Member Contributer Switchblade Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 Dam! Better open her back up! Thanks for the help. If your lucky the gasket mite survive .... Link to comment Share on other sites More sharing options...
Guest Posted December 29, 2013 Share Posted December 29, 2013 found the culprit...any idea what i need to remove in order to plug the new one in? I don't even know how that happened...dammit! lol Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 you can soilder that back up try that first before you buy a new one. Link to comment Share on other sites More sharing options...
Guest Posted December 29, 2013 Share Posted December 29, 2013 Hmmmm....you think thats good for longterm? Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 yes.. doing a quick write up for ya.. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 since the wire is already cut.. strip off the black and the yellow/white cover. take a 2 or 3 inch long piece of wire and do a FLASH SOILDER.. aka a very fast melt and cool as to not over heat the electronics inside. do this by taking the 3 inch wire and wrapping it around the stubby wire. and fanning out the strands.. you heat the strands with a flame and they get red hot real fast, melting the soilder that should be touching the wire before you heat them. it will melt FAST!! let it melt then blow it cool . trim the strands and tuck the wire.. then add shrink wrap. the soilder the other end of the wire ,. i say 2 or 3 inches but you can use 10 inches if you want Link to comment Share on other sites More sharing options...
Guest Posted December 29, 2013 Share Posted December 29, 2013 Thanks! I have a solder gun....did u just use a lighter? Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 or a candle. the flame with heat it much faster. just hold the fanned strands in the flame. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 you want to practice a few times on some scrap wire. Link to comment Share on other sites More sharing options...
Guest Posted December 29, 2013 Share Posted December 29, 2013 Its pretty bad. Im going to just replace it. I took the right side fairing off and found where it plugs into but the routing for the wire is very tight and behind the frame. Any tips to remove it? Also i cant seem to find a part number on it anywhere.... Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 found the culprit...any idea what i need to remove in order to plug the new one in? I don't even know how that happened...dammit! lol vfr.jpg Hmmmm I was afraid of that but maybe a easy fix ... Did the gasket survive ? Link to comment Share on other sites More sharing options...
Guest Posted December 29, 2013 Share Posted December 29, 2013 No, but i can clean and redo that easily. I cut the sensor wires and pulled it out from opposite ends. Gonna order new one tomorrow. Anyone know a part number? Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 go to ronayers.com and click on fiche. honda, the year, the model. then the part by where its located on the bike. but seriously? you just GAVE UP? with out even trying? thats why your bad.. you dont try! you think Nick Foles is the # 1 quarter back by not trying? come on!! give it shot! it doesnt mater if you think your no tom bradey or a manning! give a shot and if you screw up. THEN get a new one. Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 I would personally just replace the part. No need to solder this connection and have a potential issue down the road where you don't have a soldering iron on hand to fix it. You can find the part # on any parts website, such as partzilla.com, ronayers.com, and cheapcycleparts.com. I'd price check all three (with shipping) and see who's cheapest. Usually one of 3 wins out by at least 5 bucks, and lead time is similar on each. Link to comment Share on other sites More sharing options...
mcrwt644 Posted December 29, 2013 Share Posted December 29, 2013 ^^haha! I'm an Eagles fan and found gll's re awesome...Nick didn't become one of the best by not trying over and over!! Soldering is a bit of an art and takes perfect practice to be perfect, over and over and there is only one way to get that good at it....try. Also, IF this is your issue, the temporary (while waiting for the other part) fix will allow you to confirm that this IS your issue and have a running bike in the meantime... Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 No, but i can clean and redo that easily. I cut the sensor wires and pulled it out from opposite ends. Gonna order new one tomorrow. Anyone know a part number? Partzilla.com cant be beat !!!! Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 ^^haha! I'm an Eagles fan and found gll's re awesome...Nick didn't become one of the best by not trying over and over!! i am a south philly boy.. so yous hasta say it RIGHT!! DA IGGLES!! Link to comment Share on other sites More sharing options...
Guest Posted December 29, 2013 Share Posted December 29, 2013 LOL...you guys are killing me. IMO it makes alot more sense to just replace the sensor. God forbid that came apart inside the cover...that would be catastrophic. It's winter here and there is ZERO chance for me to ride the bike anytime soon anyways... Thanks for all the help so far. I will keep everyone updated. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 http://www.partzilla.com/parts/search/Honda/Motorcycle/2010/VFR1200F+AC/CLUTCH/parts.html Multiple Part Search Sign In | Order Status | Wish List Parts List by Blowout Reference# # Part Number Description MSRP Price Required Qty Price is for one part. We sell all parts individually. 1 14406-MGE-000 SPROCKET, TIMING (20T) (Honda Code 9418393) $41.78 $27.58 1 2 15131-MGE-003 SPROCKET, OIL PUMP DRIVE (30T) (Honda Code 9418559) $43.53 $28.73 1 3 22100-MGE-000 CLUTCH OUTER (Honda Code 9419557) $279.53 $184.49 1 4 22116-MGE-000 GUIDE, CLUTCH (OUTER) (Honda Code 9419565) $16.05 $10.60 1 5 22117-MEJ-610 COLLAR, DISTANCE (Honda Code 9419573) $7.02 $4.71 1 6 22120-MGE-050 CENTER, CLUTCH (Honda Code 9419581) $324.76 $214.34 1 7 22210-MGE-305 DISK SET, CLUTCH (Honda Code 9419599) $147.22 $97.16 1 8 22325-MEL-000 SPRING, CLUTCH PLATE (Honda Code 7682883) $8.69 $5.74 1 9 22326-MGE-000 SEAT, JUDDER SPRING (Honda Code 9419607) $8.44 $5.57 1 10 22350-MGE-010 PLATE, CLUTCH PRESSURE (Honda Code 9419615) $188.24 $124.24 1 11 22354-MGE-000 LIFTER, CLUTCH (Honda Code 9419623) $42.24 $27.88 1 12 22356-MGE-000 SEAT, CLUTCH LIFTER (Honda Code 9419631) $10.18 $6.72 1 13 22365-MGE-010 HOLDER, CLUTCH SPRING (Honda Code 9419649) $34.02 $22.45 1 14 22366-MGE-000 SEAT, CLUTCH SPRING (Honda Code 9419656) $11.18 $7.38 1 15 22366-MM5-000 PIECE, CLUTCH JOINT (Honda Code 2548758) $17.22 $11.36 1 16 22368-MGE-020 SEAT B, CLUTCH SPRING (Honda Code 9419664) $9.98 $6.59 1 17 22401-MGE-020 SPRING, CLUTCH (Honda Code 9419672) $8.91 $5.88 2 18 22850-MGE-000 ROD, CLUTCH LIFTER (Honda Code 9419680) $21.69 $14.32 1 19 23103-MGE-000 GEAR, PRIMARY DRIVE (42T) (Honda Code 9419789) $84.69 $55.90 1 20 23104-MGE-000 SUB-GEAR, PRIMARY (42T) (Honda Code 9419797) $48.47 $31.99 1 21 23115-MGE-000 SPRING, PRIMARY DAMPER (Honda Code 9419805) $7.91 $5.22 3 22 30291-MGE-000 ROTOR, PULSE (Honda Code 9420191) $14.59 $9.62 1 23 30300-MGE-641 GENERATOR ASSY., PULSE (Honda Code 9420209) $53.53 $35.33 1 24 90024-MGE-000 BOLT, FLANGE (12X45) (Honda Code 9423500) $5.29 $3.58 1 25 90231-MS2-610 NUT, LOCK (25MM) (Honda Code 3377561) $14.91 $9.84 1 26 90407-MFL-000 WASHER (25.1X37X3.2) (Honda Code 8901514) $3.45 $2.45 1 27 90408-MGE-000 WASHER (12.5X36X6) (Honda Code 9424094) $5.38 $3.64 1 28 90601-MFL-000 CIRCLIP, INNER (102) (Honda Code 8901555) $4.00 $2.75 1 29 91102-MEL-D20 BEARING B, NEEDLE (35X41X27.8) (Honda Code 8292831) (WHITE) $6.78 $4.55 1 30 95701-06014-00 BOLT, FLANGE (6X14) (Honda Code 2410884) $0.73 $0.54 2 Parts Finder Select Year... 20142013201220112010200920082007200620052004200320022001200019991998199719961995199419931992199119901989198819871986198519841983198219811980197919781977197619751974197319721971197019691968196719661965196419631962196119601959195819571956195519541953195219511950194919481947194619451944194319421941194019391938193719361935 Select Make... Select Model... Multiple Part Search Number 23 $35.33 !!!!! Link to comment Share on other sites More sharing options...
Guest Posted December 29, 2013 Share Posted December 29, 2013 yep...just found it on partszilla...#23 in the diagram http://www.partzilla.com/parts/detail/honda/HP-30300-MGE-641.html Cheap too! Gonna call dealer tomorrow and see if it's in stock and if they will match the price... My plan is to install it without being plugged in, that way there is no tension on it this time. After I put the cover back on, I will then route the harness to the plug in. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 29, 2013 Member Contributer Share Posted December 29, 2013 You the man ... Link to comment Share on other sites More sharing options...
SEBSPEED Posted December 29, 2013 Share Posted December 29, 2013 Call Keith at Mason City Honda if you want the absolute best prices, period. http://www.vfrdiscussion.com/forum/index.php/topic/33107-oem-parts-honda-ext-warranties/ Link to comment Share on other sites More sharing options...
lshark Posted December 29, 2013 Share Posted December 29, 2013 Hopefully some of this is helping OAK, I know this stuff can be infuriating. It's one of my biggest worries about the 1200... all the electrical crap. my biggest worry too...i just bought a nice 2000 Valkyrie because, well,one i've always loved the bike, and two, i just wanted a bike that i could wrench on and fiddle with without getting any more grey hair !!! little mistakes on the VFR can cost $$$$$$$ Link to comment Share on other sites More sharing options...
Guest Posted January 9, 2014 Share Posted January 9, 2014 Ok gang....installed the new part today but still getting the check engine blink and no start... I'm positive I did this right...do I need to reset the computer in order for it to clear? If so, is that just a matter of disconnecting the battery for a few minutes and then reconnecting? Link to comment Share on other sites More sharing options...
Guest Posted January 9, 2014 Share Posted January 9, 2014 lol....never mind gang! the beast is back! it would help to plug the new pulse generator in! haha... Link to comment Share on other sites More sharing options...
