Sign in to follow this
V4Supremacy
Hid Projector Headlights
Two questions:
1. Did you only have to 'bake" it once or did you need to put it back in the oven before you were able to disasemble the housing?
2. It looks like your projectors have the "halo" ring, did you opt for the "Angel Eyes"?
Cheers
Share this post
Very interesting...... I've threatened myself for the last bunch of years to do the Modification that runs all four bulbs at once - but this is a mod that might be even more beneficial.
I believe that its illegal to run more than two head lamps at once (at least here in Canada it is) so if I'd done the 4 lamp system, and the law wanted to write me up - they could have.
Please continue to post up your results. Where are you mounting the ballasts - or are they internal?
:fing02:
Share this post
:offtopic: I won't be mounting them just yet, as I have ordered a white and black euro style fairing kit, which hasn't arrived yet. My bike is Candy Glory Red, but i'm planning on doing a white and black theme with white powder-coat wheels. The stock silver-ish finish on the wheels is just so...MEH.
I can't wait to see how this will look. I think the VFR is one bike that looks really good in White and some of the non US offerings that have the B&W colors look very cool. Do keep us up to date with pics. I am really interested in how the halo lights look head on.
Share this post
Looking good.
My own take on halos is that they're not really very noticeable when the lights are on--and they always are on a motorbike, no?
Ciao,
Share this post
How does the projector stay? Is it screwed into the factory reflector housing?
Share this post
As far as I know there are no internal ballasts unless it is some high end cage and the projectors would be even bigger to accomodate them. Not something you would want for the VFR.
You probably could have freed up some space by removing the lower reflector. Something you may want to consider as you don't want the projector touching the lens. Vibrations will cause scuffing of the projector and create hot spots in you beam pattern. That and the heat of the projector could potentially melt the lens over time also causing beam pattern distortions.
I know this means baking it again but you probably want to do this anyway because it will be easier to adjust the projectors with the lens off anway to make sure you have a nice horizontal spread when you test everything on the VFR.
Still, this is looking very nice and I give you massive kudos for doing HID the right way. :fing02:
Here's a how-to for HID projector a guy did on another bike: http://www.theretrofitsource.com/pdf/trs_tech/Sportbike_Stage_III_Retrofit_Kit.pdf
Share this post
The OEM D1S system used internal (integrated, really) ignitors, and this was the type of system used in the infamous "PHID" driving lights that were once popular with the LD riding crowd. The advantage of doing it that way was that all of the wiring going to the projector unit could be regular 16-ga or so, rather than the high-voltage wire used by the D2S-type systems (which used to have separate igniter and ballast, but now incorporate both igniter and ballast into one unit). There are also D2S OEM systems that have igniters built into the bulb holders (rather than being part of the bulbs themselves), and these are very compact, too, and can use regular wires. Yes, I've been studying this topic for quite a while: I may never have finished a single xenon retrofit project during that time, but I've got boxes of xenon-related crap in two countries! :tongue:
Ciao,
Share this post
"I believe that its illegal to run more than two head lamps at once (at least here in Canada it is) so if I'd done the 4 lamp system, and the law wanted to write me up - they could have."
If so, how do they sell HArley's with the 3 headlight setup(THE most visible bike system btw...)
Share this post
The two side lamps on the harleys are called, fog lights so they can get away with it, but I have a car that does run with the lows and highs on at the same time when I turn on the highs, it just depends on the country and there laws
Share this post
Good to see someone doing a HID install the right way not just replacing a halogen bulb with a HID, and blinding everyone with glare while decreasing their useable field of vision.
Edited by MBrane
Share this post
And the purpose of baking your parts is? :unsure:
Does it release some adhesive or something?
Obviously I have not read the instructions. :sleep:
Share this post
Yep. Softening the glue that binds the shield to the housing.
Share this post
Grazi. I guess it should be obvious that we don't need no stinking screws for electronics these days.
At least not the cases. Glue is the word. :goofy:
Share this post
... project ... in progress ...
(the dirty spots & splashes are dead insects from the week end ride)
Share this post
I really like that.
Share this post
That looks like a pissed off 4 eyed bird, lol!! You got a lot going on in those housings. Pretty cool
Share this post
PUT DOWN THE BLING AND BACK AWAY FROM THE VEHICLE. DO IT NOW... :biggrin:
Ciao,
Share this post
The most difficult thing was to fit all the wires, ballast and igniters under the fairing. Unfortunately one 4300K was busted so I need to find a replacement. I'll need to make a beam adjustment and I should be good to go.
To open up the headlight is not difficult and it wend much faster than expected after seeing the tutorials on youtube. 2-3 min with the hot air gun and it was done. I had to trim the upper projector's shroud to fit on the lower part. I did not make any pictures since there are plenty instructions on the net and/or youtube.
The bling factor is made by blue angel eyes, red devil eyes and yellow led strip - my national colors. Beside the management of the multitude of wires, there was no trouble. Like the bulbs, these are powered up only if the engine is running (see below) and I have the possibility of switching them on in steps - first the angel eyes and the strip; - second step all together.
The lights are all bi-xenon (4300k on lower and 6000k on upper) with possibility of switching them on either 2 by 2 or all together which basically means 4 bulbs on low or high beam simultaneously. Although HID are more economical than normal ones, the starting current is much higher and that puts to the stress the entire electrical circuit. For this reason the stock wiring should not be used and the assembly should be powered up directly from the battery with a higher section wire than stock. It is advisable to use also the kit from or similar to the ones on wiremybike.com. I am using a VFRness bundle with some extra mods. An extra 10 slots fuse panel which is powered up through a relay only when the engine is running and the RR is producing energy - I hated the fact that before starting the engine the lower beam was on squeezing energy from sometimes drain battery. Also the left side projectors are connected through some delay relays and starting with an almost 8 sec later than the right ones - for the same reason of stressing the electric circuit.
Later I'll make some more pictures and a small phone made movie.
Cheers.
Share this post
Did you use my HID wiring kit with the projectors to get the Latch and Delay functionality? I don't recall sending any to Romania but I have mailed them all over. I am not keen on the LED strip...the rest looks good and the camera makes the light look more purple than it probably is given the color temperatures you went with.
Share this post
The answer is no, I did not get the HID harnes from you. I'm a seaman and last year, while going (regularly) to Hueneme, I got the agent to order the VFRness bundle for me.
I received from the ebay seller that sold me all the projectors, for free, also the controllers with the appropriate harness. It was a struggle to find place for everything. Unfortunately one of the controllers was defective - probably an internal short circuit between the power and the High beam signal. Because I did not have the patience to disassemble the controllers, I simply kick them out and in place I'm using two (one for each pair of bulbs) normal/basic auto relays to power up the bulbs. The high beam signal is going straight to each projector's coil.
The delay functionality I've made it using adjustable relays (normal auto relays with a knob adjuster 1-50 sec). They are set up for aprox 7 and 12 sec so that, if all 4 projectors are powered up simultaneously, 2 will fire up immediately and the other two long enough for the power/current consumption to settle down.
The latch is from my Cheetah VizAlert and is "...intelligent “engine running” sensor, the POWERSENSEnode, which you just attach directly to the battery terminals. This clever little gizmo automatically powers up your detector or jammer when you start up the engine, and shuts them down when you stop, so there’s no risk of a flat batteries" - quote from the maker's web site. It is connected to the VFRness and give-s the signal to power up the relay/fuse box. The fuse box is under the seat, but in parallel with it I have another 10 fuse box rooted to the right front side (now I have only 2 free slots).
I thought of ordering from you but the shipping and the custom fee did not made it worth. Next time I'll reach US I'll try to get a RR, even though the OEM is still working great.
The picture taken is not showing the real view - it was dark and the camera (an Iphone4) messed up the colors. Have more patience for more pictures, please. Time, right now, is something that I lack.
Cheers!
Share this post
I'd be interested in seeing the light pattern from the pilot seat... on-road and against a wall.
Share this post
That's a massive amount of light! Pretty cool. I was wondering how well the bi-xenon would look with the factory high beams & I like it. Can you run just the halo's while riding?
Share this post
My project is still unfinished. I decided, when I'll start working, to ditch the LED strips. Just the projectors are good enough. I'm still waiting for one of the bulb's replacement (one was busted on first firing - bad things happens sometimes). I need to reopen the headlights because the projectors does not have the same cut off line on low beams and I'll use the opportunity to take off the LED - I'll find another use 4 it.
@V4Supremacy - nice work! Ballasts are under the side fairings, behind the ECU (on the right) and ABS controller (on the left).
Share this post
