Member Contributer awacs Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 At 107k miles, I guess things like this happen. The boss (or whatever you call it) with threads for the middle bolt on the rear cowl broke off. If I have to ride with that bolt missing, so be it. But is there a reasonable way to fix it? Thanks, Aram Link to comment Share on other sites More sharing options...
Member Contributer ggathagan Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 It'd take a little investigation, but maybe you could find something that would fit snugly inside of that tube, like a length of threaded rod or a piece of round bar stock. Then maybe J B Weld, similar epoxies or even getting it tack-welded might suffice to hold it. Link to comment Share on other sites More sharing options...
Member Contributer JeffInFranklinTN Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 I think a body shop could weld that back on there real pretty like. It'd take a little investigation, but maybe you could find something that would fit snugly inside of that tube, like a length of threaded rod or a piece of round bar stock. Then maybe J B Weld, similar epoxies or even getting it tack-welded might suffice to hold it. I was thinking this also. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 just weld it back. Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 It'd take a little investigation, but maybe you could find something that would fit snugly inside of that tube, like a length of threaded rod or a piece of round bar stock. Then maybe J B Weld, similar epoxies or even getting it tack-welded might suffice to hold it. Mine went at about 50K I'd say. I used some all thread, cut to length, and screwed in to both ends. It's been good for 40K since then. You can just see the threaded rod through the crack. Link to comment Share on other sites More sharing options...
keny Posted January 23, 2014 Share Posted January 23, 2014 I wounder why they break? There should not be that mutch stress on them, just holding the plastic tail part partly. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 unless you have a givi attached ...looks like a weak link Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 Maybe a little excess weight ? Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 +1 on the threaded rod. Clean both ends up, tap them, run a threaded rod with some loctite on it. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 vfrcapn's solution looks good. I've never heard of that breaking without the GIVI. Luckily my WingRack doesn't use that bit to mount. Link to comment Share on other sites More sharing options...
Member Contributer awacs Posted January 23, 2014 Author Member Contributer Share Posted January 23, 2014 Thanks, all. I don't weld (though a friend offered to). The threaded rod solution is brilliant, thanks. Yep, I have run a big Givi top case for years. This little guy finally gave it up. Not only did this mount snap off, but Givi's top case support cleaved in 3 places. Again. I've gone through like 3 of those. I probably overload the case a little, from time to time, but not much or often. Those things are totally under-built. I need a real solution -- and KanadienKen is not building any 5th gen mounts.So I am case-less. :( But I digress.) Switchblade don't know me very well, do he? I'm trying to put a little bulk back on. Also trying to put a little extra weight on the pillion seat, if you know what i mean, but we'll see how that goes. Thanks again for the ideas. Really appreciate it. Aram Link to comment Share on other sites More sharing options...
Member Contributer y2kvfr Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 Mine broke when I had the Givi tail rack w/o the upgrade (upgrade added some flat stock). I put some thread rod in, drilled a couple of holes along the that pipe, and tacked the rod in (well, a friend did, as I don't weld). He then welded that 'bung' back on with the rod in it. IIRC it was 3/8" threaded rod. I took the subframe off the bike so as not to mess with the electrics when welding and to be able to clean everything up for the welding process. Link to comment Share on other sites More sharing options...
Member Contributer JeffInFranklinTN Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 I wounder why they break? There should not be that mutch stress on them, just holding the plastic tail part partly. Could it be from moving your arse over on the edge of your seat when hitting the twisties fast and rigorous? Now looking at the pic of my bike...I wouldn't think that would be causing it........ Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 It's the GIVI. The seat rests entirely on the subframe. It's surprising, really, that GIVI would have designed it that way. I think it was just the lightweight tubular style rack? I know my full WingRack bolts to the subframe using the passenger grab handle mounts, then extends down to the passenger pegs for lower support. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted January 23, 2014 Member Contributer Share Posted January 23, 2014 Lots of good ideas here.... mine is fit a rod that slides into the I.D. and throw in JB weld and then pin it. Lowes stocks an assortment of roll pins. Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted January 24, 2014 Member Contributer Share Posted January 24, 2014 MIne was probably the Givi hanging off. I had the seat cowl on when it snapped, causing the frankenbolt to just spin. Just take the seat off to get to the broken end, after taking off the seat cowl, after removing the frankenbolt, which is just spinning... Link to comment Share on other sites More sharing options...
