Jashue Posted April 17, 2016 Share Posted April 17, 2016 I had the reflash done last week on my 2010 which I purchased brand new last September, and due to some pretty frigid weather around here (that, plus my work schedule) I haven't had a lot of time to rack up too many miles. That is-- until yesterday. I put in about 200 miles of a combination of backroads and interstate riding yesterday, and I have to say that the new bike is everything that everyone has been raving about. I call it a new bike, because that is exactly how it feels. The newness of this experience has been compounded by the fact that at the same time I had the newly reflashed ECU put in, I had a Dam exhaust put on. In retrospect, I wish that I could have had the two procedures done separately because both changes have affected the riding experience pretty dramatically. It might have been nice to see what the Guhl treatment would be on an even playing field. Either one of these changes would have left me smiling, but having them together, I'm pretty blissed out about my new VFR. I thought I'd chime in to let anyone who may be on the fence about the reflash. Link to comment Share on other sites More sharing options...
vfrflanders Posted April 26, 2016 Share Posted April 26, 2016 It's very difficult, if not impossible to compare SAE HP en DIN. 1. 1 SAE HP is approx. 745,7 Watt and 1 DIN HP is approx 735,5 Watt So a 173 SAE HP motorcycle is approx 129 kW and a 173 DIN HP motorcycle is approx. 127,2 kW Conversion formulas DIN HP = SAE HP * 1.0142 SAE HP = DIN Hp * 0.9860 2. SAE HP is a measurement of the engine's power without fixed accessories. and DIN HP is a measurement of the engine's power with ALL fixed accessories, such as inlet and outlet, fan, water, fuel and injection pump. (no alternator). Only a proper dynorun (with conversion) can give you a good idea when you compare DIN with SAE Link to comment Share on other sites More sharing options...
Quinvg Posted May 11, 2016 Share Posted May 11, 2016 Ive just got mine back from a Don Guhl reflash ... haven't had it on a long ride but its much more fun to ride in town. And all the horses on tap from the start ... I'm not sure about the Belgium service, but Guhl has brilliant service. Well worth the money! Link to comment Share on other sites More sharing options...
Auron Posted May 14, 2016 Share Posted May 14, 2016 On 3/20/2016 at 10:30 PM, RC1237V said: I don't know what the OP bought but this is what I bought: USB: http://www.amazon.com/gp/product/B00W3W6AMU?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00 Volt Gauge: http://www.amazon.com/gp/product/B00S7FUT10?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00 This one is a little different but it has the volt meter in one. Any reason it won't work? Didn't you have clearance issues under the panel? http://www.amazon.com/BlueFire%C2%AE-Charger-Socket-Outlet-Voltmeter/dp/B01F3I117E?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=ACKFGXOOEC78X Link to comment Share on other sites More sharing options...
Member Contributer RC1237V Posted May 14, 2016 Member Contributer Share Posted May 14, 2016 56 minutes ago, Auron said: This one is a little different but it has the volt meter in one. Any reason it won't work? Didn't you have clearance issues under the panel? http://www.amazon.com/BlueFire%C2%AE-Charger-Socket-Outlet-Voltmeter/dp/B01F3I117E?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=ACKFGXOOEC78X No clearance issues under the panel as it's mostly hollow, I used a step drill to make the hole the correct size. Be careful, the plastic is soft, and fairly thin.....go easy! Link to comment Share on other sites More sharing options...
Auron Posted May 14, 2016 Share Posted May 14, 2016 Does that mean it's difficult to get the outlet sturdy once mounted? Link to comment Share on other sites More sharing options...
Member Contributer RC1237V Posted May 17, 2016 Member Contributer Share Posted May 17, 2016 On 5/14/2016 at 2:32 PM, Auron said: Does that mean it's difficult to get the outlet sturdy once mounted? No, just tighten up the jam nut below, it may have come with a washer, I cant remember, but I put a dab of silicone on the underside to keep it (the jam nut and socket) from vibrating loose. Link to comment Share on other sites More sharing options...
R1KSU Posted May 21, 2016 Share Posted May 21, 2016 Hi Guys Im in the UK and had my 2014 dct flashed last month, its gone from a fast sports tourer to a missile, top speed now reads 176mph ( 166mph= GPS ) it was limited to 166mph on the speedo before. several of you say you have had yours dyno'd, how do you get around the dct on the dyno, I know its something to do with fooling the abs. I want to get mine dyno'd in the UK but dynojet say it cant be done. my 0-100mph times are almost identical in S or D mode which is odd ( 6 seconds ) Oh one more thing, I think Don Guhl made a mistake on mine as I have now lost my cold start idle ( choke) , it has stalled and runs very lumpy for the first mile or so now until warm. Link to comment Share on other sites More sharing options...
Auron Posted May 22, 2016 Share Posted May 22, 2016 Interesting, did you call him? I thought my old XX fast idle was going out, turns out I was just storing it in a hotter garage. Link to comment Share on other sites More sharing options...
Member Contributer 1996 Beeper Posted July 13, 2016 Member Contributer Share Posted July 13, 2016 Looks like I need to get this done but cant seem to find Dons contact info in the 8 pages here? Link to comment Share on other sites More sharing options...
Chanmenie Posted July 14, 2016 Share Posted July 14, 2016 try here http://www.guhlmotors.com/ Link to comment Share on other sites More sharing options...
Member Contributer 1996 Beeper Posted July 14, 2016 Member Contributer Share Posted July 14, 2016 8 hours ago, Chanmenie said: try here http://www.guhlmotors.com/ Thank you Link to comment Share on other sites More sharing options...
Member Contributer paulmeisterpk Posted August 18, 2016 Member Contributer Share Posted August 18, 2016 Is there any way to tell if the ECU has already been reflashed by Don? Are there markings or a sticker on it anywhere that he adds? Link to comment Share on other sites More sharing options...
marriedman Posted August 18, 2016 Share Posted August 18, 2016 There is a sticker on the ECU, but you will have to remove it to see it I believe. Link to comment Share on other sites More sharing options...
lshark Posted August 19, 2016 Share Posted August 19, 2016 Link to comment Share on other sites More sharing options...
Member Contributer paulmeisterpk Posted August 19, 2016 Member Contributer Share Posted August 19, 2016 Excellent. I'll check this out when I figure out how to take the fairings off. I'm assuming the ECU is under there somewhere. I didn't see it under the seat on first glance. Link to comment Share on other sites More sharing options...
lshark Posted August 19, 2016 Share Posted August 19, 2016 it's in front of the air filter box, right behind the steering head Link to comment Share on other sites More sharing options...
lshark Posted August 19, 2016 Share Posted August 19, 2016 tried to upload a pic of the location but limited to 1.3 MB Link to comment Share on other sites More sharing options...
