Guest jambie Posted September 9, 2008 Share Posted September 9, 2008 Just thought I'd post a pic of the cockpit setup I've got on my new '06 VFR/A. It consists of a Garmin Zumo 550 w/ XM, Passport 8500 w/ Marc's Visual Alert up on top above the speedo, and you can just barely make out the switch for the heated grips I just installed. It's just forward of the top screw on the left fairing next to the tank. The Zumo is mounted in a Touratech locking cradle (very trick) which is in turn mounted on a Ram 5.5" ball arm on the tank bolt ball mount. The Escort is mounted on a Ram handlebar mount. The visual alert is just velcro'd to the top of the instrument panel. The tie wrap around the Escort is to hold the visual alert jack into the unit, as it otherwise fits VERY loosely. This is all very similar to the setup I had on my '02 Blackbird, and functions very well. The only problem is not having come up with a theft-proof mount for the Escort :rolleyes: The separate Garmin XM entenna rides in the clear map pocket of my tank bag, and all are powered through the Powerlet setup I installed in that. If anyone wants more pics, I'll be happy to send them along. Thanks again, everyone, for all the advice! Cheers, Tom Cockpit Link to comment Share on other sites More sharing options...
timmythecop Posted September 9, 2008 Share Posted September 9, 2008 all youare missing is the button marked "Booze" dont forget to post any future problems or lessons learned as you put mileage on that setup. Link to comment Share on other sites More sharing options...
Higgin Posted September 9, 2008 Share Posted September 9, 2008 You know, the more I think about it, the more I would like to have a Zumo. At first I thought it would be total overkill with me, but more and more, I find myself going on longer and longer trips, and having to stop every hour or so to pull out the map and have a look Either that or I end up using the patented Higgin "Analog GPS", which is somewhat embarassing to have to explain to someone what it is. Not to mention trying to decifer my chicken scratch while sitting at a stoplight or stop sign....lol But one of the things that worries me about a gps such as the zumo that costs like $500, is what do you guys do with them when you are off the bikes (such as being on a long trip, and stopping to get dinner and relax for an hour or 2)? I would be very afraid of them getting stolen. Or are they locked down well enough to make it difficult to steal? Seems to me that they would be easy to just pull right off. My thought was that whenever I take a trip of any distance, I always have my hard cases, and I figured I could lock it in there with my helmet, jacket, and gloves when I am leaving the bike. I know the hard cases aren't exactly "theftproof", but it would at least get it under lock and key and out of plain sight and would require someone to put at least a moderate amount of effort into stealing. That's my thought anyway? So what do you guys that have GPS units do with yours? Might be a nice Christmas gift to myself this year, since the g/f (and her pricey gifts) are long gone now....... Link to comment Share on other sites More sharing options...
Member Contributer doug5551 Posted September 9, 2008 Member Contributer Share Posted September 9, 2008 Jambie, I just saw in your post about how: The tie wrap around the Escort is to hold the visual alert jack into the unit, as it otherwise fits VERY loosely. I had the same issue when I purchased my Visual Alert, and ended up taking it to Marc Parnes's house in Huntington Beach, Ca for him to evaluate. It turns out that Escort changed some specs on the internals of the Passport, and that causes the problem with the VA connection. Please see this thread from the FJR forum where the issue is discussed in detail, with comments from Parnes. http://www.fjrforum.com/forum//index.php?showtopic=27361 The best solution to the issue is to dremel a little bit off the plastic case, and then it will fit snugly as it is supposed to. Please be careful, I do not want you to get a ticket because of this manufacturing issue, and I know personally that Marc Parnes does not want you to either. He is a great guy. Link to comment Share on other sites More sharing options...
marid2apterbilt Posted September 9, 2008 Share Posted September 9, 2008 all youare missing is the button marked "Booze"dont forget to post any future problems or lessons learned as you put mileage on that setup. What no Red toggle switch for NOS? Looks a little crowded? Link to comment Share on other sites More sharing options...
Baileyrock Posted September 9, 2008 Share Posted September 9, 2008 Looks like your set up nicely Tom! :rolleyes: Link to comment Share on other sites More sharing options...
Member Contributer hondalover Posted September 9, 2008 Member Contributer Share Posted September 9, 2008 Just one suggestion. Use the mount for the XM antenna on your front master cylinder. I drilled two holes in the plate, trimmed the usual mounting ears off, and then mounted it using longer allen head pan screws. If you want a pic, I can deliver when I find my camera. Link to comment Share on other sites More sharing options...
checksix Posted September 9, 2008 Share Posted September 9, 2008 You know, the more I think about it, the more I would like to have a Zumo. At first I thought it would be total overkill with me, but more and more, I find myself going on longer and longer trips, and having to stop every hour or so to pull out the map and have a look Either that or I end up using the patented Higgin "Analog GPS", which is somewhat embarassing to have to explain to someone what it is. Not to mention trying to decifer my chicken scratch while sitting at a stoplight or stop sign....lol That's funny, I do the same thing. I plot a route using google maps and write down a "strip chart" with route numbers, mileages and waypoints. Low tech, works great and it's less distracting than gps. Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2008 Share Posted September 10, 2008 But one of the things that worries me about a gps such as the zumo that costs like $500, is what do you guys do with them when you are off the bikes (such as being on a long trip, and stopping to get dinner and relax for an hour or 2)? I would be very afraid of them getting stolen. Or are they locked down well enough to make it difficult to steal? Seems to me that they would be easy to just pull right off. My thought was that whenever I take a trip of any distance, I always have my hard cases, and I figured I could lock it in there with my helmet, jacket, and gloves when I am leaving the bike. I know the hard cases aren't exactly "theftproof", but it would at least get it under lock and key and out of plain sight and would require someone to put at least a moderate amount of effort into stealing. That's my thought anyway? So what do you guys that have GPS units do with yours? The Touratech unit I'm using is spendy, but worthwhile for the peace of mind IMHO. Using it with a Ram locking friction knob for the stem mount really discourages the casual thief. Mine has worked very well so far. Touratech Locking Zumo Mount Cheers, Tom Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2008 Share Posted September 10, 2008 Jambie,I just saw in your post about how: The tie wrap around the Escort is to hold the visual alert jack into the unit, as it otherwise fits VERY loosely. I had the same issue when I purchased my Visual Alert, and ended up taking it to Marc Parnes's house in Huntington Beach, Ca for him to evaluate. It turns out that Escort changed some specs on the internals of the Passport, and that causes the problem with the VA connection. Please see this thread from the FJR forum where the issue is discussed in detail, with comments from Parnes. http://www.fjrforum.com/forum//index.php?showtopic=27361 The best solution to the issue is to dremel a little bit off the plastic case, and then it will fit snugly as it is supposed to. Please be careful, I do not want you to get a ticket because of this manufacturing issue, and I know personally that Marc Parnes does not want you to either. He is a great guy. Hi Doug, Thanks for the concern. I've used the tie wrap mod for close to 3 years now, both on my Blackbird and in the cage, and it's been rock solid. After I started using the visual alert on the bike, I started using it in the cage as well, since I didn't have to keep the tunes low enough to hear an alert. I also believe that our brains react more quickly to visual cues than to audible cues, so reaction time goes up. With that in mind, after a ride today I relocated the visual alert to a velcro mount on the inside top lip of my ZG Sport Touring screen. This gives me more of a "heads up" type of display and is more in my direct line of vision. The wire running to the Escort is a bit annoying, and if it were longer I could attach it with adhesive clips or something to the perimeter of the windscreen running down to the instrument panel, but, oh well... :unsure: Cheers, Tom Cockpit 2 Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2008 Share Posted September 10, 2008 Wow! Talk about task saturation, that cockpit is worse the the flight station on my KC-130J! Very well done to you it looks good. I think you should consider something like this if you can afford it. I don't have any direct contact with this product so I cannot endorse it, but from what I have read it's supposed to be pretty awesome. There are others but this is the only one I've found that you don't have to modify for detectors. -Chris. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted September 10, 2008 Member Contributer Share Posted September 10, 2008 But one of the things that worries me about a gps such as the zumo that costs like $500, is what do you guys do with them when you are off the bikes (such as being on a long trip, and stopping to get dinner and relax for an hour or 2)? I would be very afraid of them getting stolen. Or are they locked down well enough to make it difficult to steal? Seems to me that they would be easy to just pull right off. My thought was that whenever I take a trip of any distance, I always have my hard cases, and I figured I could lock it in there with my helmet, jacket, and gloves when I am leaving the bike. I know the hard cases aren't exactly "theftproof", but it would at least get it under lock and key and out of plain sight and would require someone to put at least a moderate amount of effort into stealing. That's my thought anyway? So what do you guys that have GPS units do with yours? The Touratech unit I'm using is spendy, but worthwhile for the peace of mind IMHO. Using it with a Ram locking friction knob for the stem mount really discourages the casual thief. Mine has worked very well so far. Touratech Locking Zumo Mount Cheers, Tom I have the same mount on my ST1300. I'd have preferred something a bit more secure (i.e., surrounding the unit with a stainless cage or bars or something), though the TT mount is the only locking one I know of for the Zumo. Of course, the next question is, how do you prevent someone from un-screwing the RAM ball where it attaches to the bike? I ended up making a custom mount for that, secured by "security Torx" stainless M8 bolts, but that's not exactly "high-security", given the ease at which anyone can get the appropriate security Torx bits. Should slow down the casual klepto some, though. Ciao, Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2008 Share Posted September 10, 2008 I have the same mount on my ST1300. I'd have preferred something a bit more secure (i.e., surrounding the unit with a stainless cage or bars or something), though the TT mount is the only locking one I know of for the Zumo. Of course, the next question is, how do you prevent someone from un-screwing the RAM ball where it attaches to the bike? I ended up making a custom mount for that, secured by "security Torx" stainless M8 bolts, but that's not exactly "high-security", given the ease at which anyone can get the appropriate security Torx bits. Should slow down the casual klepto some, though. Ciao, Ram makes a locking friction knob that replaces the one that comes on any double ended ball arm. When locked it simply free-wheels, preventing a would-be thief from removing the arm altogether... Cheers, Tom Link to comment Share on other sites More sharing options...
Guest Posted March 23, 2009 Share Posted March 23, 2009 Tom, I like the Zumo set up on your VFR. Do you know the RAM part number for the gastank bolt ball mount? I just picked up a VFR yesterday and that's exactly how I would like to mount my Zumo. Thanks! Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted March 23, 2009 Member Contributer Share Posted March 23, 2009 Just thought I'd post a pic of the cockpit setup I've got on my new '06 VFR/A. It consists of a Garmin Zumo 550 w/ XM, Passport 8500 w/ Marc's Visual Alert up on top above the speedo, and you can just barely make out the switch for the heated grips I just installed. It's just forward of the top screw on the left fairing next to the tank.The Zumo is mounted in a Touratech locking cradle (very trick) which is in turn mounted on a Ram 5.5" ball arm on the tank bolt ball mount. The Escort is mounted on a Ram handlebar mount. The visual alert is just velcro'd to the top of the instrument panel. The tie wrap around the Escort is to hold the visual alert jack into the unit, as it otherwise fits VERY loosely. This is all very similar to the setup I had on my '02 Blackbird, and functions very well. The only problem is not having come up with a theft-proof mount for the Escort :biggrin: The separate Garmin XM entenna rides in the clear map pocket of my tank bag, and all are powered through the Powerlet setup I installed in that. If anyone wants more pics, I'll be happy to send them along. Thanks again, everyone, for all the advice! Cheers, Tom Cockpit I would end up playing with/staring at all of that stuff while riding and then crashing! An old fashioned map is good for that purpose--you can't use it while riding! Though I do end up printing off-- in LARGE PRINT-- A condensed route guide off of Google maps and putting it on top of my tank bag. Am I the only one who thinks this is a safety issue, or am I just more easily distracted? Link to comment Share on other sites More sharing options...
Guest Posted March 23, 2009 Share Posted March 23, 2009 Am I the only one who thinks this is a safety issue, or am I just more easily distracted? I don't see that adding a zumo and a radar detector as something that would take away from safety. In that spirit, then things like the ODO, Speedo, Tach, Coolant temp, etc.. would all fall into the same category. It's all about how you use them when you ride. Link to comment Share on other sites More sharing options...
Beck Posted March 23, 2009 Share Posted March 23, 2009 Just thought I'd post a pic of the cockpit setup I've got on my new '06 VFR/A. It consists of a Garmin Zumo 550 w/ XM, Passport 8500 w/ Marc's Visual Alert up on top above the speedo, and you can just barely make out the switch for the heated grips I just installed. It's just forward of the top screw on the left fairing next to the tank.The Zumo is mounted in a Touratech locking cradle (very trick) which is in turn mounted on a Ram 5.5" ball arm on the tank bolt ball mount. The Escort is mounted on a Ram handlebar mount. The visual alert is just velcro'd to the top of the instrument panel. The tie wrap around the Escort is to hold the visual alert jack into the unit, as it otherwise fits VERY loosely. This is all very similar to the setup I had on my '02 Blackbird, and functions very well. The only problem is not having come up with a theft-proof mount for the Escort :fing02: The separate Garmin XM entenna rides in the clear map pocket of my tank bag, and all are powered through the Powerlet setup I installed in that. If anyone wants more pics, I'll be happy to send them along. Thanks again, everyone, for all the advice! Cheers, Tom Cockpit I would end up playing with/staring at all of that stuff while riding and then crashing! An old fashioned map is good for that purpose--you can't use it while riding! Though I do end up printing off-- in LARGE PRINT-- A condensed route guide off of Google maps and putting it on top of my tank bag. Am I the only one who thinks this is a safety issue, or am I just more easily distracted? No, you're not the only one who thinks so. As it is, you're systems are loaded up with enough sensory stimulation just for defensive driving to keep alive in traffic. Maybe this eletronic "immersion"should really be done mostly in your cage where it might npot be as dangerous to yourself, but "full boat" Goldwing rdiers might not agree....... :biggrin: JMOs Beck 95 VFR Link to comment Share on other sites More sharing options...
Member Contributer NorthernVFRDave Posted March 24, 2009 Member Contributer Share Posted March 24, 2009 Tom, I like the Zumo set up on your VFR. Do you know the RAM part number for the gastank bolt ball mount? I just picked up a VFR yesterday and that's exactly how I would like to mount my Zumo. Thanks! Your after this one RAM-B-231Z-2 (U Bolt Base Black) But check your Zumo box, I think it comes with one of these guys Link to comment Share on other sites More sharing options...
Member Contributer CornerCarver Posted March 24, 2009 Member Contributer Share Posted March 24, 2009 I would end up playing with/staring at all of that stuff while riding and then crashing! An old fashioned map is good for that purpose--you can't use it while riding! Though I do end up printing off-- in LARGE PRINT-- A condensed route guide off of Google maps and putting it on top of my tank bag. Am I the only one who thinks this is a safety issue, or am I just more easily distracted? I was going to answer your question but I got distracted as I have ADOP....attention deficit - OH PRETTY.... I actually prefer having the direction spoken to me in my headset from my zumo (before it was stolen from my car). I also have my Valentine 1 input into my headset. I believe many who think this type of set up promotes sensory overload are the same who are indecisive as they struggle to know whether they need to turn left or right is Northeast on connector 85 thereby screwing up and creating traffic/safety issues. Not necessarily anyone on this site but we have all seen cagers turn left from the right lane and they have a much easier time referring to a map than I can when it is in my map pocket on my tank bag...hurts my neck just thinking of those days of craning down to check the route. Link to comment Share on other sites More sharing options...
Member Contributer Rustbucket Posted March 24, 2009 Member Contributer Share Posted March 24, 2009 I would end up playing with/staring at all of that stuff while riding and then crashing! An old fashioned map is good for that purpose--you can't use it while riding! Though I do end up printing off-- in LARGE PRINT-- A condensed route guide off of Google maps and putting it on top of my tank bag. Am I the only one who thinks this is a safety issue, or am I just more easily distracted? I run a Zumo, and it's important for me to be aware of where my attention is focused. The fancy animations can be distracting, and it can be tempting to try to hit buttons while riding, both of which are good ways to get hurt. I always put in my route and set up any tunes while stopped, and pull over to make any changes. If I'm not using the navigation for routing, I'll usually switch to one of the screens that displays speed and other stats, which I find less distracting than the map view (less of the screen changing at a given point). The navigation is a life saver for me, with the spoken directions, I don't have to look down to get to unfamiliar destinations, which I think makes for a safer ride... My 2 cents... Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted March 24, 2009 Member Contributer Share Posted March 24, 2009 Am I the only one who thinks this is a safety issue, or am I just more easily distracted? I don't see that adding a zumo and a radar detector as something that would take away from safety. In that spirit, then things like the ODO, Speedo, Tach, Coolant temp, etc.. would all fall into the same category. It's all about how you use them when you ride. Good point, after I posted, I realize that I sometimes ride with a Zune, and yes, it takes some discipline not to change the playlist or volume while riding, but it in and of itself doesn't distract me. And, I only check my route when stopped, but I'd rather have voice commands than stare down at the tank bag while riding... Still, so much technical gadgetry... I guess I'm just one of those types that would rather get lost and discover new roads than get to my destination efficiently, but I can see the appeal of it. To each their own. Incidentally, what is the "explorer" a radar detector? Link to comment Share on other sites More sharing options...
Guest Posted September 20, 2009 Share Posted September 20, 2009 Just thought I'd post a pic of the cockpit setup I've got on my new '06 VFR/A. It consists of a Garmin Zumo 550 w/ XM, Passport 8500 w/ Marc's Visual Alert up on top above the speedo, and you can just barely make out the switch for the heated grips I just installed. It's just forward of the top screw on the left fairing next to the tank.The Zumo is mounted in a Touratech locking cradle (very trick) which is in turn mounted on a Ram 5.5" ball arm on the tank bolt ball mount. The Escort is mounted on a Ram handlebar mount. The visual alert is just velcro'd to the top of the instrument panel. The tie wrap around the Escort is to hold the visual alert jack into the unit, as it otherwise fits VERY loosely. This is all very similar to the setup I had on my '02 Blackbird, and functions very well. The only problem is not having come up with a theft-proof mount for the Escort :blink: The separate Garmin XM entenna rides in the clear map pocket of my tank bag, and all are powered through the Powerlet setup I installed in that. If anyone wants more pics, I'll be happy to send them along. Thanks again, everyone, for all the advice! Cheers, Tom Cockpit Regarding your heated grips; Did you install the SYMTEC ones? Also, where did you mount the switch? thanks, Link to comment Share on other sites More sharing options...
soichiro Posted September 20, 2009 Share Posted September 20, 2009 You know, the more I think about it, the more I would like to have a Zumo. At first I thought it would be total overkill with me, but more and more, I find myself going on longer and longer trips, and having to stop every hour or so to pull out the map and have a look Either that or I end up using the patented Higgin "Analog GPS", which is somewhat embarassing to have to explain to someone what it is. Not to mention trying to decifer my chicken scratch while sitting at a stoplight or stop sign....lol But one of the things that worries me about a gps such as the zumo that costs like $500, is what do you guys do with them when you are off the bikes (such as being on a long trip, and stopping to get dinner and relax for an hour or 2)? I would be very afraid of them getting stolen. Or are they locked down well enough to make it difficult to steal? Seems to me that they would be easy to just pull right off. My thought was that whenever I take a trip of any distance, I always have my hard cases, and I figured I could lock it in there with my helmet, jacket, and gloves when I am leaving the bike. I know the hard cases aren't exactly "theftproof", but it would at least get it under lock and key and out of plain sight and would require someone to put at least a moderate amount of effort into stealing. That's my thought anyway? So what do you guys that have GPS units do with yours? Might be a nice Christmas gift to myself this year, since the g/f (and her pricey gifts) are long gone now....... The directions on the tank work pretty ood. Unless of course you run a tank bag. I know I know I have used this system several times and I have 2 gps units. Link to comment Share on other sites More sharing options...
Member Contributer gstanfield Posted September 20, 2009 Member Contributer Share Posted September 20, 2009 Wow, I had no idea anyone still used radar detectors. I don't know what the guys in other parts of the country are running, but around here if your detector goes off that means I just clocked you and it's useless at that point. We don't sit around "painting" the traffic looking for speeders. Just keep that in mind when you're blasting across WY. Keep your eyes out and if you're quick you see the cop before I see you and slow down in time. The detector just lets you know that you are about to get a ticket (although we have a record of being very friendly towards bikes, so...) Ride safe, ride hard, George Link to comment Share on other sites More sharing options...
