Member Contributer Popular Post vfrcapn Posted September 12, 2021 Member Contributer Popular Post Posted September 12, 2021 Just posting about a few things done on the '99, I'm coming up on 20-years of ownership this week (9/14) and just short of 118K miles. Finished up adding the Ducati 1098 rear wheel conversion with the Australian Extreme Creations kit. And more Sebspeed Customs parts, custom cut RC51 triples with an offset closer to the original VFR specs, with a Rizoma bar. VFRD Wild headers mated to the completely refurbished Wolf exhaust from sfdownhill, done late last year. And just had the Ohlins serviced a few weeks ago. More to come eventually, on the lookout for some forged wheels. Thanks to Sebspeed for the work to create the triples, awesome design. 13 Quote
Member Contributer Ughandi Posted September 13, 2021 Member Contributer Posted September 13, 2021 oohh... rearset pegs on a 5th gen..... tell me your ways! Quote
Member Contributer Dangeruss Posted September 13, 2021 Member Contributer Posted September 13, 2021 I had the same reaction when I saw this some time ago. Those are Harris Rearsets, which they don't make anymore. Seb also produced some nice looking adapters but has said he is too busy to produce more at this time, I see you have placed an ad for some. The third option that I am pursuing is to install the lower shock mounting bracket (BRACKET, RR. CUSHION (LOWER) in Honda lingo, P/N 50475-MCW-D00). This is the same part on all 6th and 8th gen and bolts on to the 5th gen, allowing you to use later model resets as well as aftermarket ones such as Sato, https://www.satoracing.com/rearsetsVFR800.htm You will need some of the associated parts such as the through bolts and so on, easy enough to figure out if you look at parts fiche. I have the casting in hand, the rest is a winter project along with replacing the forks, delinking the brakes, installing VFRD headers and an RC51 tail section. 2 1 Quote
Member Contributer Thumbs Posted September 13, 2021 Member Contributer Posted September 13, 2021 I’ve just had a look at AliExpress and these look a good starting point for cannibalising for the price, a simple adapter plate between stock and the new ones £62.87 29% Off | Full CNC Aluminum Motorcycle Adjustable Rearsets Rear Sets Foot Pegs For HONDA CBR600RR NON-ABS 2009 2010 2011 2012 2013-2017 https://star.aliexpress.com/share/share.htm?image=U9ce99e7d1f004d8e8ac3383a58deb84ai.jpg&businessType=ProductDetail&title=£62.87 29% Off | Full CNC Aluminum Motorcycle Adjustable Rearsets Rear Sets Foot Pegs For HONDA CBR600RR NON-ABS 2009 2010 2011 2012 2013-2017&platform=AE&redirectUrl=https%3A%2F%2Fwww.aliexpress.com%2Fitem%2F1005001597972999.html%3F%26srcSns%3Dsns_Copy%26tid%3Dwhite_backgroup_101%26mb%3D42zWXXe5q0KWYoO%26businessType%3DProductDetail%26spreadType%3DsocialShare Quote
Member Contributer vfrcapn Posted September 14, 2021 Author Member Contributer Posted September 14, 2021 They are Harris rearsets, I think they were oem on the 50th Anniv. bike? Throwing out a pic of Sebspeed's triples too before I mounted them. Offset set at 35mm, mid-point between the VFR 40mm and the RC 30mm. Cerakote H coating in a simple graphite black. I know he isn't on vfrd much but can be found on FB at https://www.facebook.com/SebspeedCustoms/ 4 Quote
Member Contributer Ughandi Posted September 14, 2021 Member Contributer Posted September 14, 2021 20 hours ago, Dangeruss said: I had the same reaction when I saw this some time ago. Those are Harris Rearsets, which they don't make anymore. Seb also produced some nice looking adapters but has said he is too busy to produce more at this time, I see you have placed an ad for some. The third option that I am pursuing is to install the lower shock mounting bracket (BRACKET, RR. CUSHION (LOWER) in Honda lingo, P/N 50475-MCW-D00). This is the same part on all 6th and 8th gen and bolts on to the 5th gen, allowing you to use later model resets as well as aftermarket ones such as Sato, https://www.satoracing.com/rearsetsVFR800.htm You will need some of the associated parts such as the through bolts and so on, easy enough to figure out if you look at parts fiche. I have the casting in hand, the rest is a winter project along with replacing the forks, delinking the brakes, installing VFRD headers and an RC51 tail section. Why must all the things I want be limited-runs 😭 Thanks for the pointer for that "Harris" set. I sent them an email, and put a watch on ebay for them. My Classifieds listing is likely wishful thinking... but who knows! I may get lucky. As for the rear cush drive, I read a lot of archived forums for that, but IIRC the conclusion was that the sizing didnt quite mate up right... But if it can be done, I'm not foreign to big-item swaps... (would be a good excuse to do that ZX10r or 929 shock upgrade since "I'm already in there" -- the most financially dangerous phrase said in builds 😄) Ah! If you ride hard, you will love the De-link! I did mine (rebuilding both masters -- F4i rear BMC, and rebuilding all calipers + drilling) and HO BABY I can stoppie the front and skid the rear now! The skill ceiling raises quite a bit after the delink, and I get FAR more stopping power in the front -- I paired it with the sexy "Braking" SK2 rotors. Good luck with the build! 1 1 Quote
Member Contributer Ughandi Posted September 14, 2021 Member Contributer Posted September 14, 2021 7 hours ago, vfrcapn said: They are Harris rearsets, I think they were oem on the 50th Anniv. bike? Throwing out a pic of Sebspeed's triples too before I mounted them. Offset set at 35mm, mid-point between the VFR 40mm and the RC 30mm. Cerakote H coating in a simple graphite black. I know he isn't on vfrd much but can be found on FB at https://www.facebook.com/SebspeedCustoms/ That is some impressive eye-candy... Quote
Member Contributer ducnut Posted September 14, 2021 Member Contributer Posted September 14, 2021 Check this guy on FB. He has tons of Ducati stuff. Two different FB pages, but, the same dude. Quote
Member Contributer Cogswell Posted September 14, 2021 Member Contributer Posted September 14, 2021 Interesting cutaway. It would be great on display in a man cave. Quote
Member Contributer sfdownhill Posted September 27, 2021 Member Contributer Posted September 27, 2021 On 9/11/2021 at 10:21 PM, vfrcapn said: Finished up adding the Ducati 1098 rear wheel conversion with the Australian Extreme Creations kit. And more Sebspeed Customs parts, custom cut RC51 triples with an offset closer to the original VFR specs, with a Rizoma bar. VFRD Wild headers mated to the completely refurbished Wolf exhaust from sfdownhill, done late last year. And just had the Ohlins serviced a few weeks ago. Beautiful work, Capn. Not only a goer, but also a shower. Bet it sounds schweet. 1 Quote
