SEBSPEED Posted August 13, 2014 Share Posted August 13, 2014 Thank you for your interest Willy, look for a pm from me shortly. I am currently out of stock, but a new batch is in the works. Quote Link to comment Share on other sites More sharing options...
bluewaffle Posted September 14, 2014 Share Posted September 14, 2014 (edited) anyone tried using counter sink washers? would probably need to replace the bolts. but looks so good Edited September 14, 2014 by bluewaffle Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 14, 2014 Member Contributer Share Posted September 14, 2014 That looks good ^^^ Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted September 15, 2014 Share Posted September 15, 2014 I thought about it but didn't find any during a brief search. The bolt size is M6x1 Quote Link to comment Share on other sites More sharing options...
signal Posted September 15, 2014 Share Posted September 15, 2014 Super nice looking! Quote Link to comment Share on other sites More sharing options...
bluewaffle Posted September 15, 2014 Share Posted September 15, 2014 I thought about it but didn't find any during a brief search. The bolt size is M6x1 would you know the bolt length seb? if i can get the length of the clutch bolt and the diameter of the washer part of the head of the bolt. i can maybe find something and test it out. Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 15, 2014 Member Contributer Share Posted September 15, 2014 And the beat goes on .. Quote Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted September 16, 2014 Member Contributer Share Posted September 16, 2014 I thought about it but didn't find any during a brief search. The bolt size is M6x1 would you know the bolt length seb? if i can get the length of the clutch bolt and the diameter of the washer part of the head of the bolt. i can maybe find something and test it out. Bolt thread and washer is ~25mm length, thread ~23.4mm, washer ~1.6mm thick. Washer OD is ~16.67-16.7mm. OEM bolts on a '99 5th gen. 1 Quote Link to comment Share on other sites More sharing options...
bluewaffle Posted September 17, 2014 Share Posted September 17, 2014 what do you guys think of this combo? http://www.probolt-australia.com/stainless-steel/stainless-steel-bolts-and-washers-countersunk/stainless-steel-countersunk-bolt-m6-x-1-00mm-x-25mm.html#.VBk2Z_na58F http://www.probolt-australia.com/aluminium/aluminium-bolts-and-washers-countersunk/aluminium-countersunk-washer-m5-red.html#.VBk2xfna58E Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 17, 2014 Member Contributer Share Posted September 17, 2014 a m6 bolt with a m5 washer?? (Note, I'm an accountant, not a techie....) I measured the pressure plate hole that accommodate the springs: 21mm The M5/M6 Probolt washers have a 19mm OD, leave 1mm "room" on either side The original bolts have a 16.7 mm washer, which has a little lateral play, so in effect has 2mm "room" on either side. I will let the technie's chip in to say if this is of concern or not. If not, what is the view on using the aluminum (comes in color) bolts? Too weak must use stainless? the holes themselves are 61mm "deep" But there is "only" 33mm thread; so no worries if bolts are a bit longer (I put in a M6 bolt with 40mm thread length and it "stopped" with 7mm to go) Quote Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted September 17, 2014 Member Contributer Share Posted September 17, 2014 what do you guys think of this combo? http://www.probolt-australia.com/stainless-steel/stainless-steel-bolts-and-washers-countersunk/stainless-steel-countersunk-bolt-m6-x-1-00mm-x-25mm.html#.VBk2Z_na58F http://www.probolt-australia.com/aluminium/aluminium-bolts-and-washers-countersunk/aluminium-countersunk-washer-m5-red.html#.VBk2xfna58E Looks good. ^^^^^^ BANKER ^^^^^^ Quote Link to comment Share on other sites More sharing options...
bluewaffle Posted September 17, 2014 Share Posted September 17, 2014 a m6 bolt with a m5 washer?? (Note, I'm an accountant, not a techie....) I measured the pressure plate hole that accommodate the springs: IMAG0288.jpg 21mm The M5/M6 Probolt washers have a 19mm OD, leave 1mm "room" on either side The original bolts have a 16.7 mm washer, which has a little lateral play, so in effect has 2mm "room" on either side. I will let the technie's chip in to say if this is of concern or not. If not, what is the view on using the aluminum (comes in color) bolts? Too weak must use stainless? the holes themselves are 61mm "deep" IMAG0289.jpg But there is "only" 33mm thread; so no worries if bolts are a bit longer (I put in a M6 bolt with 40mm thread length and it "stopped" with 7mm to go) 33mm.jpg the only real question for me is if the 19mm washer will work Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 17, 2014 Member Contributer Share Posted September 17, 2014 That is my question too! Quote Link to comment Share on other sites More sharing options...
bluewaffle Posted September 17, 2014 Share Posted September 17, 2014 found 18mm OD washers. http://www.ebay.com.au/itm/321461969778?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 Quote Link to comment Share on other sites More sharing options...
Motographer Posted September 19, 2014 Share Posted September 19, 2014 I'd definitely like to know when you have a new batch available. Lowsided and tore the hell out of my clutch cover today, so I'm in need of one that doesn't leak oil. Quote Link to comment Share on other sites More sharing options...
wera803 Posted September 19, 2014 Share Posted September 19, 2014 I'd definitely like to know when you have a new batch available. Lowsided and tore the hell out of my clutch cover today, so I'm in need of one that doesn't leak oil. Are you interested in one that is rashed, but does not leak to put on your bike until Seb can do another batch of window covers? You could send your broken one to him for the work and not have your bike down. PM me if you are interested. Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted September 19, 2014 Share Posted September 19, 2014 Alternatively, I also fix broken & rashed covers without putting a window in. Have TIG, will weld... Rings are in limbo with no ETA right now, best I can offer at the moment is to fix a break. Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 25, 2014 Member Contributer Share Posted September 25, 2014 Operation "Countersunk" Mwah..... The M3 torx with countersunk washers along the rim are a bit too large versus the size of the window frame methink..... I will probably go back to the M3's that Seb put in As for the spring bolts+washer, the dark blue Pro-Bolts were a larger diameter so I decided against them, went for black instead. with SS torx counter sunk... Am a bit underwhelmed.... so will keep an eye out for different washers... Put in new stronger springs in "on the house" Lever pull marginally stronger but I like the feel when accellerating Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 25, 2014 Author Share Posted September 25, 2014 i thought you would go for blue........ Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 25, 2014 Member Contributer Share Posted September 25, 2014 The only -dark- blue countersunk washers I found are Pro-Bolt and they are 19mm diameter. As I wrote above, the OEM washers are <17mm and the holes in the pressure plate are 21mm. My black ones are 18mm; but the blue from that Mfrs are a light blue. Light as the bolts I had put on previously (and I donot like cos the blue is too light). As you can see, I do not have anything else to worry about in my life.... Quote Link to comment Share on other sites More sharing options...
Motographer Posted September 25, 2014 Share Posted September 25, 2014 Seb, I'll probably just get a new cover, keep my rashed one in reserve, and keep an eye out for you to get new rings in :) Quote Link to comment Share on other sites More sharing options...
bluewaffle Posted September 26, 2014 Share Posted September 26, 2014 Omg dutchy!! I was gonna show them first! U bitch!! Quote Link to comment Share on other sites More sharing options...
Member Contributer zoomzoom Posted September 26, 2014 Member Contributer Share Posted September 26, 2014 Though I have seen this thread before and love the look of the cover, would anyone happen to have a photos of one of these magical pieces of visual eye candy installed on a 5th gen?? Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 26, 2014 Author Share Posted September 26, 2014 ZZ click here, completed pics are further down. http://www.vfrdiscussion.com/forum/index.php/topic/68154-clutch-and-grab/ Quote Link to comment Share on other sites More sharing options...
Member Contributer zoomzoom Posted September 26, 2014 Member Contributer Share Posted September 26, 2014 Cool. I had actually seen those pictures but I thought for some reason your bike was a 6th gen given the undertail exhaust. Perhaps you have installed a 6th gen tail onyerbike?? Thanks for the link and YES, tha does look very cool. Might have to add that to the list of winter improvements. I think getting one of the DMr front fork kits may be required first however. Really like therapist scheme onyourbike to Veefer800. Quote Link to comment Share on other sites More sharing options...
