Member Contributer redmarque Posted March 26, 2008 Member Contributer Share Posted March 26, 2008 In the search for space i'm tempted to remove some of this, but what does it do? apart from the breather pipe connector? surely I could cut 20mm to make it lower? The manual says 'packings' Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted March 26, 2008 Member Contributer Share Posted March 26, 2008 surely I could cut 20mm to make it lower? Why in the world would you want to do that? :unsure: Link to comment Share on other sites More sharing options...
Member Contributer redmarque Posted March 26, 2008 Author Member Contributer Share Posted March 26, 2008 surely I could cut 20mm to make it lower? Why in the world would you want to do that? :unsure: My patient needs more room for it's battery - lack of fore-thought on my part! it fits but would be happier to give the fuel pump more clearance. Link to comment Share on other sites More sharing options...
SEBSPEED Posted March 26, 2008 Share Posted March 26, 2008 Have you seen the rest of his build? I think he wants some frame clearance... Don't have an answer, unless that's the PAIR thing the can be blocked off? Link to comment Share on other sites More sharing options...
SEBSPEED Posted March 26, 2008 Share Posted March 26, 2008 N/M, I see the PAIR cover on top of that now... Link to comment Share on other sites More sharing options...
wera803 Posted March 26, 2008 Share Posted March 26, 2008 It probably has some sort of steel wool in it. The main job is to separate the oil from the crankcase gasses/pressure before it is released. Without the material, it will allow the gasses along with suspended oil into the air filter housing. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted March 26, 2008 Share Posted March 26, 2008 It probably has some sort of steel wool in it. The main job is to separate the oil from the crankcase gasses/pressure before it is released. Without the material, it will allow the gasses along with suspended oil into the air filter housing. Unless you run the vapours through a catch tank before routing to the airbox....... Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted March 26, 2008 Member Contributer Share Posted March 26, 2008 Have you seen the rest of his build? I think he wants some frame clearance... "I see", said the blind man. Link to comment Share on other sites More sharing options...
Beck Posted March 26, 2008 Share Posted March 26, 2008 In the search for space i'm tempted to remove some of this, but what does it do? apart from the breather pipe connector? surely I could cut 20mm to make it lower?The manual says 'packings' Donttouchdat!!! Your Klingon bike needs it's dlithium crystal fission quenching chamber!!! Beck 95 VFR Link to comment Share on other sites More sharing options...
Member Contributer dukeracr Posted March 26, 2008 Member Contributer Share Posted March 26, 2008 I bought a battery for my 5th gen that turned out to be about 20mm shorter than stock, I had to put a block of wood under it, at the bottom of the battery compartment to raise it up. Could a smaller battery be a solution? Rich A Link to comment Share on other sites More sharing options...
AB-Oz Posted March 26, 2008 Share Posted March 26, 2008 I think its the freedle valve cover Link to comment Share on other sites More sharing options...
Member Contributer redmarque Posted March 27, 2008 Author Member Contributer Share Posted March 27, 2008 Donttouchdat!!! Your Klingon bike needs it's dlithium crystal fission quenching chamber!!!Beck 95 VFR Very true! if it really needs to be cut down. I'll get my Forceps /scalpel and dissect for the class! :wacko: Ta All. Red Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted March 28, 2008 Member Contributer Share Posted March 28, 2008 In the search for space i'm tempted to remove some of this, but what does it do? apart from the breather pipe connector? surely I could cut 20mm to make it lower?The manual says 'packings' I bet Mark J. Harris would know (he's the guy on the IOM who swapped an Fi engine into a VTEC). Look for him on the bikersoracle VFR site... Ciao, Link to comment Share on other sites More sharing options...
Question
redmarque
12 answers to this question
