Veefer800Canuck Posted January 12, 2012 Share Posted January 12, 2012 I think I may have half-heartedly asked this before, but now I'm serious. I'm a-gonna paint my rear brake caliper to match the fronts. Here's a pic of them. Any suggestions on hopefully matching the colour??? Link to comment Share on other sites More sharing options...
DaveM Posted January 12, 2012 Share Posted January 12, 2012 Summit Racing ( and possibly auto parts stores) VHT SP736 - VHT Brake Caliper, Drum, and Rotor Paints Paint, Brake, High-Temperature, Gloss, Gold, 11 oz., Aerosol Spray Can Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted January 12, 2012 Author Share Posted January 12, 2012 I think Canadian Tire carries the VHT paint. I'll have to see if it's remotely close to the shade I already have on the front (OEM colour). Website sez $12.99 per can, and promises that GOLD is in stock at my local store. We will see. They're closed right now, of course. Link to comment Share on other sites More sharing options...
Guest Posted January 12, 2012 Share Posted January 12, 2012 If you can't find the exact tint of gold you could use a whole new tint of gold perhaps. -Mike Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted January 12, 2012 Author Share Posted January 12, 2012 If you can't find the exact tint of gold you could use a whole new tint of gold perhaps. -Mike Don't really want to dismantle the front calipers and paint them too. The finish on them is perfect as-is. Link to comment Share on other sites More sharing options...
Member Contributer CasualSwede Posted January 12, 2012 Member Contributer Share Posted January 12, 2012 I think Canadian Tire carries the VHT paint. I'll have to see if it's remotely close to the shade I already have on the front (OEM colour). Website sez $12.99 per can, and promises that GOLD is in stock at my local store. We will see. They're closed right now, of course. If the website says they only have ONE can, on the other hand.... prepare to wait half an hour as a teenager wanders around the warehouse looking for it, even though the can probably doesn't exist anymore. I know, I used to work there. Link to comment Share on other sites More sharing options...
Snakeman Posted January 12, 2012 Share Posted January 12, 2012 Even if it is a close match it will work. Unless they are side by side you can't tell the difference of 2-4 shades off. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted January 12, 2012 Member Contributer Share Posted January 12, 2012 Summit Racing ( and possibly auto parts stores) VHT SP736 - VHT Brake Caliper, Drum, and Rotor Paints Paint, Brake, High-Temperature, Gloss, Gold, 11 oz., Aerosol Spray Can No good. He's canadian. He needs metric. Link to comment Share on other sites More sharing options...
SEBSPEED Posted January 12, 2012 Share Posted January 12, 2012 Ask VF1000RS what he uses. He's done a bunch of parts that look like that. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted January 12, 2012 Member Contributer Share Posted January 12, 2012 Taking apart the calipers is no big deal. Gives you a chance to clean the pistons really well, and I've cleaned off many a seal without replacing them. That said, those do look really nice and clean on the outside. So, I'd hate to paint over that nice finish. I can't think that a gloss gold spray on finish would look all that nice in comparison. What did you do to the caliper mount and caliper bolts? That just paint, or powder? Bought anodized bolts? Link to comment Share on other sites More sharing options...
SEBSPEED Posted January 12, 2012 Share Posted January 12, 2012 I think Rob knows better than to attach braking components with aluminum bolts... (!) Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted January 12, 2012 Member Contributer Share Posted January 12, 2012 You could probably buy a set of F4i calipers pretty cheap and paint them along with the rear to see how they turn out. F4i have the same piston sizes as SP1, assuming that's what you're currently running. Link to comment Share on other sites More sharing options...
Member Contributer Sparrow75 Posted January 24, 2012 Member Contributer Share Posted January 24, 2012 Hey Rob, I think you should paint the front calipers, as well. But while you are at it, drill a hole in each one and add a window so you can see the internals working! Just kidding. That would be unsafe, non? Can't wait to see this year's updates to the GL! Link to comment Share on other sites More sharing options...
Member Contributer sa1713 Posted August 19, 2014 Member Contributer Share Posted August 19, 2014 I have a chance to pick up some 6th gen ABS calipers in gold. Any reason they won't work on my non-ABS 5th gen? Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted August 19, 2014 Member Contributer Share Posted August 19, 2014 I have a chance to pick up some 6th gen ABS calipers in gold. Any reason they won't work on my non-ABS 5th gen? If you're talking about the front calipers, then I don't think you can use them, as the linked braking system is different on the two generations, different plumbing involved. Can it be done with modifications? probably, but much cheaper and easier to get the 5 gens powder coated or painted. As far as the rear goes, I know that the pistons are different sizes (6 gen being slightly bigger) but if the master cylinders (Rear and Secondary front) are the same then this should bolt right on. Link to comment Share on other sites More sharing options...
Member Contributer sa1713 Posted August 19, 2014 Member Contributer Share Posted August 19, 2014 Thanks for the info. Link to comment Share on other sites More sharing options...
BRad704 Posted August 19, 2014 Share Posted August 19, 2014 If it helps, this is the coloring the VHT gold caliper paint. Overcast day fwiw. Link to comment Share on other sites More sharing options...
Member Contributer sa1713 Posted August 20, 2014 Member Contributer Share Posted August 20, 2014 Nice pic. Thank you. Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2014 Share Posted September 17, 2014 The VHT stuff works great. It WILL, however, come off if you even THINK about dripping brake fluid on it. Even if you bake it. I did my rims and some bobs on my GS750... But it's easy enough to touch up. Link to comment Share on other sites More sharing options...
Question
Veefer800Canuck
18 answers to this question
