Member Contributer y2kvfr Posted March 21, 2014 Member Contributer Share Posted March 21, 2014 Nope. This is a big azz ground connector. About 20 wires. The 'ness doesn't affect this block, but it is near it. Link to comment Share on other sites More sharing options...
Sweeper Posted March 21, 2014 Share Posted March 21, 2014 You really don't think he could have a grounding issue with that garage queen do you? Link to comment Share on other sites More sharing options...
Member Contributer y2kvfr Posted March 21, 2014 Member Contributer Share Posted March 21, 2014 Never! ;) Link to comment Share on other sites More sharing options...
Member Contributer Burns Posted March 21, 2014 Member Contributer Share Posted March 21, 2014 the Yellow peril is more like a Lot Lizard than a garage queen, I think... Link to comment Share on other sites More sharing options...
Member Contributer y2kvfr Posted March 21, 2014 Member Contributer Share Posted March 21, 2014 Where's kkkken? I hear Jimmy Stewart voice... wh***s... Link to comment Share on other sites More sharing options...
timmythecop Posted March 21, 2014 Author Share Posted March 21, 2014 It may be a deathtrap, but it is MY deathtrap. Link to comment Share on other sites More sharing options...
Roebling3 Posted March 21, 2014 Share Posted March 21, 2014 Really cold weather and a depleting charge in the battery from lack of use or charging is deadly. Surprising that it started at all. The battery may have frozen and warped plates. Be certain to charge the replacement battery to full capacity b4 installing, no matter what the counter guy says, even if you trust him. R3~ Link to comment Share on other sites More sharing options...
Tightwad Posted March 25, 2014 Share Posted March 25, 2014 Really cold weather and a depleting charge in the battery from lack of use or charging is deadly. Surprising that it started at all. The battery may have frozen and warped plates. Be certain to charge the replacement battery to full capacity b4 installing, no matter what the counter guy says, even if you trust him. R3~ The Li-Poly batteries typically are fully charged out of the box. Link to comment Share on other sites More sharing options...
Auspanglish Posted March 25, 2014 Share Posted March 25, 2014 Nice Stones reference... Now buy yourself and/or use a battery tender... they're much cheaper then batteries... don't ride with the battery KO or it might take out the R/R and Stator as collatoral damage... Link to comment Share on other sites More sharing options...
Auspanglish Posted March 25, 2014 Share Posted March 25, 2014 BTW... just do it... http://www.vfrdiscussion.com/forum/index.php/topic/66045-urethra-i-found-it/?hl=urethra Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted March 25, 2014 Member Contributer Share Posted March 25, 2014 Now buy yourself and/or use a battery tender... they're much cheaper then batteries... That was the end reasoning for buying the 3/4 tenders I have now. It seemed like every year a battery would die, whether I put them on a charger once a month after storing them inside or leaving them in the bike for the winter. $ battery tender < $ battery Also, if you are using a Li-Ion/LiFePO4/A123 battery, DO NOT USE A TENDER ON THEM. Tenders are only for Pb batteries. Link to comment Share on other sites More sharing options...
Auspanglish Posted March 25, 2014 Share Posted March 25, 2014 Oh I just done read the whole thread and it would seem Mr FlatBlack got hisself one o them thar Li-on batteries... meanin he done gone borrowed it from Leon or sum'in?? Don't be gettin' all tender over that one... not like a NY steak or nothin'. Ya hear? Tender is for Loin not Lion... Like kinda Git it?? Link to comment Share on other sites More sharing options...
Crewwolfy Posted March 29, 2014 Share Posted March 29, 2014 I had a similar problem. Ended up being the ignition wire. If I turned the handlebars just right, it'd go black. Did the clock die? If not, probably ignition. If it's black, try turning the handlebars or fiddling with the wire coming out from the key module. As far as fixing that, I'm in the middle of figuring that out myself. Resistance is good, clock works, but still black.. Link to comment Share on other sites More sharing options...
timmythecop Posted March 29, 2014 Author Share Posted March 29, 2014 oh it is black alright. No my problem was total and sudden battery failure. No signs of impending doom, but I should have seen it coming after the ice station zebra winter we had and me leaving it in an unheated garage. Link to comment Share on other sites More sharing options...
Crewwolfy Posted March 29, 2014 Share Posted March 29, 2014 Confirmed battery? Ah, well good to know. Sounds exactly like the symptoms I had. Link to comment Share on other sites More sharing options...
timmythecop Posted April 2, 2014 Author Share Posted April 2, 2014 fired right up and is charging as it should. I forgot how light this unit is, and when I picked it up, I almost threw it over my head. Less than 1/4 wieght of the Yuasa. Note the legos that snap on the bottom to take up free space: Link to comment Share on other sites More sharing options...
Member Contributer Conedodger Posted April 2, 2014 Member Contributer Share Posted April 2, 2014 Note the legos that snap on the bottom to take up free space: Looks like a great place to store your stash...oh...wait...I didn't just tell a cop that. Link to comment Share on other sites More sharing options...
timmythecop Posted April 25, 2014 Author Share Posted April 25, 2014 A few weeks of commuting later, it is as if nothing ever happened. Only difference with this new battery is there are now only 2 values shown on volt meter: 13.4 at idle and 14.8 once moving. Rock solid. Never changes. The weight savings is absolutely un-noticeable, but this is a heavy bike to begin with. Link to comment Share on other sites More sharing options...
