SEBSPEED Posted May 2, 2014 Share Posted May 2, 2014 Don't have my manual handy, trying to figure out where the 3 hoses shown below link to. What do 20, 21, and 22 link to? Airbox? Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted May 2, 2014 Member Contributer Share Posted May 2, 2014 Seb, I forget what they attach to but after we synched our carbs through those barbed connectors we installed 4 small Phillips screws in the holes using little rubber washers. The screws we used were found on the parts fiche...IIRC the hoses run to a small vacuum canister or the airbox. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 2, 2014 Member Contributer Share Posted May 2, 2014 Link to comment Share on other sites More sharing options...
SEBSPEED Posted May 2, 2014 Author Share Posted May 2, 2014 I don't see them in any of the pics Dutchy Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 2, 2014 Member Contributer Share Posted May 2, 2014 maybe #9 and #10 in this EU diagram? 4th gen 3rd gen Link to comment Share on other sites More sharing options...
SEBSPEED Posted May 2, 2014 Author Share Posted May 2, 2014 No, those are fuel tubes. The hoses in my picture link the intake ports on the cylinder head to... something. The rear head has plugs to block off the connections per the fiche. Link to comment Share on other sites More sharing options...
Member Contributer hondalover Posted May 2, 2014 Member Contributer Share Posted May 2, 2014 Vacuum operated petcock, and purge valve? I'm not even sure they have vacuum operated petcocks since they have a fuel pump. Link to comment Share on other sites More sharing options...
SEBSPEED Posted May 2, 2014 Author Share Posted May 2, 2014 Anyone have a complete bike they can peek at? Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted May 2, 2014 Member Contributer Share Posted May 2, 2014 Capture3.JPG Isn't it in this drawing? Near #20 and #11 on the lower pic is a tee. Ciao, Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 2, 2014 Member Contributer Share Posted May 2, 2014 to the pair system. take out the ports , block them off with a screw and throw the crap in the trash.. dont forget to block off the holes on the head. pm sent Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted May 2, 2014 Member Contributer Share Posted May 2, 2014 I think the one on Cylinder 1 actually goes to something (airbox maybe?), but the other three are just capped off. Might be part of the PAIR system. Link to comment Share on other sites More sharing options...
Member Contributer apexandy Posted May 3, 2014 Member Contributer Share Posted May 3, 2014 My bike looks just like the diagram dutchy posted. I have nothing but the factory rubber caps on those intake nipples. Must be part of the PAIR system. My particular Canadian bike didn't have any of the PAIR system. I only use those ports for synching the carbs. Sorry I can't say more about where they go... But maybe removing them is the best option? Link to comment Share on other sites More sharing options...
SEBSPEED Posted May 3, 2014 Author Share Posted May 3, 2014 I'm putting together a list of small odds and ends to order, looks like I'm getting 4 fresh caps. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted May 3, 2014 Member Contributer Share Posted May 3, 2014 I'm putting together a list of small odds and ends to order, looks like I'm getting 4 fresh caps. I picked up some caps at a local hardware store for cheap. Not sure how much they are from Honda, but I'd guess at least a couple bucks each. Link to comment Share on other sites More sharing options...
SEBSPEED Posted May 3, 2014 Author Share Posted May 3, 2014 I looked this morning, I think they were just under $1 each. The airbox screws on the other hand... Hoo-doggie... Don't lose those! Link to comment Share on other sites More sharing options...
mcrwt644 Posted May 3, 2014 Share Posted May 3, 2014 Those ports come off on to vacuum lines. Used to sync carbs too. GLL is right on as usual as well Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted May 3, 2014 Member Contributer Share Posted May 3, 2014 The caps we had on a couple of ours we cracked and leaky so we went with the Honda part for the screw that fits that hole after we completed our post rebuild carb synch. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 3, 2014 Member Contributer Share Posted May 3, 2014 The caps we had on a couple of ours we cracked and leaky so we went with the Honda part for the screw that fits that hole after we completed our post rebuild carb synch. you mean a screw that costs 7 cents at home depot? thats what i tell everyone to use. forget the caps!! Link to comment Share on other sites More sharing options...
