Yeah, after 14,000km commuting that Metzeler Lasertec rear is as square as a square sausage!!!  (miss that Scottish cuisine...  :tongue:)
The front still has 2.9mm thread depth left... :fing02:
With the rear cover beginning to "sweat" a bit, I dropped by my dealer. Long and behold, he actually HAD a gasket in stock for my 33 year old!
They could no longer order it through Honda (NLA) so went to CMSNL for another one. When they are gone tgey are gone....
Yes, gonna get harder to keep them going. Then again, the way we are accelerating to an electric only future we might not need to.
Pretty sure we will find a backstop for that issue as well......  :goofy:
SP's have one gremlin....... If the sun is shining from behind while parked up, the screen's inside will act like a parabolic mirror and melt the cockpit...
Mine came with that mark and I camouflaged it with a wee sticker.
But, jolo and all that.... :tongue:
Your Vessels look hardly used.  Admit it, you're just fishing for "Wow, those are some really nice screwdrivers you've got there, Leon" comments, aren't you?  :happy:
Ciao,
JZH
Ciao,
JZH
Yep, pretty much nailed it.
Did the same thing when I got my JIS screwdrivers about 6 years ago.
I even had the one that was an impact screwdriver.
I can still hear the crickets chirping after my proud post. 😉
I admit.... They are new!
Finally accepting that JIS is not philips....
So that's what caused the bumps above the tach!
Thanks Dutchy, glad I check on your unending thread periodically..
...and btw, my JIS screwdrivers are red, to match the bike of course!
just for kicks, next time the sun is out in force, park your bike tail to the sun and  place a piece of black paper on the tacho...
Don't do that; you're going to set the bike afire!
Part of the JIS/Phillips confusion stems from the Japanese calling their JIS-spec cross-head screws "Phillips"!!!  :wacko:
Honda also had a problem with the early RC46 windscreen dimpling/melting the dashboard, which they "fixed" by changing the dash to include ugly little raised triangles of extra plastic on the later Y2ks and '01s:
Such aesthetic indifference caused me to buy a second-hand set of clocks just to salvage the plastic to swap onto mine.  (I will park out of the sun!)
Ciao,
JZH
I recall a warning about focused sun rays from the Givi touring screen. But I quickly forgot about the warning and parked in the sun without regard and without negitive results. I work on my machines primarily in my non-shaded driveway. Bikes ('00 and '01s) have sat out in the sun for hours frequently tail-to-the-sun. I'lll be more careful of my '98. Thanks for the warning.
Will do, fire extinguisher in hand.
Random track day photo:
Great picture! :beer:
IMG_20190131_092836.thumb.jpg.fe7462f4a0a7d6e4a6a53257604ce3f9.jpgman, I need a real garage.....
that stain on the floor is from when the clutch rod seal was leaking........:tongue:
Wow! I just noticed the red forks. V cool.
Man, you sure do!
Man, you sure do!
No you don’t! You guys are magicians with space out there!!! :-) I’m sure you can squeeze one more bike in there if you tried.
C
  • Confused 1
Lovely day, clear skies, 14 celcius
One distinct feature in our Dutch landscape are pollard trees.
They are "high maintenance" cos if left alone, they will eventually topple. Especially since the water is omnipresent Why then keep them then?
cos they grow nice straight twigs that are flexible for making baskets for instance. Or lace them into fence-work.
Like I said, sunny and 13C.
So timing wise, this vendor is a bit out of season for his road salt.....
Sticker tuning 😀
RHS still in place, glued on a plastic ring to reinforce
A bit of McGyver on the LHS while I ponder on a better solution
Put a bit if dense foam between panel and locking mechanism house to space it...
Saddle rubs the tank so a wee bit of touch up
Redslut lives on!!! 🙂
  • Like 4
Lovely day for it..... :fing02:
