8200rpm Posted March 16, 2020 Posted March 16, 2020 So the little plastic nub on inside of the switch pod housing that fits into the clip-on recess hole broke off. So the entire housing free spins on the clip-on. It's especially annoying when I'm trying to open and close the choke (fast idle lever). Is there a hack or fix for this? I tried torquing down on the screws but that only clamps the two plastic parts together. It doesn't provide any additional clamping force onto the clip-on. Quote
Member Contributer ChrisBezz Posted March 16, 2020 Member Contributer Posted March 16, 2020 Hi, 8200 - just wondering, how did it happen? Chris B. Quote
Member Contributer carlgustav Posted March 16, 2020 Member Contributer Posted March 16, 2020 If you just need a simple hack for the near term (and this is truly a hack), then get some of the anti-slip tape (Lowes, Skid Guard) and wrap just enough under the housing to clamp on. It's been working for me on my track bike for many seasons. It's not a proper fix and doesn't look great up close, but works ... ACE 1 Quote
Member Contributer JZH Posted March 16, 2020 Member Contributer Posted March 16, 2020 Any second-hand Honda switch pod from eBay that looks like yours should swap housings with yours. Of course, it could also snap off... Ciao, JZH Quote
Member Contributer Terry Posted March 16, 2020 Member Contributer Posted March 16, 2020 You could also do what some bodger PO did to my new purchase; drill through the switch casing and into the bar, and insert a self-tapping screw. This was done from below where it's not obvious, and doesn't affect functionality, but its not exactly elegant. Quote
Member Contributer MaxSwell Posted March 17, 2020 Member Contributer Posted March 17, 2020 Just brain storming here. Can you replace the broken nub with anything and some plastic glue? Plasti-Fix works on ABS. Replace it with a metal pin with threads into the housing? 2 Quote
8200rpm Posted March 17, 2020 Author Posted March 17, 2020 17 hours ago, ChrisBezz said: Hi, 8200 - just wondering, how did it happen? Chris B. It might have weakened over time from the resistance of the choke lever. More likely, the nub wasn’t lined up to the recess when I installed it. So, it could have snapped off when I tightened the screws. Quote
8200rpm Posted March 17, 2020 Author Posted March 17, 2020 22 minutes ago, MaxSwell said: Replace it with a metal pin with threads into the housing? This might be the most elegant fix. I gotta find a small Allen set screw that’s about the same diameter as the hole in the clip on. Drill a little hole in the plastic housing and thread it through. Thanks for the idea! 1 Quote
Member Contributer MaxSwell Posted March 17, 2020 Member Contributer Posted March 17, 2020 6 minutes ago, 8200rpm said: This might be the most elegant fix. I gotta find a small Allen set screw that’s about the same diameter as the hole in the clip on. Drill a little hole in the plastic housing and thread it through. Thanks for the idea! Perfect! Quote
JoelF Posted March 17, 2020 Posted March 17, 2020 The rude solution is a few wraps of electrical tape on the bar. It's soft enough to get mashed into the crevices and lock the pod to the bar pretty well. Quote
Member Contributer ChrisBezz Posted March 18, 2020 Member Contributer Posted March 18, 2020 Ha! maxSwell beat me to it! I thought of suggesting a piece of metal rod with a thread cut into it. Same end result. i hope you get it sorted? Chris B. Quote
