choco Posted August 3, 2014 Share Posted August 3, 2014 So the key goes in and out just fine, but the ignition won't turn, something is binding. I started it up for todays ride, rolled it outside, washed it, rolled it back in the garage, dried it, and when it was time to go the ignition switch wouldn't turn. I wiggled the key, joggled the ignition housing, tried both keys, kept wiggling, somewhat desperately as Jim (Bizbat) was likely waiting for me at the Duvall Grill, after have just ridden about 60 miles from Yelm! Finally it turns and I am able to start it. I ride down to the Grill, we have breakfast with my lovely wife and it turns just fine because I left the key in it. We ride about 15 miles to fuel up and I've forgotten my spare key on my workbench when I was fidgen with the ignition in the morning. So I reluctantly take the key out of the ignition and open my fuel tank, and later I insert the key into the ignition and it won't turn. So, long story short, I fidgeted for quite a while until it finally turned on and we rode back and got the other key. I shut my bike off several times on our 270 mile+ ride but didn't take the key out and it turned just fine. I don't dare take the key out until I find out if anybody on VFRD has had this experience and has a fix. I assume I will be ordering a new ignition switch, with brings me to the next question for later. Link to comment Share on other sites More sharing options...
divrnr Posted August 3, 2014 Share Posted August 3, 2014 Mine started doing that but I just sprayed some lock graphite in the tumbler and it has worked fine for the last 4 months. Link to comment Share on other sites More sharing options...
timmythecop Posted August 3, 2014 Share Posted August 3, 2014 my fifth gen ignition has always been tough to turn. I just pull up a tiny bit and it usually works. Link to comment Share on other sites More sharing options...
klrtovfr Posted August 3, 2014 Share Posted August 3, 2014 mine does that, I flip the key over and it works on the one side only. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted August 3, 2014 Share Posted August 3, 2014 I had to replace my ignition switch, they tend to wear out over time. Link to comment Share on other sites More sharing options...
TNRabbit Posted August 3, 2014 Share Posted August 3, 2014 I bought a brand new one & had the same issue after a month. Just lube it generously & problem will be solved. Link to comment Share on other sites More sharing options...
Member Contributer V-FORE Posted August 3, 2014 Member Contributer Share Posted August 3, 2014 Hey Lee try some Tri-Flow lubricant, I still have some after a locksmith recommended it years ago....it works wonders Good Luck! Link to comment Share on other sites More sharing options...
choco Posted August 3, 2014 Author Share Posted August 3, 2014 Thanks for the replies. I will try graphite or tri flow before I order a new ignition. Reading these comments, I think I'm going to try the Tri-Flow http://www.peachparts.com/shopforum/diesel-discussion/204009-graphite-spray-lubricant-ignition-lock.html Hey Lee try some Tri-Flow lubricant, I still have some after a locksmith recommended it years ago....it works wonders Good Luck! Which one did you use? http://www.bing.com/images/search?q=tri+flow+lubricant&id=78FE2FBEAA02D1132291418BE3A10D9FD72DD8B4&FORM=IQFRBA Link to comment Share on other sites More sharing options...
spud786 Posted August 3, 2014 Share Posted August 3, 2014 Just hit it with a shot of wd40, its proven not to cause issue. I used to do lock smith work, don't put dry graghite in a lock or anything with silicone in it either. Link to comment Share on other sites More sharing options...
Member Contributer V-FORE Posted August 3, 2014 Member Contributer Share Posted August 3, 2014 Thanks for the replies. I will try graphite or tri flow before I order a new ignition. Reading these comments, I think I'm going to try the Tri-Flow http://www.peachparts.com/shopforum/diesel-discussion/204009-graphite-spray-lubricant-ignition-lock.html Hey Lee try some Tri-Flow lubricant, I still have some after a locksmith recommended it years ago....it works wonders Good Luck! Which one did you use? http://www.bing.com/images/search?q=tri+flow+lubricant&id=78FE2FBEAA02D1132291418BE3A10D9FD72DD8B4&FORM=IQFRBA Aerosol can..... Link to comment Share on other sites More sharing options...
choco Posted August 4, 2014 Author Share Posted August 4, 2014 My hardware store had Tri Flow in the aerosol can and powdered graphite. I ended up buying an aerosol can of Lock-Ease which is an aerosol spray of graphite, the spray evaporates and leaves the graphite. I tried it and it worked great. My ignition is working again. it's Lock-Ease Graphited Lock Fluid by the AGS company. Link to comment Share on other sites More sharing options...
spud786 Posted August 4, 2014 Share Posted August 4, 2014 The problem with graphite, if subjected to moisture turns to mud, then when it dries you have crusted mud inside your lock, the problem with silicones in high heat(sun exposure it can gel), so its take your chances longevity wise. Link to comment Share on other sites More sharing options...
Member Contributer vfrcapn Posted January 5, 2015 Member Contributer Share Posted January 5, 2015 I had to replace my ignition switch, they tend to wear out over time. What did you replace it with? OEM or dubious Chinese knockoff? I'm a little leary of those $25 eBay ones. Honda wants $135, then again the first one lasted over 16 years... Link to comment Share on other sites More sharing options...
