ca315 Posted January 27, 2020 Posted January 27, 2020 For those of you who like a VFR800 sound track, this is a clip from one of the track day sessions yesterday at Phillip Island. Speedo and tacho in the shot. https://www.youtube.com/watch?v=hO5JZZgC5Vo&t=740s Some highlights; geese on the track at 1:40 and a dice with a CBR1000 starting at 14.00, he runs wide at 14:44. He could only get me on the straight. VFR is a 99 model, performance mods: · Power commander · Air box mods · BMC air filter · Wilbers suspension front and read · Brembo disk and pads · Galfer braided lines · Metzler M7 tires · Staintune exhaust (no restrictor) I had an aversion to scratching it, so not pushing as hard as you could. I was lapping around the 2:10 mark, best 2:07. To give a comparison I was sharing the garage with a 2016 BMW 1000RR, he had just bought it and got down to 2:03 at the end of the day and 275km/h down the straight vs my 210km/h (speedo has a HealTech SpeedoHealer on it, so it is accurate). More experienced riders on the same BWM’s on slicks were around 1:53. So not bad for a 21 year old bike on road tires. 2 Quote
Member Contributer Philois1984 Posted January 28, 2020 Member Contributer Posted January 28, 2020 Loved watching the video ca135, looked like great fun. The bike sounded great. A track day at Philip Island is on my bucket list. Thanks for posting the video. Quote
squirrelman Posted January 29, 2020 Posted January 29, 2020 great fun and exciting to watch, but it took my pulse 10 minutes to return to normal . Quote
Tiutis Posted January 30, 2020 Posted January 30, 2020 Great riding- nice and smooth controls. And that sound! Quote
Member Contributer MaxSwell Posted February 5, 2020 Member Contributer Posted February 5, 2020 Very nice video. I really enjoyed it. I am curious; do you check your tach as you approach redline or do you just wait for the rev limiter to cut-out? Quote
ca315 Posted March 10, 2020 Author Posted March 10, 2020 Here is another clip https://www.youtube.com/watch?v=iUoJKmMqkqs&t=259s from 9 March 2020 Quote
Member Contributer MaxSwell Posted March 10, 2020 Member Contributer Posted March 10, 2020 The superior brakes on the fifth gens are obvious in this clip! Quote
ca315 Posted March 14, 2020 Author Posted March 14, 2020 Here is another sound track from Phillip Island 6 Mar 2020, this one has speed and track position. 1 Quote
Member Contributer MaxSwell Posted March 14, 2020 Member Contributer Posted March 14, 2020 I really like this one with speed, rpm and postion on the track. Quote
ca315 Posted March 15, 2020 Author Posted March 15, 2020 Hero 5 onwards record GPS data in the file, it is extracted and overlaid using Dashware http://www.dashware.net 1 Quote
ca315 Posted March 20, 2020 Author Posted March 20, 2020 On 2/6/2020 at 5:32 AM, MaxSwell said: Very nice video. I really enjoyed it. I am curious; do you check your tach as you approach redline or do you just wait for the rev limiter to cut-out? I watch the tacho, change up around 11k. Max power is around 10k, so drops just below max power when you change. 1 Quote
JimMoore Posted March 20, 2020 Posted March 20, 2020 On 3/14/2020 at 6:43 PM, ca315 said: Here is another sound track from Phillip Island 6 Mar 2020, this one has speed and track position. My man, that looks like fun, but you gotta work on those shifts. You're spending too much time in between gears and your rpm is getting all out of whack. Try this. First, quit using the clutch on your upshifts. As you approach max rpm, preload the shifter, then roll off slightly and immediately back on the throttle. You'll find yourself in the next gear so quickly and so smoothly you won't believe it. Downshiftiing is a little trickier, but you can smooth that out too. There are two scenarios that require different techniques. Typically you're on the brakes and at idle while you downshift. Try rolling the throttle open a little bit while you downshift. Try to get the rpm to stabilize or even increase, so you're already at the correct rpm for the next lower gear. Sometimes you're at a steady throttle state and you want to downshift to get to a lower gear for a certain corner. Here's a great trick. Preload the shifter, hold the throttle steady, and start to squeeze the clutch. As the clutch disengages the bike will shift to the next lower gear, AND the rpm will increase so you're already at the correct rpm. Money! (Coming into turn 2 looks like the perfect place to use that technique.) Two other thoughts. I think you're shifting too early, especially on the front straight. There's still a lot of hp up above 11K rpm. I'd hold it wide open until at least 12K, then quick shift as discussed above. I'll bet you end up 10-12 kph faster at the end of the straight. You have good telemetry there so it will be pretty easy to see which technique works better. I also think you're a little low on rpm in the corners. I might try adding a tooth in the back so you have a little more drive out of those corners. I actually went with -1/+1. It REALLY made a difference. Completely different bike. Hey, feel free to disregard it all. There's nothing worse than some dickhead picking apart your riding videos. But what the hell, everyone is stuck inside and we'll all be dead in a month anyway. 1 Quote
Member Contributer bmart Posted July 16, 2020 Member Contributer Posted July 16, 2020 Appreciate you posting these. As a track day coach, I particularly enjoyed them! I'd love to run that track one day...and Portimao. Here's a pic from last year when I took the two street bikes to CMP in Kershaw, SC (which they are FINALLY repaving!) Quote
