Hello everyone... New here, so hopefully you'll excuse my ignorance around VFR's and send me a few pointers to help!!
I have built a couple of Ducati's before and they are quite agricultural compared to the Honda's and especially the VFR. I bought a 5th Gen 2001 engine and frame and have also bought a pre HISS / VTEC ignition and ECU (think it is a first model Gen 5 ignition). I want to test the starter circuit and get the thing running with a bit of 'Easy-Start' or something like that. Indecently this is a project build (not a restoration), which I will share on the forum if I get past this bit!
I have rigged things up as you can see in the pics, but would like to ask the question of the forum. What do I need to ensure I have hooked up, so I can switch on the key, select run and flick the starter switch to get the thing turning over. I know a VFR like things to be in order, whereas a Ducati will start if you can jam a lolly-pop stick in the ignition!
So, I have done the following:
- Plugged in ECU
- Connected ignition barrel and key
- Connected tilt switch
- Connected the injector bodies to the loom
- Connected the starter motor / battery to the starter solenoid
- Connected engine stop relay
- Connected main ground and battery ground
- Connected coils
I am just pulling this together, so this isn't the result of 4 weeks banging my head against a wall, just looking for a checklist really to avoid the head-banging in the first place. Needless to say, with the above connected I get nothing... not even a click.
Question
WillMitch
- Plugged in ECU
- Connected coils
Do I need to connect a few more relays etc?
Help welcomed.
Will
19 answers to this question
