RC24 Posted December 7, 2014 Share Posted December 7, 2014 I don't see three wire (High and Low beam in single unit) in the Cycle Gear link. Am I wrong? Also, I didn't find the H4 pair I originally bought from Lifetime listed on their site. The photo shown on the site is of the H7 version. The H4 has the 3 prong plug. It's exactly the same as the Lifetime bulbs. Same chinese supplier too I imagine. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted December 7, 2014 Member Contributer Share Posted December 7, 2014 OK, I didn't see it on the CG link... Link to comment Share on other sites More sharing options...
RC24 Posted December 7, 2014 Share Posted December 7, 2014 Hmm, looks like you can order right from china if you want to save 50%. Appear to be exact same bulbs and you get a pair for 70 bucks.http://www.amazon.com/Eyourlife-Universal-5000K-HEADLIGHT-Conversion/dp/B00KBQWR5Y/ Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted February 12, 2015 Member Contributer Share Posted February 12, 2015 Good luck captain with PayPal , I have had two claims over false purchases , got about 50% refund in both , Paypal has a 45 (or 90) day time limit so I'm sol on the $85. eBay seller won't return email or voicemails. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted March 22, 2015 Member Contributer Share Posted March 22, 2015 Hmm, looks like you can order right from china if you want to save 50%. Appear to be exact same bulbs and you get a pair for 70 bucks. http://www.amazon.com/Eyourlife-Universal-5000K-HEADLIGHT-Conversion/dp/B00KBQWR5Y/ Anybody tried these yet? Link to comment Share on other sites More sharing options...
Crewwolfy Posted May 8, 2015 Share Posted May 8, 2015 I'm seeing 80w LEDs available. Pretty sure I installed high wattage headlights into my econobox as a teenager and fried some shit. Is it safe to install 80w LED headlights into the Viffer? Link to comment Share on other sites More sharing options...
TNRabbit Posted May 8, 2015 Share Posted May 8, 2015 I'm seeing 80w LEDs available. Pretty sure I installed high wattage headlights into my econobox as a teenager and fried some shit. Is it safe to install 80w LED headlights into the Viffer? Not an issue IF you charging system is SOUND Link to comment Share on other sites More sharing options...
Crewwolfy Posted May 8, 2015 Share Posted May 8, 2015 Charging system on a VFR? Those are never anything but perfect... :P Link to comment Share on other sites More sharing options...
Member Contributer zoomzoom Posted May 9, 2015 Author Member Contributer Share Posted May 9, 2015 Most often it seems that when listing the wattage on LED headlights they list the wattage in pairs. So that could mean that the LED's you have looked at consume 80W per 2 bulbs or 40 W each. The stock Honda headlights are rated at 45W each. If you use standard H4 automotive bulbs then they are rated 60w/55w for high and low per bulb so a max of 120W draw. If the LED's draw 80W per pair of bulbs then I doubt there would be an issue. If they were 80W per bulb then I might be a little concerned especially with overall brightness and glare. Lifetime LED sells and advertises 70w H4 LED headlights that would work in the VFR and after emailing the company the bulbs are 70W per pair or 35W each. Personally, I love the extra light and the overall beam pattern that the LED's have provided and would not hesitate to recommend them. The results are fantastic. Link to comment Share on other sites More sharing options...
Member Contributer SCguy Posted May 9, 2015 Member Contributer Share Posted May 9, 2015 Has anyone used the Cyclops 3800 lumen bulbs? http://www.cyclopsadventuresports.com/3800-Lumen-H4-LED-Headlight-bulb-_p_83.html Link to comment Share on other sites More sharing options...
Crewwolfy Posted May 11, 2015 Share Posted May 11, 2015 Yeah, I noticed that the wattage is for the pairs shortly after posting. Seems odd, but bigger numbers sell more, I suppose. I went with one of the kits originally posted. Tired of having to replace halogens every year.. :P Link to comment Share on other sites More sharing options...
RazorWing Posted May 13, 2015 Share Posted May 13, 2015 This is an amazing write up! I think this will be a thing to do when I pull the fairing off to replace the cluster bulbs.Question, where you can get the retaining rings mentioned in step 4? Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted May 13, 2015 Member Contributer Share Posted May 13, 2015 They aren't actually necessary. I've installed countless H4 bulbs (incandescent and LED) without the rings. Just bend or clip off the bottom two and the spring retainer holds them in place no issues. The previous owner of my ST1300 tried to get clever and trim them so all three fit into the slots, but all that did was take up his time, and also slightly skew the bulb because it made the top tab not exactly at 12 O'clock. Link to comment Share on other sites More sharing options...
RazorWing Posted May 15, 2015 Share Posted May 15, 2015 They aren't actually necessary. I've installed countless H4 bulbs (incandescent and LED) without the rings. Just bend or clip off the bottom two and the spring retainer holds them in place no issues. The previous owner of my ST1300 tried to get clever and trim them so all three fit into the slots, but all that did was take up his time, and also slightly skew the bulb because it made the top tab not exactly at 12 O'clock. Awesome, thanks! Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Lifetime LED has a new one: https://www.lifetimeledlights.com/led_lights/h4_led_bulb_h4_led_headlight_bulbs Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Lifetime LED has a new one: https://www.lifetimeledlights.com/led_lights/h4_led_bulb_h4_led_headlight_bulbs I wonder if they are water proof ? https://www.youtube.com/watch?feature=player_embedded&v=dnxvsZf6jAE#t=29 Link to comment Share on other sites More sharing options...
Member Contributer digitallyhip Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Lifetime LED has a new one: https://www.lifetimeledlights.com/led_lights/h4_led_bulb_h4_led_headlight_bulbs Hmmmm. More expensive and WAY less light than the separate ballast model (which I have and love). Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 It's $150 for the pair vs $125 for your single. Link to comment Share on other sites More sharing options...
RazorWing Posted May 25, 2015 Share Posted May 25, 2015 Lifetime LED has a new one: https://www.lifetimeledlights.com/led_lights/h4_led_bulb_h4_led_headlight_bulbs I believe those are bulbs only. The full kit I was told was the $250 kit. This is why I held off for now. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Full kit for what? The other link from digitallyhip is just a brighter version at $125 each. The link I put up is a newer version of what I originally bought last year. Looks like they don't require a separate driver box now. Link to comment Share on other sites More sharing options...
Member Contributer digitallyhip Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 It's $150 for the pair vs $125 for your single. Nice catch! Sorry for the misinformation. But I still prefer brighter. Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 And I prefer not $250! Link to comment Share on other sites More sharing options...
Member Contributer ggathagan Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Lifetime LED has a new one: https://www.lifetimeledlights.com/led_lights/h4_led_bulb_h4_led_headlight_bulbs Nice! looks like a direct plug-in replacement. The only question is whether or not there's room for the heatsink/fan component of the bulb behind the bulb housing. A quick visual check makes me think you'd run into clearance issues for the brake hoses and wiring. Link to comment Share on other sites More sharing options...
RazorWing Posted May 25, 2015 Share Posted May 25, 2015 Full kit for what? The other link from digitallyhip is just a brighter version at $125 each. The link I put up is a newer version of what I originally bought last year. Looks like they don't require a separate driver box now. The whole assembly. I called them 2 weeks ago and was told the $150 was just replacement bulbs and needed the $250 set up to do a full conversion from H4 to H4 HID. That may have been wrong though as the $250 price tag is what put me off and I just left the working bulbs in for now. It would be great if the $150 kit worked though! Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted May 25, 2015 Member Contributer Share Posted May 25, 2015 Lifetime LED has a new one: https://www.lifetimeledlights.com/led_lights/h4_led_bulb_h4_led_headlight_bulbs Nice! looks like a direct plug-in replacement. The only question is whether or not there's room for the heatsink/fan component of the bulb behind the bulb housing. A quick visual check makes me think you'd run into clearance issues for the brake hoses and wiring. I have a similar type, probably the same dimensions, and it fits fine. I think it's in a much earlier post the size of the housings I installed. (Page 16) Hey Razor, I'm still not clear on if we are talking about the same things here. These are just LED headlights, not a full HID. Link to comment Share on other sites More sharing options...
