beck 95 VFR Quote Link to comment Share on other sites More sharing options...
Guest Cogs69 Posted May 24, 2010 Share Posted May 24, 2010 I just got my '02 VTEC for a song, and was able to pay cash, but not much left for mods right now. Great bike, but definitely could use some improvements, especially in the FI and suspension. I've been searching the forum, but thought it'd be cool to have a list of little to no cost mods to improve the bike, with comments on their benefits. Should be a good FAQ once compiled, and my bike is bone stock now, so I'm willing to be a guinea pig. Mostly looking for improved driveability and suspension performance, also aesthetic (visual and/or aural). I think weight reduction would be another good catagory. By low-budget, I mean: free, using (adjusting, modifying, or removing) stock parts (or used parts from other models) if possible or worthwhile, or the most cost-effective aftermarket options. For example, a new Ohlins USD fork would be nice, but Race Tech springs, gold valves, and rebound pistons and adjuster caps from an F4, while not free, would be more cost-effective for the majority of riders. Please add comments, links to how-to threads, and any new mods. I'll compile and edit as we go along, and add my impressions as I perform the mods. Feel free to PM me, or just reply. Let's go! -David INTAKE SYSTEM Mod: Flapper valve disable Benefits: Smoother acceleraton through 5k rpm??? Sound enhancement at low rpms? How to: Lift fuel tank, pull vacuum hose off of flapper control valve diaphram on top of air box, plug hose with bolt, secure with zip tie (optional). How it works: Disconnecting the vacuum hose will keep the flapper valve from closing the second intake opening under the control valve. Time: 5 minutes Cost: $0 Permanance: Completely reversible. Help: got to http://www.vfrdiscussion.com/forum/index.php?page=parts click on "Air Cleaner" for drawing Mod: Remove intake snorkel Benefits: Sound enhancement at WOT, possible performance benefit due to less restriction. How to: Lift fuel tank, pull snorkle out of right front of airbox lid. Time: 5 minutes Cost: $0 Permanance: Completely reversible. Help: got to http://www.vfrdiscussion.com/forum/index.php?page=parts click on "Air Cleaner" for drawing EXHAUST SYSTEM Mod: De-baffle stock exhaust Benefits: Sound enhancement, possible performance benefit due to less restriction. How to: Time: Cost: $0 Permanance: Not reversible without buying another stock exhaust. FUEL SYSTEM Mod: Adjustable fuel pressure regulator (FPR) Benefits: Improve drivability by reducing lean running conditions How to: Time: Cost: $130 (retail) Permanance: Completely reversible. Mod: Dynojet Power Commander (PCIII) Benefits: Improve drivability by modifying fueling maps How to: Time: Cost: Permanance: Completely reversible. FRONT SUSPENSION Mod: Heavier fork oil Benefits: Increased compression and rebound damping with stock internals How to: Time: Cost: Permanance: Completely reversible. Mod: Raise forks in triple-clamps Benefits: Improved handling due to steeper head angle, reduced trail How to: Time: 20 minutes Cost: $0 Permanance: Completely reversible. Mod: Replace fork springs with Race Tech appropriate for rider weight and use Benefits: Improved handling, reduced brake dive. Stock springs are too soft. How to: Time: Cost: $110 (retail) Permanance: Completely reversible. Help: got to http://www.racetech.com/evalving/SpringRat...SpringType=Fork to choose your rate, or direct (15% discount for VFRDG) or through your favorite vendor REAR SUSPENSION: Mod: Increase rear ride height by shimming under top shock mount Benefits: Improved handling due to steeper head angle, reduced trail, increased cornering clearance How to: Add approximately 4mm of shims under top shock mount to raise ride height ~12mm. Time: Cost: $0 Permanance: Completely reversible. Any chance to get the broken links fixed? I'm about to do a search, but for the ease of other newcomers it would be nice to have the links work again. These just take me to the homepage. :warranty: Quote Link to comment Share on other sites More sharing options...
Guest ThomasNielsen Posted May 24, 2010 Share Posted May 24, 2010 Remove the stickers on the fuel tank - Use only unleaded fuel - Always wear protective gear Improves the look and lower the weight with up to .5 g. Quote Link to comment Share on other sites More sharing options...
Guest PlayWithGravity Posted June 22, 2010 Share Posted June 22, 2010 Remove the stickers on the fuel tank - Use only unleaded fuel - Always wear protective gear Improves the look and lower the weight with up to .5 g. Got any great advice about removing the stickers from the tank without messing up the finish? Quote Link to comment Share on other sites More sharing options...
Member Contributer swimmer Posted June 22, 2010 Member Contributer Share Posted June 22, 2010 Remove the stickers on the fuel tank - Use only unleaded fuel - Always wear protective gear Improves the look and lower the weight with up to .5 g. Got any great advice about removing the stickers from the tank without messing up the finish? Goo Gone. Quote Link to comment Share on other sites More sharing options...
Member Contributer thor294 Posted June 24, 2013 Member Contributer Share Posted June 24, 2013 Broken links do need to be fixed... :) Quote Link to comment Share on other sites More sharing options...
divrnr Posted March 10, 2016 Share Posted March 10, 2016 I did the PAIR, flapper, and snorkel mod and noticed a 1 to 2 MPG better gas mileage on average. That's over the last 2,000 miles. Happy so far. Quote Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted March 11, 2016 Member Contributer Share Posted March 11, 2016 I just got my '02 VTEC for a song, and was able to pay cash, but not much left for mods right now. Great bike, but definitely could use some improvements, especially in the FI and suspension. I've been searching the forum, but thought it'd be cool to have a list of little to no cost mods to improve the bike, with comments on their benefits. Should be a good FAQ once compiled, and my bike is bone stock now, so I'm willing to be a guinea pig. Mostly looking for improved driveability and suspension performance, also aesthetic (visual and/or aural). I think weight reduction would be another good catagory. By low-budget, I mean: free, using (adjusting, modifying, or removing) stock parts (or used parts from other models) if possible or worthwhile, or the most cost-effective aftermarket options. For example, a new Ohlins USD fork would be nice, but Race Tech springs, gold valves, and rebound pistons and adjuster caps from an F4, while not free, would be more cost-effective for the majority of riders. Please add comments, links to how-to threads, and any new mods. I'll compile and edit as we go along, and add my impressions as I perform the mods. Feel free to PM me, or just reply. Let's go! -David INTAKE SYSTEM Mod: Flapper valve disable Benefits: Smoother acceleraton through 5k rpm??? Sound enhancement at low rpms? How to: Lift fuel tank, pull vacuum hose off of flapper control valve diaphram on top of air box, plug hose with bolt, secure with zip tie (optional). How it works: Disconnecting the vacuum hose will keep the flapper valve from closing the second intake opening under the control valve. Time: 5 minutes Cost: $0 Permanance: Completely reversible. Help: got to http://www.vfrdiscussion.com/forum/index.php?page=parts click on "Air Cleaner" for drawing Mod: Remove intake snorkel Benefits: Sound enhancement at WOT, possible performance benefit due to less restriction. How to: Lift fuel tank, pull snorkle out of right front of airbox lid. Time: 5 minutes Cost: $0 Permanance: Completely reversible. Help: got to http://www.vfrdiscussion.com/forum/index.php?page=parts click on "Air Cleaner" for drawing EXHAUST SYSTEM Mod: De-baffle stock exhaust Benefits: Sound enhancement, possible performance benefit due to less restriction. How to: Time: Cost: $0 Permanance: Not reversible without buying another stock exhaust. FUEL SYSTEM Mod: Adjustable fuel pressure regulator (FPR) Benefits: Improve drivability by reducing lean running conditions How to: Time: Cost: $130 (retail) Permanance: Completely reversible. Mod: Dynojet Power Commander (PCIII) Benefits: Improve drivability by modifying fueling maps How to: Time: Cost: Permanance: Completely reversible. FRONT SUSPENSION Mod: Heavier fork oil Benefits: Increased compression and rebound damping with stock internals How to: Time: Cost: Permanance: Completely reversible. Mod: Raise forks in triple-clamps Benefits: Improved handling due to steeper head angle, reduced trail How to: Time: 20 minutes Cost: $0 Permanance: Completely reversible. Mod: Replace fork springs with Race Tech appropriate for rider weight and use Benefits: Improved handling, reduced brake dive. Stock springs are too soft. How to: Time: Cost: $110 (retail) Permanance: Completely reversible. Help: got to http://www.racetech.com/evalving/SpringRat...SpringType=Fork to choose your rate, or direct (15% discount for VFRDG) or through your favorite vendor REAR SUSPENSION: Mod: Increase rear ride height by shimming under top shock mount Benefits: Improved handling due to steeper head angle, reduced trail, increased cornering clearance How to: Add approximately 4mm of shims under top shock mount to raise ride height ~12mm. Time: Cost: $0 Permanance: Completely reversible. Any chance to get the broken links fixed? I'm about to do a search, but for the ease of other newcomers it would be nice to have the links work again. These just take me to the homepage. It may be that those posts have been purged. Going to the end of the modifications section, there's only a handful prior to 2006. The generations sections were recently purged to no more than 600 days old, so many links there are no longer working, either. Quote Link to comment Share on other sites More sharing options...
