Member Contributer rescue Posted September 6, 2014 Member Contributer Share Posted September 6, 2014 Ooops. Of the three bolts for the clutch slave, the top long was turned just a touch too much and click!!! Spins out now. What are my options!! Cheers Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 6, 2014 Member Contributer Share Posted September 6, 2014 A slightly larger bolt at first.... Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 6, 2014 Member Contributer Share Posted September 6, 2014 And a torque wrench !!! Link to comment Share on other sites More sharing options...
timmythecop Posted September 6, 2014 Share Posted September 6, 2014 Mine has been snapped for over a year. Link to comment Share on other sites More sharing options...
kyojitsu Posted September 11, 2014 Share Posted September 11, 2014 Helicoil thread repair kit? Not sure what bolt size but you should be able to get a set with a variety of threads and taps. Loads on ebay. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted September 11, 2014 Member Contributer Share Posted September 11, 2014 Helicoil thread repair kit? Not sure what bolt size but you should be able to get a set with a variety of threads and taps. Loads on ebay. helicoil sucks. remove the clutch slave holder/ sprocket guard and see if the broken bolt can be removed by hand . i bet it will. one the broken bolt is out replace with longer bolt as i am sure more threads are on there.. if worst comes to worse, tap out to the next size up. if you REALLY want to keep the same bolt.. then use a TIMESERT.. as helicoil sucks. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 11, 2014 Member Contributer Share Posted September 11, 2014 one the broken bolt is out replace with longer bolt as i am sure more threads are on there.. There was for my RHS clutch cover...... Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 11, 2014 Member Contributer Share Posted September 11, 2014 More anti-seize ! Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted September 11, 2014 Member Contributer Share Posted September 11, 2014 Timeserts are great. Trying to get my current work to start using them. They do need to work on their distribution though. Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted September 11, 2014 Member Contributer Share Posted September 11, 2014 I've used Keenserts for thread repair too, a lot like Timeserts. The only problem is the hole has to be made quite a bit bigger for the insert. But if you have the room they can't be beat. Link to comment Share on other sites More sharing options...
