bighawk Posted December 16, 2017 Share Posted December 16, 2017 Friends, What tire pressure are you all running? Manual says COLD tire should be 36 front and 42 rear. I deflated them a couple months ago for the track and just remembered I need to put air in them. That said, I'm curious what you all are running for normal commuting/spirited riding both cold and warm. Thanks! Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted December 16, 2017 Member Contributer Share Posted December 16, 2017 Did a track day at Phillip Island, the track officials from memory set both tyres to 33psi. Have always ran 36/42 as recommended for normal road riding. Link to comment Share on other sites More sharing options...
Member Contributer GatorGreg Posted December 16, 2017 Member Contributer Share Posted December 16, 2017 What's the reason for having more pressure in the back? Is it cuz of extra weight from the rider? Link to comment Share on other sites More sharing options...
Member Contributer fink Posted December 16, 2017 Member Contributer Share Posted December 16, 2017 36/42. 24/ 28 psi on a cold wet rainy Scottish Autumn morning can be a bit hairy. Link to comment Share on other sites More sharing options...
Katie Posted December 17, 2017 Share Posted December 17, 2017 13 hours ago, fink said: 36/42. 24/ 28 psi on a cold wet rainy Scottish Autumn morning can be a bit hairy. In the running for 'Understatement of the Year' award Link to comment Share on other sites More sharing options...
Member Contributer fink Posted December 17, 2017 Member Contributer Share Posted December 17, 2017 1 hour ago, Katie said: In the running for 'Understatement of the Year' award No point in over exaggerating things is there.. Link to comment Share on other sites More sharing options...
Member Contributer Bent Posted December 19, 2017 Member Contributer Share Posted December 19, 2017 As important as tire pressure is using an accurate tire gauge. Most of them aren't. Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted December 19, 2017 Member Contributer Share Posted December 19, 2017 5 minutes ago, Bent said: As important as tire pressure is using an accurate tire gauge. Most of them aren't. Do you have a list of which ones are or one that you can recommend? Link to comment Share on other sites More sharing options...
Member Contributer fink Posted December 19, 2017 Member Contributer Share Posted December 19, 2017 Here you go. i have no 1&3 Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted December 20, 2017 Member Contributer Share Posted December 20, 2017 3 hours ago, fink said: Here you go. i have no 1&3 Can't see or download the file... Link to comment Share on other sites More sharing options...
Samuelx Posted December 20, 2017 Share Posted December 20, 2017 I THINK this is the one Fink is talking about: http://images.mcn.bauercdn.com/upload/ride magazine/product test pdfs/9 sep08 pressure gauge test.pdf http://www.reviewlab.com/best-tire-pressure-gauges https://www.consumerreports.org/tire-pressure-gauges/choosing-the-best-tire-pressure-gauge/ Link to comment Share on other sites More sharing options...
Member Contributer fink Posted December 20, 2017 Member Contributer Share Posted December 20, 2017 Cheers Link to comment Share on other sites More sharing options...
Member Contributer Bent Posted December 20, 2017 Member Contributer Share Posted December 20, 2017 21 hours ago, Bent said: As important as tire pressure is using an accurate tire gauge. Most of them aren't. I use an Longacre Racing gauge and have had it calibrated once. It didn't need it that time and, in fact, they said they almost never have to change one. FWIW. I've checked other gauges against it and they're all over the map. Again, FWIW. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted December 20, 2017 Member Contributer Share Posted December 20, 2017 Thanks for the link on the pressure gauges. I have to pick up a good one soon. Oddly, most accurate gauge I have is the one built in on a 12V portable tire pump out of an early 90's conversion van. Matched up perfect to a MotionPro gauge. Street pressures is usually the stated 36/42. Drop a bit to 34/40 sometimes. But I'm slow. Link to comment Share on other sites More sharing options...
mountainslide Posted December 21, 2017 Share Posted December 21, 2017 I run 34/36 for aggressive riding/leaning. Link to comment Share on other sites More sharing options...
JIMLARCH Posted December 22, 2017 Share Posted December 22, 2017 I run 36/42 for regular riding. Unless you live in an area such as Deals Gap or the canyons of California, they're fine. From my experience one man's idea of "hard riding" is likely another man's idea of a "brisk" ride. Link to comment Share on other sites More sharing options...
