Guest vfroem Posted February 9, 2014 Share Posted February 9, 2014 Hi Everyone ! Here my update for my project. Will start with 2009 and what happened. 2009: Link to comment Share on other sites More sharing options...
Guest Posted February 9, 2014 Share Posted February 9, 2014 What has been changed the last few years; Front Discs One of the front discs (Brembo) was warped. I have send the set 2x to straighten but still they I wasn't happy about the result. ISR Discs ordered and took out the brembo's Rear shock Spring was updated by Hyperpro in the past and new gas inside; sold the complete item Brought the bike to the Dutch Importer of Bitubo; custom made rear shock was made by the factory and also they upgraded the front forks. Mirrors Light but unuseable; changed by VFR800Fi items (much heavier....) Radiators The new rads have almost 3x the capacity of the old radiator. Also the waterpump was replaced in the past by an electric item and the termostat was removed. I drove a couple of times without a fan but when driving slow the temperature became too hot. Bought several fans (Fireblade, R1) and put them all on the bathroomscale. The item with the lowest weight has been added Rear Seat Rear seat (carbon-kevlar NC30/VFR400 item) cracked on several places. Not strong enough; reinforced now Fueltank My Honda stopped a couple of times / running on just 3 or 2 cilinders... carb jets had to be cleaned a couple of times... My fueltank is resistance against German Fuel, but Dutch not... (probably Ethanol) Got a brand new tank from the manufacturer. Rear axle The rear axle is a modified VFR400 part. Found some Alloy parts to replace the much heavier steel items 'In progress' pics; Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted February 9, 2014 Member Contributer Share Posted February 9, 2014 any up to date pics ? dyno details etc ? Looks good. Link to comment Share on other sites More sharing options...
Guest Posted February 9, 2014 Share Posted February 9, 2014 Ready for a new paintjob: BMW metallic White Dyno details: My to be done / 'Wish list' for now: -get it painted -starterclutch replaced by a lighter item -startermotor "less weight version" (current fireblade/cbr600rr ) -replace current coils by injection type integrated versions (less weight) -rear fender replaced by a carbon version -carbon wheels -ceramic front discs Link to comment Share on other sites More sharing options...
ej90vfr Posted February 9, 2014 Share Posted February 9, 2014 Sweet! Looks pretty cool! Should look even better when it's all done!! Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted February 9, 2014 Member Contributer Share Posted February 9, 2014 Those are pretty good numbers. Hope you get it all sorted soon. Link to comment Share on other sites More sharing options...
Member Contributer mk2davis Posted February 9, 2014 Member Contributer Share Posted February 9, 2014 I've heard that CF brakes are no good in the wet. Is that a concern in Holland? Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2014 Share Posted February 10, 2014 It never rains in Holland...!!! Will use Braketech, Quote from their website: Performance features include: Not thermally sensitive (will work great on the street) Ultra broad torque curve across a very wide thermal range Much longer lasting than C/c Much less expensive than C/c Great wet weather performance - unlike C/c [not hygroscopic] Terrific feel and feedback at the lever " Hope they do not Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted February 10, 2014 Share Posted February 10, 2014 I've heard that CF brakes are no good in the wet. Is that a concern in Holland? Ceramic Matrix Composite brake discs are not the same animal as the carbon/carbon discs they use in MotoGP. http://www.braketech.com/index.php?option=com_content&view=article&id=50&Itemid=95 The Carbon/Carbon don't work well when cold or wet. That's why for wet races, they use steel discs in GP. And the Carbon brakes they use in GP probably cost as much as a new car. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 10, 2014 Member Contributer Share Posted February 10, 2014 Hard to beat semi-metallic ... Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 10, 2014 Member Contributer Share Posted February 10, 2014 Man the pearl paint is a foot thick !!! Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2014 Share Posted February 10, 2014 Not the BMW Mineralweiss Metallic color... Link to comment Share on other sites More sharing options...
Member Contributer kgsmotorcycles Posted February 15, 2014 Member Contributer Share Posted February 15, 2014 Looking great as always! Did you have any cam or valve changes? What else did you remove from inside engine? How has reliability been?? What carbs and jetting do you run now? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 15, 2014 Member Contributer Share Posted February 15, 2014 Make us a video with the bike running !!! Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2014 Share Posted February 17, 2014 The cams have been modified. Valves: VFR800FI inlet valves (shortened), VFR750F outlet valves modified All other engine mods: tensioning gears removed Hyperplate clutch plates waterpump removed (electric waterpump) rc30 race alternator RC30 carbs+HRC mods rods modified JE pistons heads and ports flowed ram-air carbon air box (Durbahn) ignition changed Link to comment Share on other sites More sharing options...
CandyRedRC46 Posted February 17, 2014 Share Posted February 17, 2014 http://shop.durbahn.de/shop/en/products/Airbox_%26_Air_-_Intake/Durbahn woah thats some good stuff!! Link to comment Share on other sites More sharing options...
Guest Posted February 18, 2014 Share Posted February 18, 2014 Next week I will have the fairing painted. Link to comment Share on other sites More sharing options...
Member Contributer kgsmotorcycles Posted February 19, 2014 Member Contributer Share Posted February 19, 2014 Are you still running steel clutch plates? Picked up some JE pistons recently, carbs are on the wanted list, along with an air box solution. Not sure when ill be ready to finish build.. but half way there.... Link to comment Share on other sites More sharing options...
Guest Posted February 19, 2014 Share Posted February 19, 2014 The Vif has Hyperplates: less rotating mass. What I still need: recent startmotor (1991 startmotor is really heavy) starterclutch from a recent bike (weight) coils integrated in the sparkplug cable (like the modern bikes) Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted February 19, 2014 Member Contributer Share Posted February 19, 2014 coils integrated in the sparkplug cable (like the modern bikes) This perhaps? http://www.vfrdiscussion.com/forum/index.php/topic/70686-4th-gen-coil-on-plug-mod-split-thread/ Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted February 19, 2014 Member Contributer Share Posted February 19, 2014 What a set of wheels . Link to comment Share on other sites More sharing options...
Guest Posted February 20, 2014 Share Posted February 20, 2014 Thanks Dutchy ! Have to visit this forum more often.... coils integrated in the sparkplug cable (like the modern bikes) This perhaps? http://www.vfrdiscussion.com/forum/index.php/topic/70686-4th-gen-coil-on-plug-mod-split-thread/ Link to comment Share on other sites More sharing options...
Guest Posted February 28, 2014 Share Posted February 28, 2014 The paintjob is finished. Not sure about the stickers.... (still can change them) Link to comment Share on other sites More sharing options...
Guest Posted March 3, 2014 Share Posted March 3, 2014 New pics: Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted March 3, 2014 Member Contributer Share Posted March 3, 2014 I really like that paint. Link to comment Share on other sites More sharing options...
