Coxylaad Posted August 1, 2022 Posted August 1, 2022 Hi All, Been a while since I have posted anything about my ongoing project bike - so long that my original thread has been locked and I cant get back into it anymore 😞 Ive messaged the admins but i never seem to get a reply. Anyways, its been a while, mainly because I have moved house. Even after I moved its taken me a long time to get my garage into a position where I could actually do any work in it! some pics to kick off again: In its new home: Ive discovered a great way to make short work of polishing headers. Using my powerfile with an old sanding band in there is abrasive enough to remove the corrosion and tarnishing from the headers, without actually touching the metalwork: headers modified, link pip welded up and exhaust in place: Ive made the bracket to mount the main header and collector box to the botom of the frame, but I never took any pics of that. I will do that later. I have the exhaust hanger to fabricate,, but as soon as my exhaust gaskets arrive I will be moving onward to the next Job. I looking for a bit of inspiration and a motivation, so the short term objective is to the get the bike fired up and hear it running for the first time in a couple of years. 5 Quote
Member Contributer Thumbs Posted August 1, 2022 Member Contributer Posted August 1, 2022 Well done, that’s an impressive street fighter ..👌🏻 Quote
Member Contributer Tirso Posted August 1, 2022 Member Contributer Posted August 1, 2022 Welcome back. Looks great, look forward to hearing it roar. Quote
Member Contributer Yokel Posted August 1, 2022 Member Contributer Posted August 1, 2022 Oh, nice to see this back in the works. Following! Quote
Member Contributer Skids Posted August 1, 2022 Member Contributer Posted August 1, 2022 Keep up the great work. Quote
Coxylaad Posted September 2, 2022 Author Posted September 2, 2022 bit of an update: I dont get a great deal of time to work on the bike these days but Ive managed to get a few things ticked off: Needed a big earthing point for the loom, so I welded on a small section of 6mm steel onto the cross tube under the tank: Drilled and tapped: All mounted up: So Ive been looking for a bit inspiration and motivation to get moving with the bike, what more motivation than hearing it fire up for the first time! went through all the wiring connecting everything up and making sure it is how it should be. Its a bit of a wiring disaster at the moment and required a lot of sorting out, however the good news is that I got it running on the first time of asking! (well almost - I forgot to connect the fuel hose up and fired petrol across the garage floor when i turned the ignition on) Anyways video evidence: Interesting to hear the throttle bodies cycling through with no airbox or filter on. I was wondering if it was something to do with the fact they have been unplugged for over a year and they might need balancing or something, or thats the noise they make and you normally cant hear it becuase they are burried under all the plastic and ducting. Happy days. time to start tidying all the wiring up! 5 Quote
Member Contributer Yokel Posted September 4, 2022 Member Contributer Posted September 4, 2022 (edited) On 9/2/2022 at 4:03 AM, Coxylaad said: Interesting to hear the throttle bodies cycling through with no airbox or filter on. I was wondering if it was something to do with the fact they have been unplugged for over a year and they might need balancing or something, or thats the noise they make and you normally cant hear it becuase they are burried under all the plastic and ducting. Good for you getting it to fire first time. That noise is familiar on my 2010, though my bike may not be as loud. As you noted, they are typically buried under plastics/tank/etc... on the standard bike. At this point I'd say "works as intended". Edited September 4, 2022 by Yokel clarification 1 Quote
Coxylaad Posted September 20, 2022 Author Posted September 20, 2022 Update: Got a bit of time whilst everyone was watching the queen so jumped in the garage and picked a job to do - Exhaust hanger: Started with some stainless tube and a stainless nut bashed it in with a hammer Chopped the tube down, then done the same again to make the end fixing pieces of the bracket. here they are bolted in place Then took a smaller diameter stainless tube, cut to length and shaped to fit the odd interface angles, then welded up: I also welded in the nuts around the seam so no chance of them working loose (not that they could based on the force needed to press them in) Finished, apart from a bit tidying of the weld up. All stainless so doesnt require painting. Massively overengineered, just the way I like it Another job ticked off. I think the next job will be to tidy up the wiring and sort out a battery box for under the seat. 5 Quote
mello dude Posted September 20, 2022 Posted September 20, 2022 Whoa welcome back.....quite awesome stuff going on keep at it! We wanna see you finish and ride it.......motivation enough? I love bike build threads Quote
Member Contributer eastbowl2 Posted September 30, 2022 Member Contributer Posted September 30, 2022 Love it. Quote
Coxylaad Posted October 14, 2022 Author Posted October 14, 2022 Wiring work at the weekend. need to get it tidied up and fixed in place. I need to get some more photos up but Ive made the headlight bracket and fitted that Quote
Coxylaad Posted October 18, 2022 Author Posted October 18, 2022 little bit of progress: Number plate and rear indicator mounting done. You cant see the bracket underneath but it took me 2 hours to make haha 2 Quote
Coxylaad Posted November 21, 2022 Author Posted November 21, 2022 Update: Sorting out the details from the back to the front. rear indicators: I bought some BMW LED indicators, that look nice but the fittings are flimsy plastic and i wasnt happy with them, so I decided to upgrade them. flimsy removed the fitting, drilled it out, and tapped an 8mm thread into it Took an 8mm stainless bolt and drilled the centre out of it on the lathe, then chopped the head off it then threaded it into the plastic part, nice and snug back together, new and improved Next job, seat release mechanism. I kept the vfr seat lock, and acquired the Speed triple seat release mechanism, Need to mount the VFR lock and mate it up to the S3 mech. VFR lock: S3 seat release mech bracket to mount the lock in the hole and stop it turning: Its industrial, but it wont break 😀 new arm to take the end of the pull cable - I used a 10mm bolt, drilled a 8mm hole in it, then slotted it to take the nipple Removed the arm from the VFR lock, flattened it, and trimmed it down, then welded the 'nipple holder' on (he said nipple 😄) Needed some dressing at this point, but thats the last photo I had of it Modified the lock mounting bracket so it holds the pull cable outer in place et voila, sorted, and another job ticked off. 3 1 Quote
Coxylaad Posted November 23, 2022 Author Posted November 23, 2022 The last picture you may have noticed that the bike is missing a rear shock, Thats becuase it was away getting the correctly rated spring fitting to it. Its back, now with a 180nm spring on it. fitted back to the bike Im adopting a suck it an see approach with the damping. The spring rate has nearly doubled on the shock, so I need to see if the adjustment on the damping can cope. If it cant then the shock will come off and new cartridges will be fitted. Not the end of the world as TTX shock damper cartreidges are easy to swap around. Quote
Member Contributer Skids Posted May 15, 2023 Member Contributer Posted May 15, 2023 Looking good! Quote
