Epyon007 Posted November 28, 2016 Share Posted November 28, 2016 Where have you people put power sockets? I'm thinking the USB kind, but it may be better to get a normal one. I just don't see that there is a ton of space for one. I'm sure you all have figured out some great solutions. Link to comment Share on other sites More sharing options...
cat0020 Posted November 28, 2016 Share Posted November 28, 2016 Depends on the purpose.. for GPS/smartphone, I put it close to the handlebars. For heated jacket/liner/gear, I put it next to the tank, next to my left inner thigh for easy access of temperature adjustment on-the-fly. Link to comment Share on other sites More sharing options...
hellindustries Posted November 28, 2016 Share Posted November 28, 2016 I got an Oxford twin USB socket, cut a slightly too small rectangular hole in the cover and rammed a cable in there. Placed the socket on the left of the bike just rear of the Reg/Rec and ran the cable to the bars. When not in use, i can just tuck it under the tank and it stays dry, even in heavy rain. I used a USB extension cable so i have options without rewiring. As for taking power; I chose poorly - I took a positive off the rear lights. It blows a bulb when i use it. I'll be taking positive from the back of the starter relay when i get around to fixing it. Though i'll probably run a heavy guage to a multi connector block so that i can run whatever other stuff off of it in future. More for neatness and a clean install, really. Link to comment Share on other sites More sharing options...
Epyon007 Posted November 28, 2016 Author Share Posted November 28, 2016 This would be for phone/GPS usage. I was hoping to see about getting it nicely integrated into the upper fairing somehow I just don't think there is much room for it. I also was hoping to make it not involve the side fairings so I could take them off with out to much mucking about. Link to comment Share on other sites More sharing options...
hellindustries Posted November 28, 2016 Share Posted November 28, 2016 Well, if you want it doing properly etc... You COULD go the route of fitting the pos/neg of the USB socket to the battery, and then routing it as i described. Upside is that the only bodywork you really need to move is the seat, and maybe lift the tank for a neater routing. Downside is that the USB socket is constantly on. Doesn't draw much at all, but if you leave it for weeks at a time? Yeah. Link to comment Share on other sites More sharing options...
Epyon007 Posted November 29, 2016 Author Share Posted November 29, 2016 Yeah that would seem to be the best for weather and cleanest install. Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted November 29, 2016 Member Contributer Share Posted November 29, 2016 Headstock, through the black plastic cap. You can mount the sat nav holder onto the 2 tank bolts. Link to comment Share on other sites More sharing options...
Epyon007 Posted November 29, 2016 Author Share Posted November 29, 2016 I like that idea! Is there a kit for it or something that you know of? Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted November 29, 2016 Member Contributer Share Posted November 29, 2016 RAM Mounts do a tank-bolt mount. I'm sorry but I don't have the serial number, but it shouldn't be too difficult to find on their website. As for the power cable....you need a length with a waterproof connector to sit on the headstock and battery connectors at the other end (or route it via a switched power source - I'm not an electrician, sorry). Then a short connecting cable from the headstock to the sat nag. I simply drilled a hole through the plastic cap and fed the cable through before I soldered the end. Worked beautifully. Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted November 29, 2016 Member Contributer Share Posted November 29, 2016 14 minutes ago, Skids said: RAM Mounts do a tank-bolt mount. RAM-B-149ZU https://www.amazon.com/gp/product/B000XDGJQI/ Link to comment Share on other sites More sharing options...
Member Contributer Skids Posted November 29, 2016 Member Contributer Share Posted November 29, 2016 6 minutes ago, thtanner said: RAM-B-149ZU https://www.amazon.com/gp/product/B000XDGJQI/ That looks like the one, but you can discard the semi-circle clamp and simply bolt the mount onto the tank bolt holes. Link to comment Share on other sites More sharing options...
hellindustries Posted November 29, 2016 Share Posted November 29, 2016 Speaking of RAM mounts; I think this is a better option, certainly less obtrusive when not in use. Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted November 29, 2016 Member Contributer Share Posted November 29, 2016 1 hour ago, Skids said: That looks like the one, but you can discard the semi-circle clamp and simply bolt the mount onto the tank bolt holes. Yup! Here's how I have mine setup. Link to comment Share on other sites More sharing options...
GleninAus Posted November 29, 2016 Share Posted November 29, 2016 Remove the plastic cap on the steering head and insert one of these. http://www.ebay.com.au/itm/RAM-Mount-Fork-Stem-Mount-KTM-1-IN-Ball-Phone-GPS-Camera-Mount-Base-Tablet-Stem-/311611067744?hash=item488d778d60 My GPS is a Garmin Zumo and comes with a permanent mount. Has a harness that that runs from the battery and even includes an extra USB lead that you can charge your phone from so you can keep getting those real time Bluetooth updates to the GPS or recharge your helmet Bluetooth. Listening to Music, Pandora or Spotify while on the move tends to drain a lot of battery. Link to comment Share on other sites More sharing options...
Epyon007 Posted November 30, 2016 Author Share Posted November 30, 2016 It would be nice if there was a USB socket that fit in to head stock. Great set ups everyone, thanks for sharing. Thtanner your socket is mint! Link to comment Share on other sites More sharing options...
artpongs Posted February 14, 2017 Share Posted February 14, 2017 On 11/29/2016 at 7:09 PM, Epyon007 said: It would be nice if there was a USB socket that fit in to head stock. Great set ups everyone, thanks for sharing. Thtanner your socket is mint! They do make ones that fit into the head stock, you are talking about the steering head hole right? Search for it, I think several makers of that type. Art Link to comment Share on other sites More sharing options...
Loftust Posted February 14, 2017 Share Posted February 14, 2017 On 29/11/2016 at 7:18 PM, hellindustries said: Speaking of RAM mounts; I think this is a better option, certainly less obtrusive when not in use. That's a beautiful thing. It's a shame the cable can't be routed through the headstock as well with this option...unless you drill a hole in it's stem, which may weaken the mounting arrangement. Sticking a relay into the circuit is a good idea too. It's very simple, and all you need is a mini 12v automotive relay, some wire, and a few electrical connectors (crimps are ok, but soldered are much better). The main issue that people have is finding the right sort of feed to switch the relay on (ignition live), thereby allowing the load to draw power from the battery. If your lights are on all the time, whether you turn them on manually or they come on automatically, then the rear light wire is probably a good one to use for the relay switching, but NOT as the source of the power for the applicance itself; the licence plate/number plate light is also a fairly sensible one too. This arrangement also allows for the circuit to be fused as well, which is obviously a good thing. If you get yourself such a relay, the numbering is common, therefore the load can be connected up thus: 30 = battery +ve terminal (preferably with in-line fuse) 87 = load (heated grips, sat nav etc) +ve 85 = ignition or switched live (e.g. rear lights) 86 = battery -ve terminal The load/appliance will need to be earthed to somewhere on the frame/block as well, or directly to the battery -ve terminal. Disconnecting the battery before doing this is a sensible idea too. Link to comment Share on other sites More sharing options...
artpongs Posted February 14, 2017 Share Posted February 14, 2017 Loftust, I would like to mount up auxiliary led driving lights, and a USB port to switched power. How would I go about this? The relay would have those numbers on them? Would I need relays for both of these? Art Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted February 14, 2017 Member Contributer Share Posted February 14, 2017 You'd be better off finding a small fused power block that has switched power via a relay. WireMyBike should still have some available on their website that fit under the seat. That way you only have one relay, and one connection to the battery. Link to comment Share on other sites More sharing options...
artpongs Posted February 14, 2017 Share Posted February 14, 2017 5 hours ago, KevCarver said: You'd be better off finding a small fused power block that has switched power via a relay. WireMyBike should still have some available on their website that fit under the seat. That way you only have one relay, and one connection to the battery. That looks like a nice unit. So I see it has 4 circuits. I actually have 3 things I would like to install on both of my bikes, Hawk GT and VFR800. Voltmeter, USB port, and led auxiliary driving lights. I can just hardwire these into once circuit each and have one left over? How do I install the block into the bike? I don't see a manual I can review. Art Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted February 14, 2017 Member Contributer Share Posted February 14, 2017 It's super easy. Just need to wire the positive side of the block to the battery +, and I like to ground the - to the frame rather than the battery. Just my preference. Works either way. The relay will have a trigger wire. That can be tapped into the tag light wire pretty easily. All that does is open the relay. Once the relay is open the fuse block will be drawing power off the battery. The fuse block will only provide positive power to each of the circuits you install, and you will have to provide fuses appropriate to each accessory. Volt meter will require very low amps, aux lighting a bit more. I'm sure the lighting packing will tell you how many amps they draw. USB will also be very low. Generally phone chargers are 2.1 amp max. GPS may be more, again it should be in the instructions provided with the unit. Or folks here will know. For the grounds, again I like the frame. Anything in the front of the bike will require a wire to the fuse block for the positive power, but the ground can be bolted to the front of the frame to avoid having to run another wire to the battery. I've got the same fuse block on my '99 and it fits fine under the seat just to the rear of the battery, and I tapped the tag light for the relay trigger. Be sure to put a sticker or something on the top of the fuse cover to label what each circuit is. Quick tip for the battery terminals: Stick a bit of foam rubber under the captured nut on each terminal. Ear plugs work great for this. That ensures the nut is always at the top of the terminal. Sometimes with a couple ring terminals for accessories the bolt won't reach far enough to engage the nut. That ends up being a major PITA! Link to comment Share on other sites More sharing options...
artpongs Posted February 14, 2017 Share Posted February 14, 2017 Kev, Can I see your farkle setup and how you setup things? The led auxiliary lighting says they only draw .75 amps for the pair. The harness for the lights already have a 5 amp fuse. USB port I have has a 7.5 amp fuse inline. Would I need a fuse for the voltmeter, if so what should I get? Art Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted February 15, 2017 Member Contributer Share Posted February 15, 2017 I think I used a 3a for the voltmeter. Not sure there is a smaller one. It's probably actually well under 1a draw. You can see my fuse block between the battery tray to the left and seat rail on right. The relay is above it. There is a purple trigger wire from the relay to the tag light. Main power from the relay to the battery through a supplied 30a fuse on the orange wire. Power out of the relay to the fuse block is red and splits into 4. Green ground wire is bolted to the rear subframe. I've only got circuits for heated gear, heated grips, and air horn. I never remounted my voltmeter after I rebuilt the bike a few years ago because the stator rewind and FH012 reg/rec never gives me any trouble. I had a cheap 2.1a USB charger wired up and stuck up under the front fairing. I tried to use it one time after it was installed for over a year and it was already broken. That's why I have one circuit labelled "Charger" but nothing plugged into it. I do still have a wire for a voltmeter running from the front fairing to the fuse block, just in case I ever decide to remount it. The other red wire and fuse holder in the pic is the DC power out of the R/R. It's got a black sheathing on it until it passes under the relay, then it's red coming from there. It's not related or connected to the fuse block or relay. Positive is through a 30a direct to the battery and negative is grounded to the frame. I bypassed the main harness for power from the R/R and eliminated the dodgy connections. I'm also on record as being against the VFRness for that very reason. It adds more connections but without improving on the quality of the connectors. But that's a whole other thread... Link to comment Share on other sites More sharing options...
Member Contributer 007 Posted February 15, 2017 Member Contributer Share Posted February 15, 2017 Although Kevin's awesome installation above is probably one of the best I have seen, I'm a fan of the Eastern Beaver fuse block. There are different options for switched / unswitched power. I went all switched for my needs. Unlike traditional blocks, it is small and weatherproof so you can mount it virtually anywhere and don't need to take up valuable storage space under the seat. I don't have one on the VFR, but loved it so much on my K12S that its now on the CB500X. http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/3_Circuit/3CS-Sealed/3cs-sealed.html Link to comment Share on other sites More sharing options...
Member Contributer KevCarver Posted February 15, 2017 Member Contributer Share Posted February 15, 2017 31 minutes ago, 007 said: Although Kevin's awesome installation above is probably one of the best I have seen, I'm a fan of the Eastern Beaver fuse block. There are different options for switched / unswitched power. I went all switched for my needs. Unlike traditional blocks, it is small and weatherproof so you can mount it virtually anywhere and don't need to take up valuable storage space under the seat. I don't have one on the VFR, but loved it so much on my K12S that its now on the CB500X. http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/3_Circuit/3CS-Sealed/3cs-sealed.html If you like that compact size and are good with DIY, I have this (that was a lot less $$) in my toolbox waiting for the next bike I need to wire up. But don't worry, WireMyBike's fuse block has a water/dust sealed cover over the fuses. On the 5th Gen there is plenty of room for the bigger fuse block. It fits under the main seat where I've never needed to store anything anyway. Also, you can find multi packs of fuses at any auto parts store or WalMart, etc. Link to comment Share on other sites More sharing options...
