Redbike Posted July 19, 2015 Share Posted July 19, 2015 Sorry, I am new here and scrolled the topics for a while. I bought a 2006 model and experienced yesterday: -after cruising 4-5000RPM and once rev. it up the power is cut off for a sec. at 6800 RPM - 2. 3. trial, no problem, no changes in power output -after cruising again, the previous power loss will come again How is the bike normal behaviour? how the vetec should change? What RPM? Or is it a seious issue, and should I go to the dealer? Link to comment Share on other sites More sharing options...
Member Contributer expvet Posted July 19, 2015 Member Contributer Share Posted July 19, 2015 The only thing I can offer with the limited information is that on an 06 6800 rpm is right at the VTEC engagement point. Seems like the transition is not going smoothly since there is a jump in power but no interruption. Link to comment Share on other sites More sharing options...
Redbike Posted July 19, 2015 Author Share Posted July 19, 2015 You mean, I should feel some jump in the torque at 6800? I know it is the transition point for the model till 2005. The newer version should switch at 6500?? but anyway, my bike makes there a full interruption for a sec. Luckily I made it on the straight and alone. Link to comment Share on other sites More sharing options...
drdreas Posted July 19, 2015 Share Posted July 19, 2015 Yea, unfortunately with the 6th gen right at vtec engagement there is actually a dip in both torque and power. If you roll through the engagement rpm slowly (partial throttle) it can actually seem like a noticeable interruption to power. I love my 08 but this is the one thing I dislike, you can't smoothly and slowly rev high into the range without this interruption. Ive learned to shift before this point unless Im at a large throttle opening. Here's a dyno chart of the 08 that clearly illustrates this. Link to comment Share on other sites More sharing options...
Auspanglish Posted July 19, 2015 Share Posted July 19, 2015 Check to see if the O2 sensors are plugged in in the wrong order, back to front so to speak... Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted July 19, 2015 Member Contributer Share Posted July 19, 2015 And are you anticipating the VTEC and rolling off of the throttle. Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted July 20, 2015 Member Contributer Share Posted July 20, 2015 No issues like those described on my '08 Vtec. Vtec in at 6800rpm-ish, out at 6400rpm-ish is the norm for 06+ models. Are you sure yours is an 06+ and not an older model year with the Vtec in/out at the same revs (6800-ish)? Hovering around that rpm can cause some lagging/surging, hence they changed it on the 06+ model. Link to comment Share on other sites More sharing options...
Redbike Posted July 20, 2015 Author Share Posted July 20, 2015 Yes, my model is 2006-so updated06+. I made this accelerating test from 4000RPM-in 4.gear at least with 50% throttle. So it was not that smooth-slow change. But the torque drop was complete for a sec. Luckily I was on the straight and did not fall down. The difference: when I let the rev. down only till 5000RPM, I could not feel and hesitating, no interuption, just smooth acceleration till 7000RPM. I will also look the O2 sensors. But it is not that easy to see Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted July 20, 2015 Member Contributer Share Posted July 20, 2015 Yes, my model is 2006-so updated06+. I made this accelerating test from 4000RPM-in 4.gear at least with 50% throttle. So it was not that smooth-slow change. But the torque drop was complete for a sec. Luckily I was on the straight and did not fall down. The difference: when I let the rev. down only till 5000RPM, I could not feel and hesitating, no interuption, just smooth acceleration till 7000RPM. I will also look the O2 sensors. But it is not that easy to see In that case, I'm struggling for an answer. It certainly does not happen on my Vtec, which is beautifully smooth throughout virtually the whole rev range. Hopefully there will be someone more knowledgeable along soon to help you. Link to comment Share on other sites More sharing options...
Lint Posted July 20, 2015 Share Posted July 20, 2015 I think I had this for a while. If memory serves, I had a bad vacuum line. Therefor, my suggestion is the usual supects, spark plugs, starter valve sync, injectors out and profesionally cleaned. Definitely check each and every vacuum line. It looks daunting under the airbox at firat, but if you spend a little time tracing each line with your finger, you should be able to get a grasp on where everything is routed. Also, check your PAIR valves and your flapper valve. Definitely check your vacuum lines. That is what handled it for me. Link to comment Share on other sites More sharing options...
spud786 Posted July 21, 2015 Share Posted July 21, 2015 Yes, my model is 2006-so updated06+. I made this accelerating test from 4000RPM-in 4.gear at least with 50% throttle. So it was not that smooth-slow change. But the torque drop was complete for a sec. Luckily I was on the straight and did not fall down. The difference: when I let the rev. down only till 5000RPM, I could not feel and hesitating, no interuption, just smooth acceleration till 7000RPM. I will also look the O2 sensors. But it is not that easy to see For the most part, that transition is totally seamless on many bikes. I saw some harsh engagement when my 06 was new, in the first couple thousand miles. Not always but hard enough to hurt my hands, a few times it hit so hard. One time Sub 3000 miles , I was in 29 degree weather and had been riding for 25 miles or so. Accelerated hard in first to get up to speed on the highway, and the bike hit so hard , it could have broken a motor mount, I mean hard, but after about 4,000 miles, those occasional episodes disappeared. IMO never adjust the vtecs(valves) if you want to touch the standard valves okay, but avoid the vtecs., I think that's the reason mine stopped doing that after a few thousand miles. But any fueling deficiencies can also bring out issues in that area, and an 06 with low mieage has been sitting way too much for its own longterm health with fueling. Any 06 should have well over 100,000 miles , you might also try disconnecting the battery so the bike recalibrates Link to comment Share on other sites More sharing options...
Redbike Posted July 21, 2015 Author Share Posted July 21, 2015 Thanks for the hints. Today, I checked again how it is working. I accelerated below 4000rpm up to 7000rpm in each gears from 2-5. When I let the rev. down and accelerated with 50+% throttle, I could feel some change at 6800 each time. It was not that big interruption like last week, a a bit different al the time. In 2-3. gears only some chenges, in 4-5. gears some torque drop. Maybe at 75+% throttle comes some interruption. And I have a high freq. vibration from the engine from 4000rpm+ . Above this 6800rpm, the vibration gets more. Yes, might be aslo somehere the exhaust, I should check. But not that easy. I should remove the blastic budy w/o breaking the clips. How can I check the vacuum lines? They can have cracks or breaks or loose connections??? How to check the PAIR and flapper valves? Do I need OBD reader (Honda)? Link to comment Share on other sites More sharing options...
Lint Posted July 21, 2015 Share Posted July 21, 2015 You do not need to remove the palstic to remove the exhaust. Simply pull your seat and you can access the bolts holding it on with a ratchet and socket as well as a hex key. Hex key on the bolt head outside, ratchet and socket to hold the nut still in the space under the seat. To check the vacuum lines, you would lift and brace your tank, then remove the airbox cover, then the airbox base, via the two screws holding each venturi down. Get a small flashlight and trace them all down and check each vacuum line end to see if there is any cracking or if any of them are loose. The Pair valve is connected to the back of the airbox, download the service manual to see where. The flapper valve is on top of the airbox, with a vacuum line running down to the right side of the airbox. Go here to download the service manual: http://www.vfrdiscussion.com/forum/index.php/files/file/150-service-manual-6th-gen-2002-vtec-with-bookmarks-new-cover-ocr/ Link to comment Share on other sites More sharing options...
Motographer Posted August 3, 2015 Share Posted August 3, 2015 Some insight after running the Tail of the Dragon about 20 times this weekend and spending most of them right around VTEC range in second gear; the VTEC system REALLY doesn't like part throttle, especially if you're rolling on slowly. If you're using >40% throttle or so and rolling through the transition, you may feel some hesitation, and above 70% or so the transition feels almost seamless to me, but if I decelerate past the de-activation point and then pick up the throttle so that it goes back into VTEC range before I'm at full throttle, there's a big jerk. I probably abused the VTEC solenoids on my bike more than I should have over the last few days Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted August 4, 2015 Member Contributer Share Posted August 4, 2015 Some insight after running the Tail of the Dragon about 20 times this weekend and spending most of them right around VTEC range in second gear; the VTEC system REALLY doesn't like part throttle, especially if you're rolling on slowly. If you're using >40% throttle or so and rolling through the transition, you may feel some hesitation, and above 70% or so the transition feels almost seamless to me, but if I decelerate past the de-activation point and then pick up the throttle so that it goes back into VTEC range before I'm at full throttle, there's a big jerk. I probably abused the VTEC solenoids on my bike more than I should have over the last few days I run the Dragon in 3rd and 4th and sometimes hit 5th. Not bragging just for example. Link to comment Share on other sites More sharing options...
Redbike Posted August 4, 2015 Author Share Posted August 4, 2015 Thank for the support. Today I lifted the tank and checked the air pipes and the filter. All of them are well mounted, clean and like a new. Then went around the bike and remounted the bolts of exhaust, engine and footpegs, which were not under the plastic covers. I could not find any issue. Spark plugs and filters are also new. The vetec transition was for me just the opposite. Smooth when slowly accelerate, small jerk when 50% and interruption when 70%+. When playing on the transition zone, even in high throttle, the engine is smooth, like my old RC36 bike was. When the bike is in 4valve mode, the vibrations are more, and I feel something like a free plate or the exhaust zzzz vibration. Does not matter, I can rev it with clutch in and no load, as well. This makes me nervous... Link to comment Share on other sites More sharing options...
Motographer Posted August 4, 2015 Share Posted August 4, 2015 Some insight after running the Tail of the Dragon about 20 times this weekend and spending most of them right around VTEC range in second gear; the VTEC system REALLY doesn't like part throttle, especially if you're rolling on slowly. If you're using >40% throttle or so and rolling through the transition, you may feel some hesitation, and above 70% or so the transition feels almost seamless to me, but if I decelerate past the de-activation point and then pick up the throttle so that it goes back into VTEC range before I'm at full throttle, there's a big jerk. I probably abused the VTEC solenoids on my bike more than I should have over the last few days I run the Dragon in 3rd and 4th and sometimes hit 5th. Not bragging just for example. You must run a hell of a lot faster than I do, then. I spend most of it in 2nd and 3rd, usually keep it below 55 on the straights, 30-40 through the corners depending on how tight they are. There's a lot of room for me to lean more, but I'm working up to that. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted August 5, 2015 Member Contributer Share Posted August 5, 2015 Some insight after running the Tail of the Dragon about 20 times this weekend and spending most of them right around VTEC range in second gear; the VTEC system REALLY doesn't like part throttle, especially if you're rolling on slowly. If you're using >40% throttle or so and rolling through the transition, you may feel some hesitation, and above 70% or so the transition feels almost seamless to me, but if I decelerate past the de-activation point and then pick up the throttle so that it goes back into VTEC range before I'm at full throttle, there's a big jerk. I probably abused the VTEC solenoids on my bike more than I should have over the last few days I run the Dragon in 3rd and 4th and sometimes hit 5th. Not bragging just for example. You must run a hell of a lot faster than I do, then. I spend most of it in 2nd and 3rd, usually keep it below 55 on the straights, 30-40 through the corners depending on how tight they are. There's a lot of room for me to lean more, but I'm working up to that. First time on a mc I was on Kawasaki Avenger 350 . I was 15 1/2 years old. That was many many years ago and thousands of passes thru . And back on subject the 08 with the PC5, the VTEC is seamless, never fill the other valves kick in . Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted August 5, 2015 Member Contributer Share Posted August 5, 2015 Thank for the support. Today I lifted the tank and checked the air pipes and the filter. All of them are well mounted, clean and like a new. Then went around the bike and remounted the bolts of exhaust, engine and footpegs, which were not under the plastic covers. I could not find any issue. Spark plugs and filters are also new. The vetec transition was for me just the opposite. Smooth when slowly accelerate, small jerk when 50% and interruption when 70%+. When playing on the transition zone, even in high throttle, the engine is smooth, like my old RC36 bike was. When the bike is in 4valve mode, the vibrations are more, and I feel something like a free plate or the exhaust zzzz vibration. Does not matter, I can rev it with clutch in and no load, as well. This makes me nervous... All sounds fine from your description. I do note some additional harshness with all 4 valves operating, but then that means the engine's working really hard so I expect it. As for the vibration, if it's severe or quite noticeable, you might want to nut and bolt the bike - take an afternoon, remove the plastics and go over everything - check for proper torque or securely fastened. It's probably fine. I've had things get in to my head and I think I have a tire going down, or hear something . . . in the end it turns out to be nothing. If you suspect something internal to the engine, an oil analysis should confirm its health or lack thereof. Link to comment Share on other sites More sharing options...
Member Contributer Ultimatevfr Posted August 5, 2015 Member Contributer Share Posted August 5, 2015 Some insight after running the Tail of the Dragon about 20 times this weekend and spending most of them right around VTEC range in second gear; the VTEC system REALLY doesn't like part throttle, especially if you're rolling on slowly. If you're using >40% throttle or so and rolling through the transition, you may feel some hesitation, and above 70% or so the transition feels almost seamless to me, but if I decelerate past the de-activation point and then pick up the throttle so that it goes back into VTEC range before I'm at full throttle, there's a big jerk. I probably abused the VTEC solenoids on my bike more than I should have over the last few days I run the Dragon in 3rd and 4th and sometimes hit 5th. Not bragging just for example. I think your being modest.....;) Link to comment Share on other sites More sharing options...
Redbike Posted August 19, 2015 Author Share Posted August 19, 2015 Thanks for your advices. Last week I visited a Honda dealer. They plugged in the OBD reader and checked also the codes but they found all the systems OK. They made a acoustic test the detect when the vetec open and close. IT was around 6700 up, and 6200 down on my 06. machine. They could not make a longer trip on in only in the local parking lot, but they found there everything OK. I changed the oil 2000km ago and used a full synt. 5100 Motul. So till now no idea, why this bike works just the opposite way: with modest acceleration smooth transition- at sport mode more and more interruption???? Link to comment Share on other sites More sharing options...
