Guest K.C. Posted September 22, 2007 Share Posted September 22, 2007 The front two bolts that hold the tank on seem like a great place to put a RAM mount for a camera but I can't figure out what base/ball plate to use. Has anyone done this ? Link to comment Share on other sites More sharing options...
Member Contributer PhatPat33 Posted September 22, 2007 Member Contributer Share Posted September 22, 2007 Check out Hulked Up's page. This is where I got the idea from. Hulked Up's Camera Mount -- WesternMassRiding.com RAM mounts. Take the U-bolt out and use the bolts from the tank to mount. Get the long arm..... This is the medium Camera Mount Link to comment Share on other sites More sharing options...
Guest Posted September 22, 2007 Share Posted September 22, 2007 2006 Honda Interceptor 022.jpg This is one with my Zumo mounted. Link to comment Share on other sites More sharing options...
turtlecreek Posted September 22, 2007 Share Posted September 22, 2007 Check out Hulked Up's page. This is where I got the idea from.Hulked Up's Camera Mount -- WesternMassRiding.com RAM mounts. Take the U-bolt out and use the bolts from the tank to mount. Get the long arm..... This is the medium Camera Mount works great! http://www.cyclegadgets.com/Products/RAM/r...prod=RAM-GPS176 Link to comment Share on other sites More sharing options...
Member Contributer Das Bone Posted September 22, 2007 Member Contributer Share Posted September 22, 2007 Yes, lots of us have been using this set up for quite a while. I've used as both a vid cam mount and a RD mount :thumbsup: 100_0410.JPG Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted September 22, 2007 Member Contributer Share Posted September 22, 2007 :huh: And love it. Link to comment Share on other sites More sharing options...
Guest 94KansasVFR Posted September 22, 2007 Share Posted September 22, 2007 The front two bolts that hold the tank on seem like a great place to put a RAM mount for a camera but I can't figure out what base/ball plate to use. Has anyone done this ? I can't find the camera mount on their site? Is it a combination of 2 parts? Sweet cheap solution! :thumbsup: How new does my windshield need to be? I think it is an original. Corey Link to comment Share on other sites More sharing options...
Member Contributer BonusVFR Posted September 22, 2007 Member Contributer Share Posted September 22, 2007 RAM tank mount works great on 5th and 6th gen bikes. Another great VFRD pass on!!!!!!!! :thumbsup: I prefer to use camera on left grip so I can shoot over the shield. Zumo goes on Tank MT. Link to comment Share on other sites More sharing options...
Member Contributer Silver#788 Posted September 22, 2007 Member Contributer Share Posted September 22, 2007 I mounted my Garmin the same way. Worked great!! :thumbsup: Link to comment Share on other sites More sharing options...
Guest Posted September 22, 2007 Share Posted September 22, 2007 Awesome, thanks for the info guys. I'm actually using a tank mount for the camera and trying to figure out where to put the recorder. I've just been putting it in my pocket, which works fine. I may just keep it there and mount the remote control, it's only abut 1.5" square. Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted September 24, 2007 Member Contributer Share Posted September 24, 2007 Check out Hulked Up's page. This is where I got the idea from.Hulked Up's Camera Mount -- WesternMassRiding.com RAM mounts. Take the U-bolt out and use the bolts from the tank to mount. RAM has two sizes of u-bolts: to fit 3/4" to 1" handlebars and for 1" to 1-1/4" handlebars. I would imagine that only one of these will fit 6th Gen. tank bolts. Which one should I use? Thanks. Link to comment Share on other sites More sharing options...
Member Contributer VIAJERO_VFR Posted September 28, 2007 Member Contributer Share Posted September 28, 2007 Check out Hulked Up's page. This is where I got the idea from.Hulked Up's Camera Mount -- WesternMassRiding.com RAM mounts. Take the U-bolt out and use the bolts from the tank to mount. RAM has two sizes of u-bolts: to fit 3/4" to 1" handlebars and for 1" to 1-1/4" handlebars. I would imagine that only one of these will fit 6th Gen. tank bolts. Which one should I use? Thanks. X2 I would also like to know which size everyone is using. This looks like a great option! Link to comment Share on other sites More sharing options...
Member Contributer BonusVFR Posted October 1, 2007 Member Contributer Share Posted October 1, 2007 No one??? THe bigger one works on the 5th which is the same as the 6th I believe. Link to comment Share on other sites More sharing options...
Member Contributer VIAJERO_VFR Posted October 1, 2007 Member Contributer Share Posted October 1, 2007 Thanks! I think I may have found the answer here as well. http://www.vfrdiscussion.com/forum/index.php?showtopic=29709 Cheers! Link to comment Share on other sites More sharing options...
zRoYz Posted October 1, 2007 Share Posted October 1, 2007 Word of advise, don't bother with a ram mount video camera, even if it's only to hold a lipstick cam. They just vibrate to much with the one mounting point & length you need to raise cam over instruments. www.sportbikecam.com has a tank mount for video cam's that bolts onto tank filler cap bolts & keeps vibration down to a minimum, I have one on my 6th gen & it works a treat (I tried the ram mount first because I already had one installed for gps). Link to comment Share on other sites More sharing options...
V4 Rosso Posted October 2, 2007 Share Posted October 2, 2007 That is some serious cameramount you got there: Link to comment Share on other sites More sharing options...
